Question about Datamax DMX-I-4208 Label Printer
Our datamax I 4208 is displaying a red flashing error message and a black chekered pattern across its display panel after we changed the label roll.
  • gita_singh Jul 12, 2010
    We have a red error message displaying on our dtamax label printer after we replaced a roll. Where is the sensor and how can I recaliberate.
  • gita_singh Jul 13, 2010
    Thank you very much. Thais solution worked for us. I appreciate the help and we are back in business. Gita
    Guru:
  • 528 Answers
Hi. May i know what is the error message that is displaying on the screen?
Posted on Jul 12, 2010
  • Archie Cruz
    Archie Cruz Jul 12, 2010
    press the FEED key for 5 seconds to calibrate the sensor label
    President:
  • 3,278 Answers
Hello.
Remove the label roll, examine to be certain it is clean and then insert correctly. Try another roll if the problem persists.
Hope this helps.
  • NinaE Jul 13, 2010
    I'm glad a solution worked. Thanks for using FixYa.
Adjusting Datamax i class
If the ribbon is moving right on the I-4208 so far that you aren't getting print on the left of your label, the typical solution is to make sure that your ribbon roll is pushed all the way in, as far as it will go (at the top center of the printer on the black hub where the ribbon and it's cardboard core slide on). Similarly, make sure that the used ribbon that is winding on to the Rewind Hub at the top front is also in (to the left) as far as it will go).
Jun 26, 2014 | Datamax DMX-I-4208 Label Printer
HOW TO FIND THE ip ADDRESS ON A DATAMAX i-4208
To view or set the IP Address on a Datamax I-4208, use the Front Control Panel on the printer and follow these steps:
Press Menu, go to Communications, then NIC Adapter, then IP Address.
Jun 19, 2014 | Datamax I-4208 Thermal Label Printer
The printer is datamax I 4208 give me an error top of form fault
Try moving the sliding green media guide out from the wall about 1/4 to 1/2 inch, until the white line is under the label path. This green piece holds the label sensor, which needs to be under the labels so it can sense the gap between labels (or the black mark on the bottom side of the backing, if there is no gap). Also, on the printer menu you must choose whether your stock has a gap (aka web) or black mark (aka reflective).
Oct 12, 2010 | Datamax I-4208 Thermal Label Printer
Datamax i -4208 printer
Any Thermal Transfer or Direct Thermal label on a 3" i.d. roll with maximum o.d. of 8" and label width between 1" - 4". Thermal transfer labels require appropriate ribbon.
Nov 24, 2009 | Datamax I-4208 Thermal Label Printer
Will not feed full length of label. display reads "ribbon fault" datamax i-4208
You may need to take out the whole ribbon assembly by removing 3 screws. The ribbon sensor looks like a L shaped clear plastic glass.
If still not working. buy the ribbon assembly.
Aug 12, 2009 | Datamax DMX-I-4208 Label Printer
Datamax I-4208 Cutter Fault
if the cutter cycles on start up up?
if not, check connector(RJ45) underneath platen assy.
I connected the I class should immediately recognize the cutter.
If it does not cut ever, check you format to see if the cutter is turned on in the driver.
I have seen some failures from wear on the bell crank that cycles the cutter.
Oct 02, 2008 | Datamax M-4208 Thermal Label Printer
Datamax DMX-I-4208 Label Printer Logo
493 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Starnley Johnwells
Starnley Johnwells
rongg
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
