Question about Eagle Cuda 242 Fishfinder
A light comes on in the lower bottom of the screen.the transducer ticks and the unit beeps when buttons are pushed. The is nothing on the screnn.
Be sure you turn the contrast down. We had ours up high and we couldn't read anything. I brought the contrast down and we could read it even in bright sunlight.
Posted on Aug 24, 2010
My Mark 4 sometimes shows incorrect depths. The transducer has not moved and no problem with electrical. One point it is working fine, the screen then runs multiple vertical lines and the depth chan
Take note if when the vertical lines appear on the screen if the depth numbers begin to flash. If this is the case then the transducer has lost bottom contact and the unit is trying to reacquire bottom contact. If the transducer is parallel to the bottom of the lake while your boat is not moving then, the next time you have it on the trailer, turn your unit on and go listen and or feel the transducer to see if you can hear and or feel the tick or sonar ping. If you can't your transducer may be faulty. If the loss of bottom contact occurs when you are moving it will happen at a certain speed. This is the result of air bubbles passing under the transducer and disrupting the sonar signal causing loss of bottom contact.
Sep 19, 2014 | Lowrance Mark 4 Chartplotter/fishfinder...
My fishmark 320 hasn't been turned on for 3 years, there are beeps when I push the buttons but nothing comes on the screen
do you have this unit on the boat with transducer hooked up or you have it wired to a battery seeing if it just comes on
Sep 10, 2013 | Boating
Screen
is the unit on auto depth .... if out of water it will not read try to do a soft reboot on your unit if that don't work try new transducer your not getting bottom lock..units in limbo don't know what to do
Jul 14, 2013 | Boating
I have a Frigidaire Beverage Center Model FFBC46F5LS It was installed on Friday and worked fine until today (Sunday) where it has started to beep constantly. If I press the light button at the bottom of...
I recently purchased a Frigidaire Beverage Center and had the same constant beeping issue as strivieri. I found my problem to be the door sensor. The door sensor is located on the lower bottom right of the unit and there is a metal plate mounted on the swinging door that is suppose to push that sensor in when the door is closed. However, this was poorly designed as it fails to do its task. I had a few adhesive floor protectors laying around that I used to stick to that metal plate that gave it the extra thickness needed to push in the door sensor when closing the door.
I hope this helps anyone else there having the same issue.
Nov 14, 2010 | Frigidaire FFBC46F5LS
When at speed i tend to lose sight of the bottom it becomes very broken. Also the depth reading takes a while to record depth.
What you are experiencing sounds like air bubbles crossing the face of the transducer. If you have a transom mount transducer check the face of the transducer. Make sure that it is clean. Also make sure the front of the transducer is a tiny bit lower than the back. The digital readout on the screen will only happen when you have a strong signal of the bottom.
Jun 28, 2010 | Lowrance Dual Frequency Transducer
My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
Jan 21, 2010 | Humminbird Boating
Eagle Fisheasy No screen display and only beeps
You could have blown the transducer.....it is supposed to be in water before you turn it on. A 5 gal. bucket inside the boat would be fine for when out the water. Put the transducer in the 5gal bucket with water and try again. You may have to get another. sorry.
Dec 20, 2009 | Eagle Fisheasy 250ds Fishfinder
Plug into car an power light (green) comes on at bottom unit but the screen does not come on. Yes, I did push the power button on top of unit and nothing?
I found tomtom internet services and followed their instruction to charge the unit for 2 hours and then restart by holding down the power button upto 15 secounds.
Jul 28, 2009 | Tomtom GPS
Fisher & Paykel GW612 beeps before spin.
You have fault code 66 (01000010) Phase 6- Pressure Transducer (Ptx) Error - Frequency >90kHZ. In simple terms you need to replace the main "Motor Control Module" Cheers
Mar 09, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
383c transducer gives nothing but noisy red feedback at medium or high speeds
If it works at low speeds fine but has problems at higher speeds, basically you need to lower the transducer down further as it is lifted by the boat at higher speeds, or is getting caught in the turbulence of surface water created at higher speed. Lower the transducer a half inch at a time and re-test.
Sep 19, 2008 | Humminbird XNT Transducers XNT 9 20 T ...
Eagle Cuda 242 Fishfinder Logo
158 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Phil Walker
Phil Walker
Are you an Eagle Boating Expert? Answer questions, earn points and help others
