Question about HP Color LaserJet 2600n Printer
Hp 2600 n
Light print on left side of page. All colors.
  • 1 more comment
  • Melissa DP Aug 20, 2008
    How do you clean the scan unit/rollers?
  • terrab Feb 02, 2009
    All of my copies come out looking dirty. It appears, possibly, the drum is dirty, coating my page with a light film.
  • frankhernand Mar 20, 2009
    my hp printer laser jet 2600n is not printing clear copies , it seems to have a film or smudged on paper
  • 34 Answers
OK. This sounds like a bad transfer belt. Does this printer have a lot of use? Do you think you have like 75,000-100,000 copies on it? If so it is very likely.
If you are SURE the fading is on ALL cartridges, then it has to be the transfer belt assembly. (that wide film part on the inside of the front door). You can buy this part, and instructions to replace it are very straightforward. Its not just the film you replace, its a module.
One last hing, if it is only happening on ONE cartridge, then all you have is a bad cartridge. All 4 = transfer belt.
Posted on Mar 24, 2009
Posted on Oct 07, 2010
How do I clean the rollers on this printer. I have print residue on copies.
Posted on Jul 03, 2008
    New Friend:
  • 159 Answers
Clean scan unit
Posted on Apr 20, 2008
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
Why does the 2550n printer not printing fully in the left column
Is the print quality poor on left side for all colors? You may have one bad cartridge. Create a paint document with Yellow, Magenta and Cyan squares on the left side and see if one color prints better than the others. You can also gently shake the cartridges to redistribute toner.
Sep 08, 2014 | HP Color LaserJet 2550n printer + HP Color...
Hp 2600n printer printing light on the left side of the page
clean the scanner & calibrate the printer thre times ur problem will be resolved
Jun 03, 2010 | HP Color LaserJet 2600n Printer
I have problem with the left side of the page - Color faded
This is a common fault on this model. The solution is to strip out the laser scanner unit. The laser scanner can be reached by removinh the back metal cover of the printer and the controll boards behind it. You need to clean the mirrors inside the laser scanner, for this you can use surgical spirits and cotton ear buds.Hope this helps. Any other queries, you can mail me renierfeldtmann7@gmail.com
Oct 06, 2009 | HP Color LaserJet 2600n Printer
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
Hp 2600
It migh be that there is not toner in your cartridges. Try to print test page from windows.
Sep 23, 2009 | HP Color LaserJet 2600n Printer
HP 2600 COLOR PROBLEM
I am not sure what out of position refers to but if it is a setting in the printer this should fix it.
Restoring the factory-set defaults returns all of the settings to the factory defaults. Restore the factory-set defaults
  1. Use the c00317853.gif (LEFT ARROW) or the c00317858.gif (RIGHT ARROW) button to select Service, and then press c00317851.gif (SELECT).
  2. Use the c00317853.gif (LEFT ARROW) or the c00317858.gif (RIGHT ARROW) button to select Restore defaults, and then press c00317851.gif (SELECT). The device automatically restarts.
  3. Hope this helps
Mar 24, 2009 | HP Color LaserJet 2600n Printer
HP 2600 ghosting
It is a massive pain but a solution that worked for me is to run a 'clean' after every card stock sheet. I know it's wicked awful but it actually worked and I had to run 100 times (one for each good color card stock)
First put plain paper in tray 2
Next
Hit left arrow until you get to 'system service' and press green check
Next
then go to 'clean' and press check
Now it should print a clean image without ghosting
May 29, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
1,058 people viewed this question
Ben Johnson
