Question about Linksys Wireless-G Broadband Router
I am trying to have internet running to the modem then have 2 ethernet cables running to 2 different computers.
    Genius:
  • 1,121 Answers
The modem needs a router, to control internet flow. is the only way to correct use. the alternatives is confusing and is always faling on internet demand as continuos flows of info.(downloads, email,browsing,...)
Posted on Jul 12, 2010
I have the rca dcm425c modem wired to my mac in my office. I want to use google logitech tv in my other room with my big screen tv. I was told all I needed to add was a router that I would hook up to my...
USB is NOT RJ45 connectors. They are very differant as in water and bar of steel.
RCA DCM425 Digital Cable Modem eBay
Read backside cable connections. "ETHERNET" connect to router "Internet" connection. Plug ALL devices into "Ethernet" dump USB cable and store away. USB may shut down Ethernet connection while connected.
May 24, 2017 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
My internet doesn't work
Plug a different computer into your cable-modem or DSL-modem, to see if that computer can successfully use the modem to access the Internet.
Try a different Ethernet-cable between your modem and your computer, to see if that fixes anything.
Click Start
Click Control Panel
Click Network Connections
Under the "Local Area Connection" icon, do you see "network cable unplugged", or "disabled" ?
If so, connect the cable, or right-mouse-click on the icon, and choose "enable".
Dec 07, 2010 | E-Machines eMachines Desktop PC
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
I cannot figure out how to hook up my Belkin Wireless Router. I've tried plugging different cords in different spots and all that jazz and I just can't get it. I got this router from a friend and do not...
First,power down your computer and disconect the power cable to the cable modem.
Install Ethernet cable from the WAN/Internet port to the Cable modem's WAN port.
then install an Ethernet cable from port 1 to your computer. you can use ports1,2,3,4 for different computers.
Then power up the cable modem, then your computer. You should be able to get on the net.
http://www.google.com/#q=installing+a+router&hl=en&prmd=iv&source=univ&tbs=vid:1&tbo=u&ei=UJXgTIWhN8Wt8AavlOjEDw&sa=X&oi=video_result_group&ct=title&resnum=4&sqi=2&ved=0CCkQqwQwAw&fp=e15567a87ae860c4
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 15, 2010 | Computers & Internet
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Belkin router can't connect to internet
    This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
    You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
    Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
    Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
    Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
    May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
    Where does the router plug in to?
    1. Plug in internet "from cable modem, dsl modem" via ethernet cable usually its blue and on the back of the router or it will say wlan.
    2. Run ethernet cable from router to ethernet connection on computer
    Nov 21, 2009 | 2wire (1000-400108-001) Router
    Ethernet light blinks no Internet
    Serveral soultions to try and they are at no cost to you. First, try re-booting the modem. Your modem stores cache just like a computer does, and it can build up on you. I myself unplug mine about once a week.. Two, in the control panel under Internet Opetion under browser history click on delete and confirm the delete, this will delete your temp. files. You might have exceeded the amount of cache allowed by windows. Finally make certain that you have ipx, and spx protocol installed on your comuter. If this doesn't help, I would get a new modem from your isp, more than likely it is bad. I know verizon modem are good for maximum of 2 years and average 1 year. I would recommend westell 6100 G moem and get a wireless router to go with.
    Oct 07, 2009 | Westell Wirespeed LiteLine 6100...
    The ethernet light won't turn on my modem anymore
    hi...
    try to check the ethernet adapter on your computer...if the ethernet cable works fine with the other computer and the other one does not, then probably, the NIC CARD or ethernet adapter is defective...i advise, if you have someone or a technician or a friend who knows how to check...then you can do such,..or if it's a laptop..then youn can bring that to any computer stores and they have technicians there to check freely your case,k...
    hope i give you something that may help a little with your concern....
    happy new year!!!!!
    Dec 31, 2008 | Computers & Internet
    Linksys Wireless-G Broadband Router Logo
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
