Question about Xerox DOCUMATE 510 Flatbed Scanner
Scanner squeeking. Is this the roller assy? - Xerox DOCUMATE 510 Flatbed Scanner
    Genius:
  • 1,121 Answers
Is the mecanical problem, some times is some plastic gear defective or stell wire losed( out of place)
Posted on Jul 12, 2010
How to Disassembly Samsung SCX-4521FS Multifunctional Copier Scanner Unit?
Dear
to release the fusser assy. you need not to open scanner unit. open the right side cover where smps/mpba are do disconnect all connectors of the fusser assy., unscrew 4 screws (2 at left side and 2 at right side),pull toward you
Thanks and Happy new year 2015.
Dec 27, 2014 | Samsung Office Equipment & Supplies
We are a medical office that is currently using the fujitsu fi-6110. When scanning documents the feeder is pulling through 2-3 pages at a time and we are not getting all of the documents scanned due to...
Hello Jenny,
Please clean the followings using a cloth/ cleaning paper moistened with iso-propyl alcohol:(Pls refer to page-95 of your scanner getting started guide)
1.Pad Assy 2. Ultrasonic sensor 3. Idler roller 4. Pick roller 5. feed roller 6. Eject roller and 7. Glass surface
If the above doesn't help, then check the Pad Assy & Pick Roller count. If the counts exceeds the suggested replacement cycles, then you you may have to replace the same. Pls refer to page-99 of the getting started guide supplied with your scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Sep 12, 2013 | Fujitsu fi Office Equipment & Supplies
Cannon dr-2580c it was not feeding without a push so i put in new rollers and it never helped . any ideas?
I have many years experience repairing Canon scanners so here is my suggestion for you.
Can you see if the small grey roller on the top is turning when your trying to feed in a sheet of paper? If so then your problem is with one of the rollers in the back of the machine. If its not turning then you have either a belt tension problem or a bad pick up motor.
If the small grey roller is turning then lift up the top half of the scanner, another words open it up like there was a peice of paper jammed in it. With the power turned off to your scanner run your hand over the black rollers on the top they should all spin freely. The small black rollers are mounted on shaft and each row is on one shaft so those 4 or 5 shafts need to spin freely or the paper will not pass through the machine. If one of them is dragging or binding then there probably is gunk in one of the bronze rollers at the end of the shaft. If you can locate the bad shaft then you need to remove the silver plate that covers those shafts there are 2 or 3 phillips screws on each side of that silver plate (both sides) that need to be removed so you can have access to the bad bushing. Once you locate the bad roller and bushing to remove the bushing you push up on the spring clip that holds it in. There is a tab to push up on and then rock the bushing until it slides out of the machine. Once you have it in your hand clean out the gunk and use some white grease and then reinstall it back on the shaft and then reinstall the silver cover back on the machine the roller should spin freely now and your problem is corrected.
If its one of the lower rollers you probably will hear a metal on metal sound. If you try to spin these rollers by hand you will feel resistance since they are belt driven. If you push hard and they do all spin and you dont hear a metal sound like metal on metal or a squeeking sound your ok. If you do hear a metal on metal sound or a squeeking sound I would recommend you call your local Canon dealer for the repair only because taking the scanner apart is easy putting it back together again is a little tricky. I can explain how to do it to you but its time consuming on the reassembly.
I hope this helps you out with your problem.
Feb 21, 2011 | Canon DR-2580C Path-Through Scanner
Canon IR3750, jamming @ vertical feed out of tray 1 (OK on tray 2), can see roller marks (2) from vertical feed roller, cleaned, still jams. Looking for any Service Bulletins or info? Direct drive system...
3 foam peices on lower right door assy put pressure on pinch roller assy, these foam peices lose their cushion and don't put enough pressure on the pinch rollers. Rather than order through MNf. I bought 10 feet of 3/8" wide 1/4" thick foam door/window weather stripping and cut length to fit (@9"), solves this issue wonderfully. (cost is $3-4)
Dec 29, 2009 | Canon ImageClass MF5770 Laser Copier...
I have GE profile Model DPSR473EW with loud squeak when drum turns ? I also need to learn how to access the drum etc...
I have experienced two problems with "loud squeeks" with the DPSR473EW. First, if you take the top off (open door, remove two screws under top door lip releasing the top), then.., remove two small screws (inside up high - one on each side) holding the front panel/door assembly on. Pull the front panel/door assy away from the main unit - can't seperate due to some wires near the blower. On the door/front panel assy..., you will see four "teflon slides" that fit into a plastic semi-circular assy (the drum rides on those four teflon slides). Most of the time, this is where the squeeks come from - I've seen them worn thru..., and the drum riding on the plastic (just order the teflon slides - qty 4 - WE1M333). If the plastic piece that the slides fit into is worn, replace it - WE2M26 (top bearing). This should do it. If the slides look OK (so the squeek hasn't been fixed), the other place for a squeek is...., the back bearing. This bearing is basically a male rotating plastic sleeve running in a metal female hole. I have seen those wear thru the plastic bushing..., causing lots of noise. To inspect that bearing, you will need to a) remove the belt (plenty of instructions on the internet), then b)remove the drum..., then..., you can inspect that back bearing (two pieces - one piece on the back of the drum, the female piece mounted on the heater shroud.. If you need to replace that bearing, or one half of it - you can order pn WE25M40 - it will have both pieces. Good Luck
Nov 15, 2009 | GE Profile DPSR473EW Dryer
HP LJ 9040- at first fuser that was orignally
I take it your a tech or have tech ability
in my personal experience Squeeking or noticable squeeking has manily from the Output Assembly
if you can here it from the rear it is the Output assy. glad i could help
Jul 24, 2009 | Office Equipment & Supplies
I have a Maytag Legacy Dryer SDE305DAYW that is squeeking. How do I change the belt?
the belt is not causing the squeek. either the tub rollers, or the idler pully is squeeking. you must remove the front panels and drum to inspect these parts. usually when a roller or idler pully is squeeking, you need to replace them. if they arnt to worn, you can clean the shaft and grease them to stop the squeek, but i dont recomend that, as it will just be a temporary fix and will start squeeking again. this isnt a easy repair if you've never done it. let me know if you have any further questions. Shane
Jun 19, 2009 | Dryers
Squeeking
The squeeking sound usually is in the fuser area
open the fuser roller area( clear paper jam the rollers are hot wait until it cools down get some spray silicone(similar to wd 40 with a plastic tube to reach small areas spray small amount on any e
xposed gears(plastic ) do not spray the fuser rollers
if you see nay other moving parts give them a light spray
turn back on and see if sound has stopped
If not try to determine when squeeking starts
then spary appropriate area
Dec 29, 2008 | Canon ImageClass D880 Copier
Squeeking
most common problem is a bad idler pulley and/or roller assy, you can order a repair kit for your dryer probly under $40, includes new rollers, belt and idler pully part number 4392065
Mar 23, 2008 | Kenmore 62822 Electric Dryer
Squeeking in lower dryer
remove the rear panel. unplug dryer before doing anything
Oct 24, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Xerox DOCUMATE 510 Flatbed Scanner Logo
50 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
