Question about GE GSS20IEP Side by Side Refrigerator
FREEZING REFRIGERATOR The Refrigerator part we have set on 1 the factory setting is 5 and it is still freezing evevrything, what would cause this can it be fixed or does it have to be replaced.
  • GE Master
  • 2,605 Answers
Hello Pam, Welcome to FixYa. In actuallity most fridges whether they are side by side, conventional top mount, or bottom mount, the control for the fridge section is nothing more than a damper which allows or prevents air flow through the fridge section. The thermostat which control the "run time" or actual temperature is the freezer control. It is possible to set the fridge control at "1" and yet still have items feeze because the freezer control is set to "3", "5", or higher. Try adjusting the freezer control to a lower number as well and see what that yields. You may also want to vacuum out your condensor coils under the unit...( unplugging the power cord first of course ;) safety first ) this too can cause items to freeze in the fridge section. Without getting too deep into how it all works I'll just say it effects the entire system negatively. Hope you find this an acceptable solution and can take a moment to rate it accordingly. Thank you for visiting FixYa and please let me know if you require further assistance. macmarkus :)
Posted on Jul 12, 2010
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
My fridge freez in the fridge part
Check your thermostat setting and make sure that it is in the middle of the numbers, that is normal setting from the factory. Example would be if you have numbers from 1 to 9, set it on 5. It will take several hours to stabilize.
Jul 24, 2015 | Refrigerators
Why is refrig so cold its freezing liquids
Good Morning Friend,
I understand that your Frigidaire refrigerator, model# FRS23KF7AB, is so cold that it is freezing liquids inside the refrigerator area. I also see that you have it set on the warmest setting. First, I suggest setting the controls to the factory setting. Secondly, reset your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When power is restored, leave the setting on the factory setting, and give your refrigerator 24 hours to stabilize at the factory setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FRS23KF7AB Side by Side...
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 16, 2012 | Frigidaire Refrigerators
My freezer appears to be over freezing. Is 1 low or high on the setting. The setting runs to 5. Thanks Mark
Don't know what you mean by over freezing ? A freezer should be at 0 degrease, If the selector the selector numbers are from 1 to 5 a recommended setting would be between 3 and 4.
Sep 04, 2010 | Refrigerators
My GE Profile Performer refrigerator is freezing fruits and veget
PUT THE REF. ON 5 AND SET THE
FREEZER ON 2 1/2 AND SEE IF THIS WORKS
Apr 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE GSS20IEP Side by Side Refrigerator Logo
226 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
