Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Unit turns on/off noise while operating
Does not affecy cooling capability
  • Kenmore Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerunit turns on/off noise while operating - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 12, 2010
Trane XR12 Heat doesnt work after 15minutes of operation
Sounds to me like the outdoor unit is malfunctioning. Could be a control board going crazy, could be the reversing valve leaking. A trouble call to the local contractor is the best idea, preferably a firm that deals with your brand.
Mar 31, 2014 | Heating & Cooling
Friedrich wall unit whistles when turned off
it is the automatic valve when it is closed
Dec 14, 2013 | Heating & Cooling
I have 3 Fujitsu heat / cooling multi split ductless units connected to one rooftop unit. Only in heating mode and only coming from the same indoor unit is a loud almost screeching/vibration sound. It can...
If it happens in heat it must happen in cooling. The indoor unit has nothing to do with if it's heating or cooling. You likely have 2 moving parts in the machine, the blower wheel and the swing fins. Turn swing option off, eliminate that. You get the rest...
Jun 04, 2017 | GE Zoneline AZ38H12DAD Split System Air...
I just purchased this portable air conditioner. I have a few questions about its operation and intimation. First, my window is a vertical sliding window that is about 55u inches tall. Do u have anything...
LG does not currently have an extender panel. However, call Vance Baldwin/Encompass at 1-866-779-7906, as they may can help you with that.
As far as noise is concerned: Generally speaking, most noises heard from the air conditioner are normal sounds of operation. Most of the time, noises are muffled during the day by activity in the home, but heard at night when it is more quiet.
Vibrating Noise? This is most likely the result of improper installation. Check that the unit is secured properly in the unit. Make sure the filter and the front grille are attached properly.
Hissing/Gurgling Noise? At the ON/OFF operation is caused by the refrigerant flowing inside the air conditioners sealed system. THIS IS NORMAL. This sound is a little louder for 2~3 minutes when the unit is first turned on. This is the sound of the compressor start-up. THIS IS NORMAL.
Beeping sound when control settings are selected/changed? THIS IS NORMAL. This noise is a signal that the control panel settings have been changed.
Pinging Noise? THIS IS NORMAL. This is the result of moisture in the base pan being picked up by the fan (called a slinger fan) and thrown against the condenser. This helps to discharge the heat and make the unit cool more efficiently.
Is the unit installed in an enclosed are? A unit enclosed by many walls is likely to produce more noise as the sound waves will be reflected and echoed.
Once the room temperature is met, the compressor should turn off automatically. But, the fan may run for several more minutes.
I hope this helped you. Thanks for choosing FixYa.
Jul 24, 2011 | LG LP0910WNR Air Conditioner
Can low steering fluid cause mechanical problems
Problems associated with low power steering fluid…
Hard Vehicle Steering
A low power steering fluid level can often times cause a vehicle's steering to become hard and labored. Adequate amounts of power steering fluid are necessary to enable a vehicle's power steering system to function and operate at optimum levels. A lack of power steering fluid in a vehicle's power steering system reduces the amount of hydraulic fluid pressure necessary to efficiently operating the various parts of the entire power steering system. Power steering fluid supplies the fluid force needed to operate the power steering gears and to enable power steering gearbox operation. Low power steering fluid levels reduce this hydraulic pressure, which commonly results in hard vehicle steering.
Pump Noise
It is very common for a low power steering fluid level to cause significant power steering pump noise. An adequate amount of power steering fluid is required to ensure the proper function and longevity of a power steering pump unit, which is a belt-driven pump responsible for housing and circulating power steering pump fluid. A low level of power steering fluid results in increased power steering pump friction, heat, and wear, all of which can significantly reduce the operational life of the power steering pump while at the same time cause excessive power steering pump noise.
Fluid Boiling
Many times a low power steering fluid level can result in excessive heating of power steering fluid, a condition that can seriously degrade the fluid and cause it to boil. A low power steering fluid level results in less available fluid to both lubricate and cool a power steering pump unit. A lack of power steering pump lubrication and cooling leads to excessive heat being generated within the power steering pump unit itself, a condition that translates into the available level of power steering fluid becoming super-heated and degraded. When this happens it is common for the power steering fluid to boil and lose all of its lubricating and heat-reducing capabilities.
Gearbox Wear
The power steering gearbox is a set of gears within a vehicle's power steering system designed to facilitate movement of a vehicle's front wheels. The power steering gearbox is connected to the power steering pump by hydraulic fluid lines that deliver a constant supply of power steering fluid to the power steering gearbox. A low power steering fluid level, especially a chronic and severe low power steering fluid level, can lead to increased friction and wear within the power steering gearbox assembly, a condition that can significantly shorten the operational life of the power steering gearbox and negatively affect its operation
Nov 26, 2009 | 2003 Pontiac Grand Am
When I turn the unit on the fan does not operate.
either the capacitor is not giving correct voltage and is inop,or the fan motor bearing are out and the motor is inop.
Jul 15, 2009 | Heating & Cooling
RUUD 13 SEER HEAT PUMP MALFUNCTION 2009 MODEL
I sell Rudd equipment. You have air in the system or faulty TXV. Replace TXV and evauate system. No more problem. Rusty
May 27, 2009 | Heating & Cooling
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
U-Line no longer cooling
This sounds like the thermostat is the problem. I wouldsuggest touching the compressor at the back of the unit to see if it is hot or cold. If it is hot then you have probably have power down to the compressor, if it is cold you could (if capable) bypass the thermostat to see if it kicks in. Hope this helps.
Aug 23, 2007 | U-Line 2075WC Wine Cooler
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
46 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
