Question about Refrigerators
I have a kenmore refrigarator and it is about ten years old or more but it has been a good appliance until the water going into the the ice maker and cold water dispenser would not shut off and i don't how bad the leak was but i found the entire freezer frozen over so bad that i couldn't even pull out the racks /dawers in the freezer. What could be my problem?
Water running from under my refrigerator, I think it stop up
Posted on Dec 13, 2008
I have a water dispenser that will not stop. Not clear from the April 20/08 posting what the solution is? What is a water inlet valve?
Posted on Jun 24, 2008
    Genius:
  • 1,073 Answers
And oce maker issue or a water inlet valve that did not cut off one of the two is the issue
Posted on Apr 20, 2008
My kenmore 106.51133210 refrigerator is not making ice
Try filling the ice maker with tap water until the tray is full allow it to freeze turn on the ice maker and if after the water freezes it drops the ice into the ice container then replace the water control valve found at this link below
Water Inlet Valve WPW10341320
If after the water freezes with the ice maker on it does not drop into the ice bin then replace the ice maker itself part number below
Ice Maker Assembly WPW10251076
Thank you
Appliance 911 Sea Breeze
May 06, 2016 | Kenmore Refrigerators
Ice maker quit working. I found water on the floor outside freezer side. This happened after a power outage and the ice maker hasnt worked since
The ice maker is freezing sound like it turning but not dumping and new water is comming in and no where to go except over the top. A new ice maker is around 100.00 Sears had them on sale recently for 49.00 find a used appliance store and maby pick one up for ten or fifteen dollars. You can install it the just plug in and hang by two screws.
Apr 26, 2010 | Kenmore 21.8 cu. ft. Side-By-Side...
Ice maker issues - what to do next?
I have not found Kenmore to do the best with the icemakers; however, you want to make sure that the lever on the side was replaced properly. They have a slot that they need to go into. The other thing that is important is to see if the motor is running on the ice maker. It could be at fault, but if that is the case those units usually are better off replaced as a whole, which runs around $200. You will probably get them cheaper through an appliance dealor rather than going through Sears and there probably is one in your yellow page section of your phone book...hope this helps.
Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker will not produce Ice
Make suer the freezer temp is 5 degrees or lower. If not the ice maker will not operate. Also make sure that you have water pressure at the back of the fridge. If so, you most likely have a bad water valve. It is what your water supply connects to. You can test it like this. Disconect the water line on the fridge side of the valve. Unplug the wires from the valve. Supply 110v to the plug. If water comes out from where you disconected the line, the valv is good. If not, you will need to replace it. If you can't find the answer with this. Reply back and I'll talk you through until we find it.
Please rate this solution if helpful.
Aug 21, 2009 | Kenmore Refrigerators
GE Ice maker water flooding
Dear friend,
ngfam at you service! happy to assist!
Perhaps you should try service!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 29, 2008 | Hotpoint HSS25GFP Side by Side...
Ice maker
Friend,
ngfam1 At your service!
You need service this time !
Sounds like a Thermostat problem!
How old is the ice maker?
If is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 28, 2008 | Kenmore 53642 / 53644 Side by Side...
ICE MAKER ON KENMORES ELITE SS
Friend,
There are a number of causes for this situation!
I would need be hands on to remedy this!
A&E Factory Service
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 25, 2008 | Kenmore 53642 / 53644 Side by Side...
Friend,
A&E Factory Service
1(800) 905-9505
You will be fine
Bless You ngafm1
Ice maker not working
Most likely the motor module and ice maker thermistat needs to be replaced. Look at this link: http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34. It is very helpful for diagnosis and replacing parts.
Nov 11, 2007 | Kenmore 50522 / 50524 Side by Side...
KENMORE REFRIGERATOR
Need a model # ... mostly likey better to just replace ice maker if that old.. 12-15 if same age as ref.
Sep 06, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Refrigerators Logo
205 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
