Question about Samsung LN-T4061F 40 in. LCD HDTV
When turning on the tv it chimes as it always has before powering up but it has been chimeing twice during startup. Then it started doing it three times and now it does it 4 times before turning on. This takes up to a minute to turn on the tv now
  • Samsung Master
  • 8,457 Answers
The tv power supply board have these parts call capacitors.It dying and have leakages of gases.That the board,where the power a/c cord plug into it.That the power supply board.These capacitors parts are alway bulges up on it tops or puff up on it tops,it dying.U know basic electronic and soldering?Replaced these dying to be dead capcitors,will cure ur delay of the tv power start up.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Jul 12, 2010
How do i disconnect fuse to seat belt alarm tried three time method didnt work
The seat belt warning chime is controlled by the central timer module ! You can't just disconnect fuses , other things may stop working !
Safety Belt Warning Indicator Lamp and Chime
The safety belt indicator and chime feature is controlled by the CTM. The driver safety belt switch is hardwired to the CTM. If at any time during the first 60 seconds after the ignition switch is placed in position II, if the driver safety belt is sensed as being unfastened, the CTM will process the input, and in turn, output a signal to the CTM through a hardwired circuit. In turn the CTM will output a visual warning to the instrument cluster. If at any time during the first six seconds after the ignition switch is place in position II and the safety belt is not fastened, the safety belt warning chime will sound.
When the seat belt is connected the warning still chimes ? Could have code stored in the CTM .
B1464 Safety belt switch circuit short to battery CTM Go To Pinpoint Test B .
SoW
Jun 30, 2015 | 2002 Ford SVT Focus
Startup chime on my mac powerbook g4 stopped working. please help !
The parameter ram reset will reset that and other basics back to factory without losing any data. To do this, take a moment and find the command, option, p and r keys and figure out how you are going to hold them ALL down at together. The mac should be off, if not, shut it down (not restart-shutdown). Now, touch the power button and immediately hold down the cmd-option-p-r keys. Hold them for the screen to cycle black to gray THREE times (each taking about 15 seconds), then let go and let the mac complete the boot cycle. On the second cycle, you should have already heard the "chime" appear. That's it! Good Luck.
Dec 12, 2014 | Apple Powerbook G4 15" 1.5GHz SuperDrive...
Why does a chime ding intermittently, always twice?
Door open chime? Mayhem defective door switch
May 13, 2017 | 2007 GMC Envoy Denali
Why does my 2000 Buick Regal chime when I hit the door lock button? I always have to press it twice for it to lock.
Those year gm's require you to hit the lock button twice. It is designed this way to help prevent you from locking the door on accident (or locking the door with the keys in the car) the chime alerts you that the lock button has been pushed. I think there might be an option to change that function. I'll do some research and get back to you. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jan 26, 2012 | 2000 Buick Regal
Startup switch on PB G4 17 not getting apple sound, takes numerous times to boot up. Using Tiger OS, upgraded to latest. Works fine, otherwise.
If a Mac is shut down while the volume is set to zero, the standard Apple startup chime will not sound, so it is impossible to say whether or not this symptom indicates a problem.
For a startup issue such as this, I would recommend zapping the PRAM and resetting Open Firmware.
To zap the PRAM, start with a powered-down machine, press the power button, then immediately hold down the four keys: command, option, P, R. After ten seconds or so, you should hear the optical drive reset, and then the startup chime (because the volume is reset to full by this procedure). Ten more seconds, another reset, another chime. After the second time you hear the chime, release the keys.
Shut the machine down again (if it doesn't start up successfully, hold the power button until the power goes off). Press the power button, then immediately hold down the four keys command, option, O, F. You will see some tech-speak on the screen, then it will wait for input. Enter the following three lines, pressing the "return" key at the end of each:
reset-nvram set-defaults reset-all
After the last line, your Mac will reboot itself. It should now boot much more reliably. If it doesn't, chances increase that you have a hardware problem. You may want to run the Apple Hardware Test from the DVDs that came with the PowerBook to check your memory and logic board. Failing this, you are in for a trip to the shop.
Oct 05, 2009 | Apple PowerBook G4 Mac Notebook
My powerbook G4 does not chime!!
I suggest you plug it into AC power, then boot with Command-P-R held down until you hear the unit chime twice, then release it. Hopefully, it will boot after this.
If not, boot with Command-O-F held down; when you reach the command line, type
reset-nvram [return-key]
reset-all [return-key]
If it doesn't boot after that, you have deeper issues if the machine is actually turning itself on and off.
Sep 18, 2009 | Apple PowerBook G4 Mac Notebook
Program a keyless entry remote on a 2000 chevy malibu
PROGRAMMING
Method One
Sit in driver's seat
Close all doors
Press and HOLD UNLOCK button on door lock switch.
Insert and remove ignition key twice. Do NOT turn ignition switch
Insert ignition key a third time and leave it in the ignition switch. Do NOT turn ignition switch
Release door lock switch.
A chime will sound three times indicating remote programming active
Press and HOLD the LOCK and UNLOCK buttons on each remote for 5 seconds
A chime will sound twice for each remote: indicating successful programming
Remove the key from the ignition switch to exit programming
Method Two
Remotes can be programmed using diagnostic equipment.
Jul 08, 2009 | 2000 Chevrolet Malibu
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Need programming instructions for RKE for 2000 Mazda 626
2000 Mazda 626
Note: Make SURE the battery is new.
Instructions for programming ONE keyless remote fob.
1. Open the driver’s door & leave open.
2. Insert the key in the ignition.
3. Turn the key to the on and off position 3 times.
4. Remove the key from the ignition.
5. After door open chime stops, press the door open button 3 times.
6. After chime, press any fob key twice.
7. After second chime, press any fob key twice again.
8. After third chime, press any fob key twice again.
9. Press the door open button once.
10. The car should give another acknowledgement chime.
11. Test key fob.
This DOES work. I just programmed mine successfully today, three hours ago.
Sep 03, 2008 | 2000 Mazda 626
Samsung LN-T4061F 40 in. LCD HDTV Logo
161 people viewed this question
Jerry Greenberg
Jerry Greenberg
