Question about Samsung 25.8 Cu. Ft. Side-By-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel
I hear a fan sound coming from my fridge
I have a fridge that is only 12 months old and tonight I am hearing a loud purring noise which sounds like a fan. When I open the door the sound disappears. I haven't noticed it until this evening. Which is always when it is hard to get help. Any ideas welcome.
  • Samsung Master
  • 43,501 Answers
Ice is buiding up because the defrost is not working right...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorI hear a fan sound coming from my fridge - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jul 12, 2010
Fridge water sound
This kind of noises produced gas in cooling system.
In the old coolers never heard sounds like streaming water because the compressors were very loud due to high pressures (12 bars or more), which were required for efficient cooling. Today we use more ecological gases which work (from 5 to 6 bars) at much lower pressures, thus compressors produce much less noises and now suddenly we hear sounds that never before heard. Generally speaking noises is lower, measured in decibels.
Dado
Feb 01, 2014 | AEG Freezers
I have an old Frigidaire refrigeator/freezer, freezer on top. Model # FRT18TJHWO. It say manufactured 06-00. I presume that means June of 2000. I have had this for almost two years. A friend gave it...
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 21, 2010 | Frigidaire Refrigerators
My mothers beko fridge freezer making bubbling sound
Sounds like the evaporator fan is doing its job. Nothing to worry about. Good hearing is a blessing all fridges make different sounds some click loud while others gurgle loud. Some pop and snap. Till I got my hearing aids I didn't know mine ran so loud and clicked.
Dec 15, 2009 | Refrigerators
Drum not turning-very loud sound coming frm dryer when turned on
There could be multiple problems with you whirlpool dyer depending on the type of noise you are hearing. If the noise is a low grumble or loud buzzing sound this could indicate a bad motor. Which could explain you not hearing the drum turning. If however you hear a grating or grinding type noise but the drum is turning, this could indicate that something is rubbing or has become jammed inside the blower fan that circulates the air. if this is the case it too may have to be replaced. Also the drum can sometime come off the drum support rollers at the back of the dryer, but this is very uncommon, and only happens if they are very worn or broken. This can easily be diagnosed by a technician and if the motor is fine, will cost little to repair.Hope this helps.
Thanks
Nov 07, 2009 | Whirlpool LER4634J Electric Dryer
Elantra 1.6 1997 Rear suspension noise
did they repalce the upper mounts? sound like that's the problem.
Jun 25, 2009 | 1997 Hyundai Elantra
I have a Samsung RS21DPSM side by side fridge under 2 years old and the other day a loud noise was coming from fridge Sounds like a fan as when you open fridge door it grinds to a stop) compartment and...
There is a design problem with this model. The fridge section is icing over due to a design defect and the noise you can hear is due to the fan on the motor driving against the ice. Eventually the motor will be stopped from running and the fuse will blow in your plug. Contact Samsung and they should replace the defective parts with a fix.
May 11, 2008 | Heating & Cooling
Mfd2561hes Maytag Refrigerator
This sounds like you have a Maytag Ice2O. You need to find out if that cound is a relay/overoad failure on the compressor or the compressor going out. I can say from experience that some of those have a tecumsie comprossor in them and the do tend to fail. If you hear a loud electrical humming sound coming from the compressor and your getting a warm up then you need to record this sound on some kind of sound recorder and call a Whirlpool warrenty certified tech. out to look at it if it's less than 5 years old from perchase date then Whirlpool will pick up the part and labor bill of a compressor installation also check your owners manual for warrenty details. Hit me up let me know.
Feb 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Samsung 25.8 Cu. Ft. Side-By-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel Logo
121 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
