Question about Fisher and Paykel Dryers
I have just taken the circuit control board out of a Fisher & Paykel Clothes dryer 427547- D ED55/56 Mk2 Dryer and I can see that a resistor is blown. The number written below the resistor on the cicuit board is R203, as it is blown I cannot work out the resistance as I cannot see the colurs, can anybody tell me what it is?
  • 686 Answers
SOURCE: Dryer is working but not heating up or drying clothes
bad heat element
Posted on Feb 20, 2009
  • 27 Answers
SOURCE: ED 56 FISHER AND PAYKEL WILL NOT START
could be the door interlock is not functioning therefore prventing the start
Posted on Mar 11, 2009
graemevm
  • 519 Answers
SOURCE: fisher and paykel clothes dryer wont turn with clothes in it.
Hi
Most dryers work with a belt around the drum. Either the belt is stretched and needs replacement or there may be a belt tensioner which needs adjustment to tighten the belt.
What is happening in your case is that the belt is slipping on the drum as it is too loose.
Best wishes,
Graemevm
Posted on Jun 18, 2009
TheMobilian
  • 8220 Answers
SOURCE: Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Posted on Sep 08, 2009
SOURCE: Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Posted on Nov 08, 2009
Fisher Paykel Dryer Fault Code 22 Info
That is a fault for the "Door Actuator Open Circuit". You may have not had the door closed completely and when you opened the door to check it out, you closed it completely. Another possibility is the sensor module is going bad.
Feb 10, 2012 | Fisher and Paykel DE27CW1 Electric Dryer
How do I turn the beeper off on my Fisher & Paykel auto clothes dryer
From what I see unfortanetly no..is the short answer, they utilize it for warnings in their system as well. You could try contacting them directly, but after reading all their dryer manuals http://www.fisherpaykel.co.nz/customercare/userguide/index.cfm I could not find any way to do so. I will continue to look for a way however this is what I am seeing currently.
Dec 27, 2011 | Dryers
We bought this dryer the year Fisher and Paykel introduced it in America.(probably 2005??) It has had one problem before and that was fixed by a technician. Now the dryer at the end of the last cycle had...
Hi Lynda,
I am inclined to think that you have a faulty control board. Moisture from the dryer does tend to corrode the PCB (circuit board) and you end up having irregular faults.
Get your husband to unplug the dryer and then remove the screws from under the display/touch panel. Gently remove the display panel exposing the control board behind it. Note the wiring position which is connected to the board.
Detach the board from the plastic panel and physically inspect the boared for signs of corrosion or dry solder joins. Note there are two boards cased together (Display and Control PCBs). The part is sold as one unit.
Ash
Sep 13, 2011 | Fisher and Paykel DEGX1 Electric Dryer
I have a fisher & Paykel electric dryer. D-DE62T27D that works but won't dry. Any solutions? Thanks Rick
Disconnect the power source to your dryer before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Dryer heating elements come in various shapes and sizes. They are all strung with a coiled wire made of a nickel and a chrome alloy. This wire receives, but resists, a controlled electric current and as a result, the wire heats up. The heat produced is used to heat and dry the clothes in your dryer.
Once you have gained access to your dryer's heating element, set your multimeter to the R x 1 resistance scale. Touch each meter probe and to one end of the element. If you receive a reading of infinite resistance, then your heating element is no longer functioning properly and you will have to replace it.
Jul 12, 2011 | Fisher and Paykel DEGX1 Electric Dryer
FISHER PAYKEL WASHING MACHINE FAULT CODE 56 DOES ANYONE KNOW WHAT IT MEANS
Error code 56 is mostly the motor controller, SD11 & SD12 brown boards, 3 x 332k resistors near the small transformer go low & need replacing with a 1 meg Ohm resistor will fix the problem.
May 22, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Auto dry not cutting off when clothes are dry
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem. Your problem should either be dirty or bad connections with the contact continuity plates, the chrome things under the lint bucket or the control circuit.
Oct 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My Fisher Paykel dryer DEGX2 WAS TAKING LONGER AND LONGER TO DRY CLOTHES AND THEN JUST STOP DRYING-DOESN'T GET WARM. THE HEATING ELEMENT WAS REPLACED ABOUT 7 MONTHS AGO. IS THERE A RESET BUTTON IN THE...
Hi.
There is no reset circuit.
Parts that must be tested are high limit thermostat and timer board.
The timer board is replaced if it is visibly faulty, or if there is no problem elsewhere.
The high limit located near to the element is tested reading impedance with a multimeter set at Rx1. If there is no continuity , the thermostat must be replaced.
Before testing parts check the lint filter, and ensure that air ducts are clean.
Regards.
Nov 13, 2009 | Fisher and Paykel DEGX1 Electric Dryer
My fisher paykel DEGX1 won't heat up. everything else works fine.
If you have the same I do then it's the circuit breaker on the heating element. You have to take the front of the dryer off: Two screws on the top under the caps. Then lift the top alittle and you'll see the two screws on the front top sheet metal. The front then can be removed by pulling each side out and forward. The orange button is all the way at the bottom. Push and you'll hear it click.
Mar 05, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Open Questions:
Dryers Logo
122 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
