Question about Kitchen Ranges
My Whirlpool Oven will not come to temperature. The broiler seems to be working. When I set the temp, it will usually warm, but either not get up to temp or take forever.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check that the oven temperature sensor has not gone bad and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 12, 2010
  • jbartoszewic Jul 12, 2010
    Okay, thanks.
    But how do I know if the oven temperature sensor has gone bad?
    I found a parts diagram on-line so I could probably find the part, but how do I know if it is working?
    Also, the part (if I am looking at the right one) is $147 - does that sound right?
  • Rylee Smith
    Rylee Smith Jul 12, 2010
    Oven temp
    sensors senses the temperature in the oven cavity and the temp sensor changes
    resistance, this change in resistance tells the oven control what temperature
    the oven cavity at and tells the control to shut off the element or turn it
    back on. The most common temp sensors used today are approx 1000-1300 ohm
    resistance at room temperature (70F). Make sure the wire nuts/connectors are
    completely through the insulation and not touching the back of the oven cavity.
    You'll need to disassemble the oven to check for the resistance of oven temp
    sensor, to verify that the temp sensor is faulty. And, if you find that its
    resistance is less than 1000ohms then you'll need to replace it or else it's
    the glow igniter that is faulty and needs to be changed. Please do accept the solution if the issue is resolved or
    Thanks
    Rylee
My whirlpool SF265LXTS oven turns on properly, but the oven itself isn't getting hot. The gas stove top and broiler both work fine.
It sounds like you might have a clogged burner plate or manifold. You should call a certified gas repair service. This could be very dangerous, even deadly.
Dec 15, 2013 | Whirlpool SF265LXTS Kitchen Range
Oven will not reach desired temperature and slight gas smell
Just had same problem it was nice it waited until christmas dinner, all i did to resolve the problem was switch the upper broiler igniter with the lower one for the oven. I tuned on the oven & it fired right up i never use the broiler on my oven so itll buy me some time. So if you can get the broiler to light try that but i did have the same low temp. & the smell of gas. Good Luck
Jul 29, 2010 | KitchenAid KGRT607 Gas Kitchen Range
The oven does not stay an even temperature and there is a gas smell. The broiler works fine! Only the oven....
By the parts diagram, it looks like you have a glow coil type igniter . Generally when the oven wont keep temperature, the igniter is failing to reignite the burner. The burner comes on till it reaches temp then shuts off until the temp falls below a certain temp then comes back on until it reaches temp again and so on and so forth. Most of the time the igniter has a very small crack in it and doesn't begin to fail until it cycles several times. I would check the igniter and the safety valves and coils on the valve
Dec 15, 2009 | Whirlpool Kitchen Ranges
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Kenmore gas range model# 362.72321 Oven will not ignite (sometimes)
Range Oven Temperature Sensor Part Number WB20K0004 Sears PartsDirect
This will be why the oven acts up. The broiler doesn't rely as much on this as the bake part does. Replace this and it should fix your problem.
Jun 14, 2017 | Ovens
Whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
Oct 24, 2008 | Frigidaire FEB24S2AB Single Oven
Whirlpool Electric Wall Oven RBS275PDQ6
had same problem, had computer checked out by profesisonal. Was ok. But it seems it is the control pad that clean cycle screws up. Try this (thanks to my wife and her experimental prowess). 1. turn oven on to custom broil. 2. push down temp button to 375. 3. press bake button. 4. You should now have up or down temp. We think you have to get past pre heat cycle in order for this to work. But work it does.
May 07, 2008 | Whirlpool GBD307PDS Electric Double Oven
1988 General Electric Oven
Sounds like the the thermostat. This is the dial item which controls the temperature. Removal and replacement is usually straightforward. Turn off the power before starting work.
Dec 28, 2007 | Ovens
Kitchen Ranges Logo
16 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
