Question about Classic Accessories Sigma 509 Bc509 Classic Bike Bicycle Computer
SIGMA BC509 trip timer problem
The clock on my SIGMA BC509 runs fine, but the trip timer is way out. Around 15% less than the actual clock time. What is the problem?
    Problem Solver:
  • 10 Answers
No problem, what it is doing is recording actual pedaling time. Say you go out for a twenty mile ride and take two rest stops. You were gone for lets say from 12:30pm to 3pm, 2.5 hours total, but trip time shows 2hrs10min. If you took two breaks of 10min each, there's the difference. My Bontrager computer counts trip time based off input from the speed sensor, if I'm not moving it doesn't count trip time. I beleive that is what is happening.
Posted on Jul 14, 2010
Intermatic T104 timer wont turn pump on,despite being tripped
If override lever snaps back and forth crisp, and turns pump ON-OFF, then timer switch is good.
Try installing new trippers. The trippers wear down and start to slip over the trip lever.
If pump does not turn on-off with override, look for loose wires at breaker or pump.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 06, 2012 | Hardware & Accessories
When I connect the 240 volt motor directly to hte GFCI breaker it works fine, however when run throough the time clock, when I turn on the breaker, it trips the breaker
You have T104 timer that controls 240Volt motor.
You have 240Volt GFCI breaker.
GFCI to motor works fine.
GFCI to timer trips breaker.
Either timer is wired wrong, or ground fault in the timer.
Open following links to review wiring:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/images/T-104-control-240V-Load4-35.jpg
1) Make sure clock motor wires are on terminals 1 and 3, and that clock motor is 240Volt WG1573 and not 120V WG1570
2) Try connecting GFCI hot leads to terminals 1 and 3 and don't connect wires to motor.
3) Click manual override both directions and see if a short appears.
4) Remove ground wire from timer but leave power connected. Test metal timer body to ground wire to see if there is power flowing to ground.
5) Unscrew clock motor from body, and make sure clock is not touching metal body, repeat test to ground to see if clock motor is bad.
6) Remove small white wires that power the clock, to test if clock is shorting. Replace WG1573 if clock is bad.
7) Connect 240Volt motor to terminals 2 and 4. Click override back and forth. Then reverse wires to 4 and 2.
Jun 24, 2011 | Intermatic T104 24h 208-277v Mechanical...
How do you turn it off
My Sigma turns itself off if the wheel stays motionless for a time.
Jun 18, 2011 | Classic Accessories Sigma 509 Bc509...
My t104p turns on/of every 15 minutes. works fine manually but will not work with trippers.
Problem is not clear.
What is turning on-off every 15 minutes? The clock motor? Or the Load controlled by the timer?
If the dial is not rotating and keeping good time, then replace Intermatic T104 240Volt WG1573 clock motor
If the Load is turning on-off every 15 minutes, then that sounds like possible electrical short and not the timer, but more information is needed. Add a comment.
Open following link for troubleshoot checklist:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 07, 2011 | Hardware & Accessories
I have a new Intermatic T104 P201 timer. When the manual switch is on, the clock runs normally and is able to trip the switch to off using the trippers. once the it is tripped off, the clock stops...
I suspect the wiring to Load is reversed with wiring from circuit breaker.
Upvote the help.
May 30, 2011 | Intermatic T104 24h 208-277v Mechanical...
The timer works but gets "stuck" when it comes to the ON time. it will continue this cycle if i force it to click past the ON time; but when it comes around the next day it sticks again.
You posted under malibu power pack.
When clock motor gets weak, it can no longer push timer dial past the trip point switch.
Right now the clock motor is overheating and will stop functioning.
This timer does not have replacement clock motor, but comes with 5-year limited warranty.
Buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
For complete troubleshoot, trippers, manuals and warranty information:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Add a comment for more free help
Also take advantage of fixya expert assistance live.
Apr 14, 2011 | Malibu ML900TW 900 watt Power Pack Timer...
My intermatic timer won't trip back on
I don't think the timer runs on 240 volts does it? You can switch 240, but the timer uses 120 volts to run. You might check the connections and timer clock rating more closely. Also, the 'off' & 'on' trippers are different, make sure you use the right one.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 26, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Tork timer 1103 will not trip off unless lever is
The timer should have came with a dark and light colored tabs. they must be put exactly on the rail that goes in a circle with the time on it.
Apr 12, 2009 | TORK Digital Interval Timer Ssa100r-24
Classic Accessories Sigma 509 Bc509 Classic Bike Bicycle Computer Logo
322 people viewed this question
Top Classic Accessories Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Classic Accessories Cycling Expert? Answer questions, earn points and help others
