Question about Samsung SF-560 Plain Paper Laser Fax
Makes clunking sound as the paper is printing out of the fax machine
    Genius:
  • 1,121 Answers
Is some damaged gear, or some losed door
Posted on Jul 12, 2010
Machine not printing sounds like it is and feeds paper thou
Change the ink cartridge first an foremost,
then do a few print head cleans to flush out the blocked nozzles. it may come back after 4 or 5 cleans
good luck!
Jan 15, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
My fax won't print, neither faxes nor copies. The paper goes through & it makes sounds like it is printing but nothing on the paper. The machine says the ink level is 6/8. I "aligned" and...
Though the ink level it said was "6 / 8", when I removed the cartridge to examine it looked bone dry empty to me. I replaced the ink cartridge. It works fine, and reports the ink level as "8 / 8".
Sep 09, 2009 | HP 1040 Plain Paper Inkjet Fax
Borhter 2820 doent print
Typically when a machine asks you to use the bypass tray it does not like the size of the paper you have in the machine.
sounds like a paper size problem, check the paper guides in the machine, make sure they are up against the paper. Make sure the paper size in your printer driver is the same as the paper in the machine.
Failing that, power off the machine, unplug it, let it sit for a couple of minutes, power it back up, this cleares anything in the volitile memory.
Hope this is of some help.
Ed
Apr 26, 2009 | Brother IntelliFax-2820 Laser Fax
Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
Apr 13, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic kx-f100 fax prints and sends a page on 2 pages- too big
it sounds like one of your rollers is not making contact with the paper. either the roller is dirty or you need a new one
Dec 08, 2008 | Panasonic KX-FP81 Plain Paper Fax
Brother FAX-2920 sending-receiving problems
Make sure you are plugged into the LINE port of the fax machine.
Oct 22, 2008 | Brother IntelliFax-2920 Plain Paper Fax,...
Print alignment
Make sure the side guides in the paper cassette are snug up against the paper.
The paper could be whacking a scrap of paper on its way through and skewing.
Sep 26, 2008 | Brother IntelliFax-2820 Laser Fax
SHARP UX 105 Fax machine ....Problem
is this making a screeching, high ptch sound. If so that is normal when sending. as far as the rest yes that is normal.
Thank You,
Mikey
Mar 19, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
How Can I Reprint a Fax?
Here's a trick that I used on the Canon thermal transfer years ago. First take out the thermal transfer unit and roll up the black transfer sheet to the begining of the lost fax. Then reload the paper. Next get a solid black original equal and make a copy. The result you should get a negative copy of the lost fax. Repeat this step until all the faxes are recovered..
May 31, 2007 | Panasonic KX-FC195E Plain Paper Thermal...
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
Samsung SF-560 Plain Paper Laser Fax Logo
50 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
