Question about Toshiba 26HLV66 26 in. LCD TV/DVD Combo
I will be watching tv and the screen freezes then turns white
I will be watching tv and the screen freezes then turns a whitist color. what is causing this?
  • 11,361 Answers
So if are just getting white/grey glowing screen now? If that is the case, look to see if you do have 12vdc feeding the T-CON board, check the surface mounted fuse on T-CON board also.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 12, 2010
SCREEN IS PINK AND NO SOUND..MENU SCREEN COMES UP IN CORRECT COLORS
How to Fix TV Pink Screen, Tech Tips 16 - YouTube
? 0:51
https://www.youtube.com/watch?v=84tyJ6A1frg
Apr 13, 2013 - Uploaded by Tampatec
Turning on and off the TV (not cable box) does recharge thescreen and the colors will properly disperse ...
Why is everything that was white now colored pink on my ...
www.makeuseof.com/.../why-is-everything-that-was-white-now-colored-...
Dec 15, 2015 | Televison & Video
Digital Lifestyles 42" LCD HDTV
How many hours has the tv been used ... approx... as this will reveal further solutions..
Jun 09, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
Color
U hear grinding noises,squiling noise,before colors fades in&out,turn to Black&White picture,than died?Yes,than ur DLP tv have a colors wheel,it defective,require replacing.The colors wheel is spinning off of it motor axis.The tv tech,should be hire for changing the tv colors wheel.
Jul 24, 2010 | Sharp 65DR650 65" Rear Projection...
SCREEN FREEZES ON MY SAMSUNG DLP
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,picture will freeze,color distortion or white dots on screens.I couldn't find the Dmd by itself but found it with the complete light engine http://www.discount-merchant.com/SAMSUNG-BP41-00119E-p/1171034.htm?Click=48173 Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 29, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
Toshiba 26HLV66 26 in. LCD TV/DVD Combo Logo
365 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
