Question about Dometic Rooftop RV Air Conditioner
My ac unit isn't blowing very strong on my R V
Had a new A C unit installed and it isn't blowing out very much cold air and isn't blowing hardly at all in the back bedroom of our camper, I'm wondering if it is bigenough for our camper. The model # is 641416.301c0
Ice maker
  • 8 Answers
SOURCE: ac blowing hot air instead of cold
Check for the following problems
(1) Check if compressor is geting power
(2) Check if system have Refrigerant in it
(3) Check if pressure switches are operational
(4) Check Thermostrat setting.
(5) Check for dirty or block condenser or evaporator
Send feed back if you solve problem
Posted on Mar 27, 2008
SOURCE: I have a dometic duo-therm. No air coming through ducts.
I have a new Montana Mountaineer with a Dometic Duo Therm as well and experience something similar.
It appears that there are two options:
1. Open the vents in the unit and all the cold air will blow out of the AC as that would be the shortest path and the there is hardly any air coming out of the ducts.
2. Close the vents in the unit and it will force all the air through the ducts.
We let the air blow straight out of the unit during the day and then force it through the ducts at night to force it in the bedrooms. You could also open the vents in the unit part ways to get a combination.
I didn't figure it out immediatly either, but just look close at the unit and you can see that you can close the vents on the unit itself
Posted on Apr 20, 2009
  • 4 Answers
SOURCE: carrier air-v AC is not blowing cold air
There could be a freon leak, or just low freon levels. If this is the case, you have to call a certified a/c technician to recharge your system.
Posted on May 19, 2009
motor1258
  • 6674 Answers
SOURCE: ac unit is blowing cold air but not enough to cool
Has it had a good cleaning recently? Coils/fins at condenser and evaporator?
Posted on Jul 10, 2010
motor1258
  • 6674 Answers
SOURCE: i have a travel trailer
If it's leaking inside where filter cover is, then real good chance the drains being plugged is the only problem. If water (condensation) not running off roof when operating in cool mode, then I'd bet drains, which are located under unit on roof, and you should see them sticking down like buttons. They have a hole in side that needs cleaning with a pipe cleaner or similar to open them up. If need be, shut off power to unit and remove top cover on roof unit and look for the drain holes in base, and clean them out. If water comes in while raining, but AC not running, then it's gasket. That is remedied by removing ceiling assembly (just screws) and 4 bolts that pull/hold the upper and lower assemblies together, unplug wiring to upper unit, and simply lift it off, change gasket and re-install. Tighten those 4 bolts equally when gasket is aligned properly over hole, only until gasket is approx 1/2, original thickness. Plug harness back in and your done. (about an hours work.) Only other thing that may be wrong is styrofoam drip tray for cooling unit, under cover on roof may have a crack , allowing condensation to leak in. If that 's the case, you can try to find a sealant compatible with styrofoam to seal those cracks.
Posted on Dec 03, 2010
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
Sep 25, 2013 | Dometic Rooftop RV Air Conditioner
Blows cold when first started and then blowes warm
I would replace the AC compressor cycling switch it may be sticking have seen it a number of times. The switch is located in the receiver dryer on the passenger side of the engine compartment. See picture below.
If this isn't the problem the AC compressor relay may also cause this, flip a coin.
Sep 13, 2012 | 1999 Ford Taurus
My air conditioner isnt blowing cold air
is the ac a manual one or automatic? if it's manual then it froze and will no longer work. it froze and is all done working. time for a new one. I bought one 12 years ago and apparently I was suppose to turn on and off. The ac couldn't do that. IF it works on it's own maybe the circuit isn't the higher amp for 220 ac units.
Sep 07, 2012 | tranexp.com Computers & Internet
My new ac unit isnt blowing out cold enough
What's the temp been out side? If its over 95 degrees only expect you air to blow at about 75. It's an air conditioner not a cold air maker.
Sep 02, 2012 | 1986 Toyota Corolla 2 Door
Car blows warm air when idling
It sounds like your AC unit could be overheating or even damaged.
AC units have a sensor that will turn them off automatically to prevent damage from overheating. If there is an insufficient amount of air flow, the unit will heat up, and then eventually turn off.
When the car is moving, more air is forced over the unit, likely keeping it cool enough to run, however, when the car come to a stop, it loses that air flow, and quickly heats up. Thus, the AC would work while the vehicle is in motion, and overheat and stop when the car is stopped and idling.
However, the AC unit could be completely blown. The cold air while moving could be just a case of air being forced into the car. Think of a house fan, the fast the wind blows on you, the cooler it gets.... Thus, it could be an illusion that the AC is working when car is in motion, when it really isn't.
Hope this helps.
Jun 09, 2012 | 2004 Lincoln LS
My g.e. a/c isn't blowing as hard as it should its running the same temp on fan and cool its not cold what should i do we cleaned the filter and everything plz help me
Hello my name is Heath it will be my pleasure to assist you. The first thing to check is the filter in the furnace or air handler. Also check the inside coil to be sure its not frozen up. Does the air coming out feel cold? It sounds like the unit could be low on charge which means it has a leak and should be leak checked repaired and properly charged. You would need refrigeration gauges to put on the system in order to properly check the refrigerant charge in the system. One other thing could be a dirty condenser coil. Turn the power off to the unit and use a garden hose with a strong nozzle and spray water through the whole coil to try and blow any dirt or debris through the condenser coil in the outside unit.
Aug 27, 2011 | Kenmore 72055 Air Conditioner
My goldstar R2403 doesn't seem to be pushing out as cold as I feel it should we just had the unit refirbished and they claim it was running ice cold sitting on the bench in repair shop, however we have...
The link below is for the Owners/Service Manual for your model Goldstar AC unit. It should be of tremendous help in troubleshooting and solving the problem. Either by you. or your maintenance man.
http://www.appliancefactoryparts.com/content/pdfs/118630.pdf
Hope this helps you.
Jul 20, 2011 | Goldstar R2403 Air Conditioner
When idling, a/c blows hot. New compressor installed. But whwn driving it blows cold
Check the fan. Some systems have a separate fan for the AC when running. If it isn't running when up on temp, check fuses, and the fan. If good, check sensor and relay.
--W/D--
May 31, 2011 | Air Tools & Compressors
My outdoor AC unit is not coming on. Air is blowing out of my vents inside but the snowflake symbol on my thermostat is blinking and the air isn't cold. The fan on the unit isn't even running. Any...
check power to outside unit, check if it has a fused disconnect, if you have power and no blown fuses it could be a blown capicator that starts the fan and compressor...............
May 09, 2011 | Heating & Cooling
AC not blowing Cold Air
take ac cage off or ac out of window so insides are exposed take out side and use water hose and clean out side coils and in side coils dont bend these coils or u will be sorry,,,clean out good if not stoped up have freon put in
Jul 03, 2009 | Goldstar M5200R Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
70 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
