Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Frigidaire Gallery Range (New). When plugged in, get a PF20 (power failure). Clock works fine. Both ovens work fine. Stovetop does not work. No heat in burners. No display over burner.
  • 677 Answers
When it doesn't heat up,
We have a Frigidaire Range model PLEF398CCC and, as many others here have mentioned, we saw the puff of smoke and the oven nor the front left burner works. The repairman has to replace a EOC on the back of the control panel and another one in the back on the bottom. The total cost for parts alone is $438 then add in the service call cost. THIS IS THE SECOND TIME we've had an EOC go bad for big bucks. The unit is about 5 years old. We're thinking of filling the landfill with it.
Use this for troublshooting:
(home-electrical.suite101.com/article.cfm/troubleshooting_an_electric_range)
another testimony to help,
Had the same problem. This solved it for me:
(lazerangle.com/sanna/index.php?option=com_content&view=section&layout=blog&id=6&Itemid=63.).
Take care.
Posted on Jul 12, 2010
  • rgazaille Jul 12, 2010
    There is no smoke. Nothing happens on stovetop as opposed to the smoke mentioned in the solution. This is a new range.
  • ikechukwu joshua
    ikechukwu joshua Jul 12, 2010
    Hi, would like to give to you a suggestion.Instead buying a newly bought oven and you've not used it or used it for too long and now you have started having complain,Don't you think it will be better, if it is if you take it back to where to bought it from? Am sure there is a guarantee on it? right.
    When you start spending money after buying what you have not really enjoyed with more expenses,men that is of disadvantage to you. Think about it and make your suggestion on what next to do.
    Take care.
I have a Kenmore 790.96224 electric range and the burners and oven do not work, but the clock is working. how do i fix?
Try replacing ONE stovetop burner and see if the new one works. If it does, replace more stovetop burners. If the new ones all work, replace the oven burners.
If that first replacement stovetop burner STILL doesn't work, don't replace any more. Instead, check (or have checked) the circuit breaker for the range. It may get power from a second source to power the clock.
Jul 26, 2014 | Kenmore 96222 / 96224 / 96229 Electric...
Why has my frigidaire CFEF372BC2 oven stopped working? There was a loud popping sound and now oven doesn't work but stovetop and clock are fine
Hi Friend, this is Z. Thank you for your inquiry!
Based on the symptoms you are describing, you may either have a communication error from the main control board or a potential wiring failure. You may try and reset your range by disconnecting the to your range for up to ten minutes by flipping the circuit breaker off and back on. If the issue proceeds, then it really could be a hit or miss calculation in parts so I would personally reach out to an experienced tech that will be able to identify the precise reason.
Jul 15, 2014 | Frigidaire FEF336BC Electric Kitchen Range
Maytag electric range model# MERH752CAS oven and stovetop stopped working.
Check the breakers. The range runs on 220v and one of the breakers may have tripped and it is running on 110v. Post back the results.
Feb 10, 2013 | Kitchen Ranges
I have a Frigidaire Gallery Professional Series Stove and Oven unit. The oven temperature indicator light has been fading for years and is now barely visible. Everything else on the control panel (timer,...
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
Oct 08, 2012 | Frigidaire FGEF3031KB Gallery 30"...
Frgidaire Pro Series glass cooktop error code
look at your owners manual and see if there is a reset mode for oven. Had a friend just reset her oven she purchased last year. sounds like it might be the same thing.
May 09, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Display Panel Not Working
Only thing is check to make sure clock control is getting 120 volts into the l1 connector on the board. If it is make sure the ribbon cable is plugged into the board properly. If it is replace board.
Mar 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
309 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
