Question about Whirlpool Duet GHW9150P Front Load Washer
Error code F35 and SUD - Whirlpool Duet GHW9150P Front Load Washer
  • Anonymous Mar 19, 2014
    F35 error code
    President:
  • 1,382 Answers
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trapclean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Posted on Jul 12, 2010
Hi All,
We had this exact same problem, and I wanted everyone to know that you may not have to actually replace the analog pressure switch. Based on everything I have read, that is the final solution that always seems to fix the Suds/F35 problem. However, I was able to clear the problem by also trying to clear the switch before replacing. Here's what I did:
1) Follow all instructions on how to replace the Analog Pressure Switch. Completely remove it by disconnecting the hose, disconnecting the cable, and turning it sideways to pull the switch from the side of the washer.
2) Blow into the hose as recommended (couldn't reach it, so I put a regular straw on the end and blew through that).
3) Here's the key -- trying turning the switch upside down, sideways, and shaking it a bit. I didn't do this, but you might want to try "sucking" water/bubbles/debris out of the switch nipple.
4) Then reinstall the switch and see if it works.
All of the instructions tell you everything but trying to clear the actual switch. They want you to just replace it. This may not work and you may actually have to replace it. But it's worth a try and could save you anywhere from $65-$120 (minus labor costs).
Worked for us!
Keith
Posted on Oct 26, 2013
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite he3t stream showing error code sud
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
SOURCE: Sud and F35 error in my kenmore elite h5 steam
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Posted on Aug 13, 2010
SOURCE: kenmore elite he3 front load
I had the same issue with a brand new wash. The issue I found was the installers installed the drain line too low. The drain line needs to be a minimum of 39" above the floor. Hope this helps -- Kent
Posted on Nov 11, 2008
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore Elite
Thanks for using FixYa!!
Posted on Nov 12, 2010
SOURCE: F35 & SuD error codes on Kenmore Elite Washer
When my kenmore elite 4he was displaying SUd and f35 I ran the clean washer cycle with no clothes or any soap added to the soap dish. So far I don't have a problem with the washer yet. You should always check underneath the rubber around the front. Make sure there are no objects underneath the grey rubber.
Posted on Feb 22, 2011
Kenmore elite 5t steam f35 and sud problem
The F35 error code indicates a problem with the analog pressure sensor, air hose or air trap. If the hose and trap are good you will need to replace the pressure sensor
The "Sud" error code indicates too much or the wrong kind of laundry soap was used. Be sure to use only HE (high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Sep 25, 2011 | Kenmore Elite 45986 Front Load Washer
Code f35 and sud on washer machine/whirlpool duet front loader
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
May 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code washing is delayed wil wash half the clothes
Mar 06, 2010 | Whirlpool GHW9300 Duet Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,756 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
