Question about Dell Dimension 4600 PC Desktop
Display shows only blues and yellows
Before leaving for vacation I shut down my computer and unplugged the power strip. When I turned on the computer again, I found that the color on my monitor is only displaying blue and yellow. I did a test of the monitor as advised by Dell, and it has red, yellow, green, white and blue. So I can't figure out how to get full color back. I've tried adjusting it by use of the buttons on the monitor, tried via Display in the Control Panel etc. but nothing is helping. Any suggestions?
  • 1 more comment
  • kristenb Apr 20, 2008
    There had been a power outage in our home at some point, but since I'd unplugged the power strip I didn't think anything of it. I am wondering if it isn't an XP problem rather than monitor problem, as the test I performed on the monitor (with the color box floating around the screen) showed colors red, green, blue, white etc just fine.
    THANKS! The problem is solved!! I hooked the monitor to my husbands computer and through troubleshooting through Vista discovered that the VGA cable (blue connection) had gone bad! My neighbor happened to have one for us and voila I am back in color. Not sure what fried that cable, as the entire computer had been unplugged while we were away. But my computer tech neighbor did say that happens frequently. If anyone else has this issue, the problem certainly can be solved inexpensively by replacing that cable. Thanks for the replies!
  • Kaitlyn Jones
    Kaitlyn Jones May 11, 2010
    was anything suspicious when you returned home?
    President:
  • 2,712 Answers
Hello kirstenb,
First, make sure that the cable between monitor and computer is secure. If possible,try using a different cable.
Secondly, try to reseat the video card or use a different slot. It could be that the card has become loose. Make sure to clean all the dust inside first; you can use a can of compressed air to do this. If you do not know how to reseat the card or open the cabinet, get someone in the know to do this for you. The video card will be the card to which you attach the monitor cable.
Lastly, try to download the latest driver for your card from the manufacturer's website and reinstall the new driver.
If all this still does not work, it could be a problem with either the card or the monitor. Get a local competent technician to check it for you. Hope this helps...
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FIXYA rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 20, 2008
  • Swilin Sampson
    Swilin Sampson Apr 20, 2008
    Great that worked out, kirstenb..Glad I could help.
    I told you the first thing to do was check the cables :)
    I would be grateful if you could take a moment to close this problem by assigning me a FIXYA! rating as a show of appreciation ;)
    Cheers and have a good day,
    IrishDruid
    Problem Solver:
  • 30 Answers
Actually, if you have not noticed, electrical things tend to act weird during thunder and lightning storms(power outage?) For instance, my little sister has a bear with a voice box that sits right up against her wall and when ever theres a thunder storm it goes off. (Scare me to death ;) ) But perhaps something like this happened to either the PC or the monitor. OR Does is the monitor tinted yellow, blue, etc...? Because that is a connection problem try screwing the cable from the PC air dusting the port and the end of the cable and making sure it id firmly screwed back in.
Tried to reset DMPBD79last step it shut off it wouldnt turn back on I just get a blinking redlight.
This is for a diff. model but give it a try, they may be diff. #'s showing up then what pops up on screen then is listed below.
  1. Remove any disc from the drive and switch the device to stand-by
  2. Press and hold [OK], [BLUE] and [YELLOW] simultaneously on the remote control until the device turns on and shows "00 RET" on the display
  3. Repeatedly press [RIGHT] on the remote control until the device shows "08 FIN" on the display
  4. Press and hold [OK] on the remote control for at least 3 seconds -> The device will reset itself to factory condition and show "HELLO" on the display
  5. Press [POWER] button on the remote control -> The device will shut down
May 02, 2016 | Panasonic Televison & Video
Acer aspire one will not power on
Sub out the ram memory one at a time, one bad memory stick will cause this problem.
Jul 03, 2012 | Acer Aspire One PC Notebook
I wanted to make 10 copies of a document using the glass. The printer froze at 3 of 10. I pressed cancel, the display showed canceled for almost an hour. I then pressed the power button now the display...
It is my pleasure to guide you.
Is it hooked up via USB or parallel?
If parallel, then the computer must be turned off to hook it up. If USB, it does not matter if the pc is running to hook up.
One thing that you can count on, it rarey hurts to shut down/unplug a printer. Sometimes that is the only way to reset the software and trouble shooting software in the printer. I use to take care of pcs/printers and sometimes did just that.
Leave the printer unplugged (if USB) and reboot the pc. Then plug it back in again, letting the OS cycle the addition of the printer.
If parallel, shut down the pc. Unplug the printer and reboot and shut down completely. Plug the printer in again and reboot.
Good luck and please post back that you are successful, giving thumbs up, or so I can be more help.
Jun 10, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
When i press the switch to start up the blue hard drive light comes on but not the yellow power light, it will not boot up and after a few seconds the blue light goes off and the no signal sign comes...
Strip the system down to the absolute minimum: unplug all of the drives, disconnect the speakers and any USB devices, and remove all but one memory module. If the system starts (of course it won't boot), one of the items you removed is defective. Add the parts back one at a time until you have a failure.
If it still doesn't start after the strip-down, swap the remaining memory module with another one. If that doesn't do it, try putting a video card in and using that instead of the on-board video (you have provided no details about your hardware, so I'm guessing at your configuration).
Caution: shut down the computer and unplug it before adding or removing any internal parts to avoid damage to the motherboard or parts (every time you add back a part). Do not touch any circuitry with your fingers; handle memory modules only by the edges. Failure to observe this precaution may cause electrostatic discharge damage to the parts (even if you don't feel the shock when you touch it). You can reduce the chance of damage by making sure you have bare skin touching the metal case of the computer while you work on it. It is not necessary to turn off the computer to plug in speakers or USB devices or remove them.
If the system will not start when it is stripped-down, either the power supply or the motherboard is bad.
Jan 02, 2011 | Computers & Internet
Normally, when the monitor is switched on, a blue screen is shown momentarily, with 'acer' right in the middle, before it shows the image that the computer is sending. But now, the screen does not show...
It sounds like either a bad signal input , possibly from a loose plug on the cable from the PC or bent pins on the plug / the video graphics card in the PC/ or the settings on the monitor need adjustment. Use the OSD (On Screen Display)
First check to make sure both ends of the cable from the PC to the monitor are not damaged and are seated good & tight.
If those are fine then unplug both cables from the monitor & leave unplugged for 10 minutes or so to see if the screen has an automatic reset.
If that does not work then use the monitors OSD (On Screen Display) to adjust to default settings. If that does not work, plug the monitor into another known good PC.This will tell you right then if its the monitor or "Your" PC.
__________________________________________________________
Here is your manual if needed
http://www.retrevo.com/support/Acer-AL1717-Monitors-manual/id/719ag107/t/2/
Oct 09, 2010 | Acer AL1717 17" LCD Monitor
I can't seem to set the display of my WHIRLPOOL VT255WH (VT-255-WH) microwave to show the current time. I had unplugged it before going on vacation and now have plugged it in.
Please switch off your power connection and try to get access to the control unit. Since you had mentioned that the set was unplugged while you went on vacation, it is possible that some moisture/insects/ condensation have cloggged on the control booard and the back up memory maybe down. So check the board and clean well use some petrol dipped with a ear bud and use a brush to clean. Use a hair dryer to warm up the circuits before you fix this back, make sure you do not damage the display with excessive heat. So fix back and allow the power to be on for several hours before you try to set the clock . If must work for sure but leave it on. Hope you try and get this right. Good day
Aug 16, 2010 | Kitchen Ranges
Will not turn on.... have been on vacation for 3 weeks with all power off from strip plug. the on button does not initialize monitor. plugs are ok and all others work on strip plug including the computer....
Try This :
Unplug the power cable from the Unit
Keep on tapping the power button for next 1 min
Also press and hold it down
Then plug in back the cable and check this should work
Regards Soumajit
Mar 13, 2010 | Acer AL1912 19" LCD Monitor
Difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Jun 27, 2009 | Computers & Internet
Laptop is not responding
1) Try holding down the power button for 5 secs. Let go and try to turn it on again. This is a signal that bypasses the OS and tells the motheboard to power down. This helps if the computer is actually still running but with no display.
2) If that does not work, unplug the computer, remove the battery and leave it at for 1 min. Replace the battery, plug it in and try to turn it on again. Corrupt data in RAM can cause problems like yours, this clears out the RAM so you start fresh.
If the above did not help it might be your motherboard. A bad motherboard does not usually damage your data. You can remove the hard drive and put it in a portable hard drive enclosure (about $30), the enclose plugs into a USB slot in a working computer and shows up as another hard drive.
Check to make sure your power is ok, I ran into a situation where the power bar was accidentally turned off and then the battery ran down.
Jan 08, 2009 | IBM ThinkPad 600X Notebook
On the MSI 7145 v2 motherboard, some cables came loose
Hi, sounds like the case switch is stuck, leave the cable from the switch off and try to bridge the pins out, the after the computer is running try shut down by bridging the pins again, if this works clean or replace the switch. Regards mistyman
Sep 25, 2007 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
91 people viewed this question
Alun Cox
