Question about Toshiba E-Studio 161 Copier
I need to replace a maintenance kit - Toshiba E-Studio 161 Copier
  • 31 Answers
Go to google.com and type in mainteance kit for the toshiba e-studio 161 copier and you will see alot of vendors that sell it. jaime
Posted on Jul 16, 2010
Install maintenance kit
The Maintenance kit is a supply you can order and replace without a technician. Look for a door on the right side of the machine toward the middle. Open it and remove a light orange assembly. This is the Maintenance Kit and is what needs replaced.
113R00736 Maintenance Kit, Standard
604K53810 Maintenance Kit, Extended
Apr 24, 2013 | Xerox Phaser 8860MFP/D - Multifunction -...
Xerox 8560 displays replace incorrect maintenance kit
Was this a new maintenance kit? If it was new, try putting the old one back in, if it reports the same message, the pivot plate will more than likely need replacing. If it displays the original message i.e, replace maintenance kit, then the fault is with the new maintenance kit. Do check you have been sent the correct maintenance kit for your machine, part number should be 108R00675 for standard and 108R00676 for the extended Phaser 8560 printer and Phaser 8560MFP kit.
If it is the original maintenance kit and the error just appeared, as I am assuming you will have already tried re-seating it, the problem is likely to be the pivot plate again.
Hope this helps.
Jan 22, 2011 | Xerox WorkCentre C2424DN All-In-One Laser...
Need to print but the maintenance kit is late
No. That maintenance kit has a chip attached to it. That will reset the machine, It is just a white roll impregnated with silicon to clean and maintain the surface on the drum.
It will take replacement of the kit to reset the machine.
Oct 06, 2009 | Xerox Phaser 8500/DN Printer
8560 DN Replace Maintenance Kit
the maintenance kit keeps your melted crayons from sticking to the roller. You know the smell... and no you need a new one.
Sep 15, 2009 | Xerox Phaser 8500/DN Printer
80 scheduled maintenance
This issue is just like changing your oil or the timing belt on your car. If you don't fix it correctly it leads to other problems. So, be warned. :+)
Here's what the Lexmark KB says:
On the Lexmark T520/522 series printers, we recommend that the maintenance kit be replaced after every 250,000 pages. If possible, an authorized service technician should replace the maintenance kit parts on these printers.
On the Lexmark T620/622 series printers, we recommend that the maintenance kit be replaced after every 300,000 pages. The maintenance kit parts for these printers are customer-installable, but some dismantling of the rear area of the printer is involved.
Note: The maintenance kit may need to be replaced more often if the customer is running heavy media (like card stock or labels) through the printer.
It is possible to clear the maintenance error message without replacing the kit. The printer will still operate, but some print quality problems may arise. However, this is not recommended as the message serves as a reminder that maintenance is due. If the printer is under warranty, the customer has to purchase the maintenance kit and have it replaced in order to keep the warranty active, although the on-site replacement itself may be covered under the warranty.
The parts that make up the maintenance kits are:
A fuser unit
A transfer roller
A charge roller
To find the part number of the maintenance kit needed for your printer, see Printers / Maintenance kits.
Clearing the maintenance message
To clear the message, you will need to go into the printer's configuration mode. Do the following:
  1. Press and hold the SELECT and the RETURN buttons as you power the printer on.
  2. Hold the buttons for six to eight seconds after turning on the power, then release them. (If you receive the maintenance message, press the Go or the Select button to continue past it.)
  3. Now, press the right Menu arrow until you see RESET MAINT CNT.
  4. Select this. You may need to press the Select button again. The printer display should briefly flash SAVED.
  5. Power the printer off and then back on in the normal way. The printer should now power up normally.
  6. If it does not and the error returns, repeat the above procedure.
Jun 11, 2009 | Lexmark T522 Laser Printer
Need Instructions on Maintenance Kit
Please let me know what are the other parts you are trying to install.
Also, installing a maintenance kit is not a customer replaceable part.
Aug 22, 2008 | HP LaserJet P2015dn Printer
8550DP Maintenance Kit
First of all make sure it is the right kit. The part numbers for teh 8550 and 2424 are very close, one ends in 675 the other in 657, so they have been known to be mixed up.
then here is the documentation..
Problem:
The machine displays the Replace Maintenance Kit after the Maintenance Kit has been replaced.
Cause:
There may two causes for this issue.
  1. The machine does not recognize that the Maintenance Kit was removed. This would likely be caused by a defective Drum Maintenance Pivot Plate.
  2. The machine corrupts the CRUM on the new Maintenance Kit. This may be caused by a defective Drum Maintenance Pivot Plate or IO Board.
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix.
  1. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message does not change to "Maintenance Kit Missing," replace the Drum Maintenance Pivot Plate and install a new Maintenance Kit.
  2. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message changes to "Maintenance Kit Missing," replace the IO Board and then install a different NEW Maintenance Kit. If the problem persists, replace the Drum Maintenance Pivot Plate and install a different NEW Maintenance Kit.
Apr 18, 2008 | Xerox Phaser 8550DP Printer
We have a Phaser 8560 Printer and we are getting the message "maintenance kit low" message. What does this mean and how do we fix it?
This will require servicing:
The maintenance kit contains a maintenance roller that keeps the surface of the Imaging Drum clean and oiled.
NOTE: Order a new maintenance kit when the Display Screen displays a message that the maintenance kit is low. Replace the kit when the Display Screen prompts you to replace the maintenance kit. Both a Standard Maintenance Kit and an Extended Maintenance Kit are available for the Phaser 8550 and 8560; however, only a Standard Maintenance Kit is available for the Phaser 8500. An Extended Maintenance Kit will not be functional with the Phaser 8500.
WARNING: The printer's interior may be hot! Do not touch the hot surfaces.
Once you have the part: instructions:
  1. Open the door on the right side of the printer.
  2. Grasp the maintenance kit (labeled A) from the maintenance kit slot and pull the kit completely out of the printer.
  3. Insert a new maintenance kit and push the kit completely into the maintenance kit slot. Follow the illustrated instructions included with the maintenance kit for full installation and disposal information.
  4. Close the door.
This will be on the right side of the printer.
This will need to be replace every 10,000 sheets of paper.
  1. Close the door.
Apr 03, 2008 | Office Equipment & Supplies
Maintanance kit replace
Problem:
Cause:
ETI v1.3.20.0 610606.Replace Maintenance Kit Message after it Has Been Replaced 2007-11-18 21:37:39
Mar 30, 2008 | Xerox Phaser 8400 Laser Printer
Replacement of the maintenance kit
I need more info or service program for reset sistem infomation (replace maintenance kit) on front panel,
Jan 17, 2008 | Ricoh Aficio AP600N Laser Printer
Toshiba E-Studio 161 Copier Logo
104 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Adorjani Laszlo
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
