Question about Miele Refrigerators
My Miele frost free fridge freezer is accumulating ice and water below the two trays in the fridge. What to do, please?
    Problem Solver:
  • 15 Answers
Call Service. 1-800-999-1360 (US) or the Canadian number. Most likely the circulation fan and/or damper flap could be out of whack.
Posted on Jul 12, 2010
Water is accumulating & freezing @ bottom of freezer ice maker has been removed water to fridge has been turned off still, water coming from somewhere & freezing
This is what it sounds like to me. There is a drain hole for the defrost water to drain down to the "drip pan" If that hole in the drain pan is clogged. Then when the defrost system melts away the frost in the cooling coils. Every 6 or 8 hours. The water will accumulate in the bottom of the freezer compartment and turn into ice. This is a very common problem.
The solution.
Put the food in the freezer and fridge into coolers and pack with Ice. Get the 99 cent coolers at the supermarket and buy some Ice there too.
Shut the fridge down and open the freezer door. chop out the Ice in the bottom of the freezer compartment, but not in the drain area directly below the coils. that will be hard to get to and you may damage the fridge if you just chop away.
To speed up the process, get some hot water in a glass and pour it into the area below the coils
(that should be a solid block of Ice as well). If you cant get to this easily, just wait for the fridge to thaw out naturally.
After it has thawed out, you should be able to locate the drain tube in the bottom of the small tray
below the coils. Stick a flexible piece of wire, or pipe cleaner or something of the sort into it to completely unclog it. So when you pour water into that tray, it immediately drains out completely.
into the "drain pan" located below the freezer compartment in the base of the fridge.
I hope this helps,
Best Regards,
Mark
Dec 30, 2010 | Maytag MSD2756GES Side by Side...
Tip
Refridgerator warm and freezer is icy cold
Frost free fridge freezers are very popular and auto defrosting fridges are a great convenience. In a frost free appliance the cold air is blown round the freezer using a fan. On modern refrigeration the evaporator (which is the plate that gets cold) is hidden behind the plastic wall inside at the back of the food shelves. When working correctly you can usually see small beads of ice randomly scattered on the back wall unless it's in a defrost cycle when you may see water.<br /> Heater inside Believe it or not most modern refrigeration has a heater inside. This heater is used to defrost the appliance automatically. During the defrosting cycle the ice on the back wall melts and runs down the back wall into a channel. It is then directed through a hole out through to the back and runs into the evaporator tray. The evaporator tray is on top of the compressor which gets pretty hot and evaporates this water into the air.<br /> Because the evaporator is behind a back panel the cold air has to be blown around the compartment with a fan motor. The defrost cycle also needs sensors and a timer and combined with several sensors throughout and PCBs to control everything the result is there is a lot more to go wrong than there used to be in old-fashioned conventional fridges. However, they are still fairly reliable.<br /> Common problems with frost free fridge freezers If the door is left open for too long (especially in humid conditions) the evaporator freezes over and the unit will not keep the food cold. This problem (unlike the older machines) has a greater impact because you can't see the amount of ice built up around the back of the panel hiding the evaporator. In many frost free fridges the ice can form all the way round the fan and cause it to run slowly or even seize up. Prior to seizing up the fan may catch on the ice and make a high pitched noise. This will of course result in the fridge or freezer not getting cold. If you hear a strange noise from your frost free fridge freezer which sounds like something is catching on a rotating fan it could be due to ice forming around it.<br /> If it stops working due to ice forming behind the evaporator and round the fan then defrosting the unit manually can fix it but it involves unplugging the unit for at least take 12 hours or so. You may not see much frost as it would be behind the back wall or behind the fan unit. You can't really use a hair dryer on modern units because they may have a thermal fuse which protects the defrost cycle. Also, even just getting to the evaporator to defrost it can be a mammoth task especially with some of the new American-style fridges. If a fault re-occurs later it could be due to faulty sensor but if the fault was only due to the door been left open for a few hours accidentally then a total defrost could work. <br /> Whilst we are on with American style frost free fridge freezer's, because the door's are so big and can store so much, the opportunity to overload them is greater. This too causes warm air to pass into the unit and frost it up. Remember a frost free unit will not cope with too much ice on the evaporator so greater care must be taken to use it correctly and check the door seal's regularly. <br /> <b>Water or sheet of ice inside fridge</b><br /> If your fridge has two sloping channels at the back wall and a hole in the middle this is designed to channel the water created on the defrost cycle through to the back of the unit where it runs onto an evaporator tray. This tray sits on top of the compressor and gets quite hot. The water simply evaporates. Sometimes this hole gets clogged up and prevents the water running out to this tray. The result is that water runs into be base of the unit. Very often the appliance will come with small tool for cleaning out this hole, but if not you can improvise.<br /> If the water in the base of the unit is frozen solid it could be that the unit has malfunctioned and is over freezing. The blockage preventing the water running through to the evaporator tray could actually be solid ice.<br /> <b>Summary</b><br /> It's common knowledge that most people rarely read the instruction book supplied with their new appliance. This is particularly true with something like a fridge or freezer. It's easy to imagine most people thinking you only need to plug it in, leave it plugged in, and fill it with food - what's to know?<br /> I would advise anyone with a modern refrigeration appliance, especially the American-style fridge freezers, to carefully read the instruction book. Modern frost-free refrigeration units work very differently to a conventional fridge or freezer. It's even important to learn how to stack them properly otherwise you can prevent the air from circulating inside and cause warm spots.<br /> You would be surprised at what you can learn from reading the instruction book.<br /> Many <a href="http://www.washerhelp.co.uk/instruction-manuals.html">User instruction manuals</a> can be downloaded here. The page concentrates on washing machine manuals but links to appliance manufacturer sites where users such manuals for fridges, freezers and other appliances should also be available.
on May 22, 2011 | Refrigerators
Frigidaire upright freezer Model # FFU14FC4AW0 frost free has water that accumulates under it. It's like it is leaking water on the floor. Not alot, but it has to wiped up and is leaving water stains on...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Nov 30, 2009 | Washing Machines
Water dripping down from freezer into refrigerator
This is likely due to an ice clogged defrost drain tube. Empty the freezer compartment of foods into a cooler chest or other freezer. Most modern freezers are frost free types. When the defrost circuit comes on, frost on the coil is melted and collected in a small tray. The tray is pitched to a low point that has a hose connected to bring the water to a tray under the fridge - where it is evaporated by the heat from the compressor and fan.
You'll need to determine exactly where the freezer coil and defrost heater is, but it is most likely behind a panel at the back of the inside of the freezer. Unplug the fridge.
Once found, locate the tray. Thaw any ice found in the tray (and drain tube opening) with hot water directed at these parts with a turkey baster or similar device.
Once cleared, mix 3 or 4 ounces of water with an once of bleach and direct it down the tube. This will kill any bacteria / mold / other growths that can cause a slow drain.
Reassemble & power up the fridge.
I hope this was Very Helpful and good luck!
Nov 20, 2009 | Coffee Makers & Espresso Machines
Water accumulation underneath the bottom vetable
Two solutions
1 If a frost free fridge/freezer - ice build up in internal cooler - defrost totally until no more water
2 if ordinary fridge/freezer look inside at the back, you should see a very shallow 'V' shaped plastic channel running to a small drain hole which leads to the rear outside of the unit. This channel collects the water drips from the cooler
Clear this hole with a pipe cleaner or cocktail stick or similar
Sep 27, 2009 | Samsung Refrigerators
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Water accumulates under the vegtable and fruit bin
You may have a pluged drain tube and prevents the water from draining into the drip pan below the fridge.you will have to remove the tube from rear of fridge and clean.If you cannot get into the tube you will need to remove the rear panel inside the freezer compartment.and then pour hot water down from there till it breakes free.If your freezer is iced up you wil need 1of3 things first defrost timer second defrost thermostat third defrost element.Hope i helped:)
May 18, 2009 | GE J Series 20.6 cu. ft. Top Freezer...
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Refrigerators Logo
642 people viewed this question
Top Miele Refrigerators Experts
AJMAL KHAN
JonSnell Electronic
JonSnell Electronic
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
