Question about Intel Motherboard
Has this board got a clear bios option - Intel Motherboard
    Novelist:
    Champion:
  • 226 Answers
Most motherboards have a set of pins near the BIOS battery which may be labelled CMOS. If there are three pins with a jumper on two of them, then remove the jumper and put it onto the other two pins. Leave this way for a few minutes and then return to the original position. This will usually reset the BIOS. Hope this helps,
www.PuterCare.com
Posted on Jul 12, 2010
Error code 1000-0416 and 1000-0141
These error codes lead me to believe the video card that is on the motherboard has called it to quits. You could investigate how much a logic board for this would be, I found ebay to be a good source. This is not one of those quick fixes it will need to be taken apart. Should you worry about cost, I would be shopping for a new laptop
Oct 03, 2014 | Dell Latitude D610 Notebook
VGC-RB42G flashig power light and won't power
I have had this problem if power is removed by disconnecting the power cord (in cases where nothing else works). To fix the problem:
1) remove the power cord from the back of the unit
2) disconnect the large power connector from the power supply to the motherboard
3) apply power to the power supply
4) reconnect the motherboard power connector
5) turn the unit on
- dedndave
Apr 13, 2010 | Sony VAIO VGC-RB42G PC Desktop
How do i clear the cmos on my asus p5nsli
support.asus
just to clarify, to clear your BIOS, there should be a 3 pin set on your board usually located some where just below your RAM. On the board will be printed something like "CLR" or "CLEAR" move the pin connector, with the power off, from its current position to the middle pin and the open pin. Wait about 15 to 20 seconds and move the connector back to the original position. You have just reset your bios to factory defaults.
Oct 18, 2009 | ASUS P5NSLI (0610839134670) Motherboard
Error message "8601 memory error" on Intel SE7501BR2
Windows is holding ram memory..........try knocking downing page files/storage not used.......use the task manager to manage ram better.......disable the junk? or freeramxp.load the barebones.........<<suggestions)))> solutions of the cuff...check that the ram sticks are OK....for the boards . check the boards. for any damage cracks/leaning caps etc.....for a system not to pass post! well.......is the Motherboard up to it......
Or this might be: "Memory errors status is now read from the BMC. Because this was not done previously, error status bits have piled up in the BMC and the first time you boot with this BIOS you will probably get a message saying all of your memory is bad (POST error 8601). To clear his status, enter setup/advanced menu and select the 'memory configuration' option. Enable 'memory retest' at the bottom of this menu and you will remove the error message. 'memory retest' option will be reset to 'Disable' in the next reboot.
"Remember to Clear CMOS after each BIOS update. Refer to the Hardware Maintenance Manual or Product Manual for procedures to Clear CMOS."
Found it at this link:
http://www-900.ibm.com/cn/support/download/attachment/JJIG-5EB3SZ/59p2195.txt
Please rate me.
Thank you.
Sep 05, 2009 | Intel Server Board SE7501BR2 Motherboard
I want to the bios intel motherboard d845PEBT2 place sent me
First be clear, do you want to update your BIOS & if so then go through this first: To identify your current BIOS version, check the BIOS version string:
  1. During boot, enter the BIOS setup by pressing F2.
  2. Check the Main menu.
  3. The 4-digit number after the '86A' or '86I' is the current BIOS version, as in this example: MQ96510H.86A.1663.2007.0319.1957
  4. Press Escape to exit BIOS Setup.
Important:
  • Update the BIOS on your computer only if the newer BIOS version specifically solves a problem you have. We do not recommend BIOS updates for computers that do not need it. You can view all new BIOS fixes in the Release Notes included on the BIOS download page in Download Center.
  • Before initiating a BIOS update, be sure to read and precisely follow the update instructions. You may wish to print the instructions for easy reference.
  • If a BIOS update process is interrupted, your computer may not function properly. We recommend the process be done in an environment with a steady power supply (preferably with UPS).
  • All images in the examples used in the instructions are specific to certain desktop boards and are for illustration purposes only. You need to select the correct BIOS files for your desktop board.
There are up to six methods of updating an Intel® Desktop Board BIOS to the latest version. The number of options made available for any particular board may vary, depending on drive support and BIOS update file size. You only need to use one.
All BIOS update files for Intel® Desktop Boards are available on Intel(link: http://mysearch.intel.com/corporate/default.aspx?culture=en_US&q=d845PEBT2&category=all&adv=0&value=0&searchsubmit.x=30&searchsubmit.y=12).
If simply want to clear the BIOS then either remove the small battery on the MB, wait for a couple of minutes and replace it. Else close to the BIOS chip look for a 3 pin setup on the mother boar with a jumper on two pins Remove the jumper, wait for 10-20 seconds & replace it. That will clear the BIOS.
A word of caution, do not update the BIOS if your PC is working properly. Do it when prompted to,during installing a new software or hardware this message will pop up on the screen.................sodeep
May 15, 2009 | Intel Desktop Board D845PEBT2 Motherboard
I am getting 1 long beep and then 6 short ones
Hi canturob,
When a system reports a check sum error the bios is telling you the information stored from the last working boot does not match the current settings stored in the bios. Please power down your MSI system, unplug the power cord. Open the case & clear the bios. Location of JBAT1 on page 3 in manual.
Clear CMOS Jumper: JBAT1 page 10 in the manual. Remove the battery/cmos. Check it's voltage with a volt meter. It should test to 3volts DC. Anything less & the battery needs to be replaced.
While in the case re-check all data cables & power cables for good connection.
The MSI board uses the Award bios. Your current beep code of 1 long & six short is not a common beep code for the Award bios. See bios beep codes here: http://www.bioscentral.com/beepcodes/awardbeep.htm
If the battery checks out ok, you may need to update the bios. Go to MSI: http://global.msi.com.tw/index.php?func=downloaddetail&type=utility&maincat_no=1&prod_no=205
To update your MSI bios (Option only if bios clear fails to resolves the check sum issue).
Good luck canturob!
Mike
Dec 03, 2008 | MSI PM8M-V Motherboard
Initial configuration
OK. Found something interesting. There is a little red box with 10 switches on it. The box is an inch long and half a centemetre wide. Each switch is labled in sequence; 1, 2, 3, etc.
There are little charts or tables or whatever on the mainboard that describe what each switch can do.
This one say's:
CLEAR CMOS...............SW1-5....ON
CLEAR PASSWORD........SW1-4....ON
KEYBOARD POWER ON...SW1-3....ON
BIOS CRISIS RECOVER...SW1-2....ON
Dec 11, 2007 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
M925 v7.3...Bios problem...ethernet option no available
For the M925G I can find a V8.0 and v9.1b motherboard on the PC Chips web site but not a v7.3. At any rate this manual clearly shows there should be an option to enable or disable the Ethernet port on the BIOS Features Setup Page near the bottom. If the option is not there and I would be more inclined to think that the wrong firmware may have been flashed to your board. You might try downloading and flashing the BIOS update again, making sure the checksums match when the procedure is complete. By the way the link to the manual I?m referring to is here: http://www.pcchips.com.tw/PCCWeb/Products/ProductsDetail.aspx?MenuID=0&LanID=2&DetailID=255&DetailName=Manual.
Jan 02, 2007 | PC Chips (M925G) Motherboard
Bios reset
As another option you could try resetting the jumper. Some boards save the password regardless unless the reset the BIOS by using the resetting jumper. Refer to the motherboard's manual for further information on how to do this.
Oct 10, 2006 | Acer (ACERMOTHERBOARD)
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
