Question about Fisher and Paykel DD605HSS 23 in. Built-in Dishwasher
F1 error How can you clear an F1 error
    President:
  • 1,382 Answers
The reason for F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorized service center. These problems cant be fixed on your own.
Thank you !!
Posted on Jul 12, 2010
F1 error code
Hi, the F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced....
Jan 19, 2012 | GE Profile Spectra JGBP90 Gas Kitchen...
I got a F1 error code
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced . GENE
Oct 17, 2011 | Kitchen Ranges
Toploader kenmore elite oasis is showing F1 code for error. I do not have an owners manual. What does F1 mean?
Gene
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Stove error f1 kenmore elite model 790.75902990
Aug 12, 2011 | Kitchen Ranges
After 10 minute power failure the Code E1 F1 keeps appearing on display and will not allow me to clear or reset
the error code means that there has been a eprom error. Follow the directions below, if this fails to clear the errror code you will need to replace the control board.
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3.
If you have any further questins please feel free to ask.
Nov 17, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
What does the error code F1 indicate, on a Wolf Oven?
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Mar 24, 2009 | Ovens
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
F1 error
Try turning off breaker for 5 minutes. It happens to me about once a year and this clears the error code.
Aug 24, 2008 | Kitchen Ranges
Clearing F1 Fault
Hi, Dexters Dad,
I cannot help you without the make and model of your dishwasher. Please provide this by posting a comment here. I should get a email from Fixya telling me you posted the comment. Thankyou and looking forward to helping you get rid of the F1 error code.
Nov 23, 2007 | Dishwashers
-F1- is showing on panel
F1 ERROR IS A KEYS STUCK ERROR...If you are not technically sound i advice that you get it replaced by a technician..They keypad is not very expensive..If you want to try doing it yourself then let me know..
Nov 02, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Fisher and Paykel DD605HSS 23 in. Built-in Dishwasher Logo
352 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
