Question about Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground
O I have to put the 2 wires to the transf.underneath the screws or the little flat plates?
Put the wire under the flat plate, but make sure no insulation is under the plate, just the wire.
Open following for Power Pack troubleshoot and resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 27, 2011
When i power up gateway screen is black
Most likely, its a power supply issue. Have fixed a couple of these by replacing bad capacitors on the power supply board. A bad capacitor will have the top bulging, not flat on top as it should be. The way to get the monitor apart is a little tricky. You will need to remove the screws around the top, sides, and bottom, Do Not remove screws on back in the middle. These screws hold the metallic pan that houses the power supply it's self. I used an orange pealer from Tupperware to pray the front face plate away from the back. You can use a screwdriver, if you don't mind a little marring on the face plate plastic. It's not easy removing the front face piece, lots of interconnecting plastic locks all.around the front face plate. Using your pry tool and pulling (you'll need to use a little muscle) to get the front off. Once face plate is loose, you'll notice the screen is connected to the power supply, one in the middle usually can be pulled and disconnected using your hand. I suggest taking pictures before removing the other wires holding the screen to the power supply. At this point, the front plate is removed, and the screws holding the the screen have been removed, wires disconnected, and power supply in view. Best of luck
Nov 10, 2013 | Gateway FPD1960 19" Flat Panel LCD Monitor
Wiring schematic for a upper thermostat
Jan 2013
1) Copy following links for wiring upper thermostat:
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
2) Thermostat must sit flat against tank wall to read correct temperature, and entire opening must be covered with insulation so cool room temperature will not interfere with temperature reading.
Be sure to put cover back on side of tank for electrical safety, and to prevent any possible fire caused by melted parts and overheating.
3) Tighten wires very tight under screw plate, and make sure only copper wire is used, and all wires under plate are same gauge, do not mix stranded wire and solid wire or stranded will become loose.
Only copper under the screw plate and cut back insulation so no insulation gets under screw plate.
http://waterheatertimer.org/images/Burned-thermostat5-143.jpg
4) Add comment and say what you are doing
Jan 23, 2013 | Rheem Water Heaters
Wi-fi is not working..while installing wi-fi drivers ..an error named as qmi module does not exist occured. email id=sidhuharjinder89@gmail.com
Sounds that the wireless adapter daughter board is either loose or failing. First, we need to make sure it is making good contact with the laptop's motherboard. In order to do this, we have to do the following:
1. Turn off the laptop & remove the battery.
2. Look at the compartments in the bottom of the laptop. You should be able to see 2 or 3 areas with small rectangular plates covering them. These plates usually have one or 2 screws holding them in place.
3. Check which one of those plates is the one which covers the wireless adapter daughter board. When you find it unscrew its screws & remove it.
4. Below the plate, there will be a small daughter board screwed to the laptop's motherboard, with 2 thin wires attached to it (usually one black wire & the other is a white wire). Gently, remove both wires using a small flat screw driver to pull them out gently. Don't forget to note down which wire connects to which connection point.
5. Unscrew the wireless adapter daughter board & remove it from its slot.
6. Clean both the slot & the daughter board's terminal connectors using a dry electric contact cleaner. You can purchase it at an electronics store.
7. Leave the slot & the daughter board for a while to dry.
8. Re-place the daughter board back in the slot & screw it to the motherboard.
9. Reconnect the 2 wires.
10. Screw back the covering plate.
11. Put back the battery & turn on the laptop. Check if the problem was fixed.
If this did not fix the problem, you will need to repeat the steps to remove the wireless adapter daughter board & replace it with a new one.
Oct 27, 2010 | Dell Vostro 1014 Laptop Computer
I am trying to remove the HD, so I can connect it to a SATA/IDE to USB adapter. Not sure how to remove the HD.
Hi
thank you for your query
Please do the following
1) Turn the laptop over on its front
2) You will be presented with the bottom of the laptop, the screen hinges should be facing the front
3) In the bottom left hand coner there will be 2 screws, screwed into what looks like a little black plastic cover
4) Remove these 2 screws and using a flat bladed screwdriver open up the plate
5)The hard drive will be located underneath this cover
6)Simply pull the drive to the left or right (depending what side the connector is on), and pull up and out
This will remove the hard drive, reverse the above if you wish to reinstall
I hope this helps
Mar 04, 2010 | Toshiba Satellite M45-S265 Notebook
SINGER CG 550
If the plate is moving up and down eithetr the teth are set far too high pushing the plate up or the teeth are set too far forward, I would go for the first, if the teeth are coming up well above the slot they are too high, they should be set so that when you look alongside the plate you can just see the top of the teeth, you can adjust the teeth by adjusting the screws underneath the machine where the teeth are.
Mar 03, 2010 | SINGER 7470 Sewing Machine
Focus error
You will have to disassemble the unit. 2 screws on 1 side and 1 on the other and 2 on the bottom, pop the back off, being careful of the 2 ribbon cables attached to the rear and unock these cables and remove. 3 screws holding the top circuit board (remove the eye piece first and unplug the 2 cables attached to it) carefully unplug all cables attached to this top board and unscrew and remove (there is one on the bottom of the board that you must flip to unlatch. After you remove that board there is the power board... BE CAREFUL!!! The flash capacitor (the black tube looking unit on the bottom of this board) stores chrge and you WILL feel it if you touch the terminals... it they touch metal you will see fireworks so be careful. unplug the single red and black wire plug and unscrew the 3 screws here You do not have to remove the white plug with the 4 or 5 wires because you can just flip the board over out of the uni.. BE CAREFUL!!. unscrew the 2 silver screws securing the metal plate underneath and remove this plate. now remove the single screw left and pull out the lens assem. Here check 2 places... 1 is he zoom screw (it is behind the long silver panel) and also the focus screw (behind the shorter metal panel. Do one at a time. remove the screws from one of them and carefully lift off the motor plate. for he zoom line to metal ring on the screw into the groove of the lens (Shaped like a V) carefully screw the screws back in bu d ni tighten to tight, leave a LITTLE slack. (1/8 turn from tight). Now for the focus screw, remove the cover and align the ring to encase the top of the V The ring is shaped like < the lens is a > so just allow the rinng on the screw to "pinch" the top of the lens groove. secure like you did the other plate (dont forget to back out 1/8 of a turn) reassemble the opposite of disassembly and you are done... it look hard but it is actually pretty easy... any uestions email me at worldin1@gmail.com
Jun 12, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Clock bulb replacement
Sisters car has the same thing. I don't think they have a bulb to light up the clock. I'm not too sure. I might try again I had to repair the aircon switch before.
How to remove the clock.
You have to remove the center console to remove the clock. (Manual car version)
-Unscrew gear knob.
-Pull out gear shifter cover surround.
-Remove cover plate with small flat blade in little tray aft of the gear stick.
-Remove 2 screws revealed by cover.
-Remove 2 screws 1 on either side of the AFT (not middle) end of the center console.
-Remove aft half of center console.
-Remove 2 screws 1 on either side fwd of air con controls.
-Remove 1 screw underneath ash tray.
-Remove hazard switch and other switch next to clock using a flat blade to pry them out.
-Unclip switches disconnect plugs.
-Remove 2 screws revealed behind switches.
-Take your time to remove fwd console / dash trim (extra screws might be there to take out).
-Disconnect clock plug.
-Remove clock.
Let me know if there is a bulb in there
May 23, 2008 | 1998 Honda Civic
Rice cooker does not work
Any chance you could post a photo? Often these machines have a deflector that reduces the heat applied to the middle of the pan - it sounds as if that is the item you are talking about - there may have been a small ceramic ring or block that the screw went through which would put it a little above the element or a little below the pan base. look in the floor beneath the element for screw holes. Hope this helps - if not please post again, with photos if possible :)
Mar 23, 2007 | Salton RA14 14-Cup Rice Cooker
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
