Question about Topeak Joe Blow Ace Floor Pump
Need parts diagram for joe blow floor pump
Pump will not seal after pumping air into tire, air pressure pushes back on pump. Two parts came out of pump need to know how they go back.
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: The pressure gauge on my
http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html
  1. Rotate the wheel so the valve is resting just above the floor. Remove the valve cap.
  2. Unscrew the locking nut on the valve stem. Quickly press down the stem to loosen the seal. You should hear air escaping when the stem is pushed in--if you do not, loosen the nut and try again.
  3. Press the pump head onto the valve and flip the locking lever to make a seal. You'll hear air escape, but it should stop after you've locked the lever. If air continues to leak out, remove the pump head and reattach it.
  4. Make two pump strokes and listen for air moving into the tire. If the pump handle becomes hard to press down after only a few strokes, or if the pressure gauge elevates extremely quickly, remove the pump head and repeat Step 3.
  5. Inflate the tire to its recommended pressure. Remove the head by unlocking its lever and quickly pulling it off the valve stem. Secure the valve's locking nut and cap.
Presta Compressor Toolwww.prestaflator.comInflate Road or Mountain Bike Tires Accurately in Seconds!
Read more: How to Inflate a Bicycle Tire With a Presta Valve ' eHow.com http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html#ixzz1Brv5VfAX
Posted on Jan 23, 2011
Impossible to Pump
If I understand, you are tying to fill a tire with an air pump.
I would start by seeing if the pump works without attaching it to the tire nozzle. Is it easier to push now? I wouldn't expect the pressure gauge to go up at this test, as there will be no pressure built up. If you are still having trouble, the pump might be malfunctioning or blocked by something.
If all works well, make sure you push the hose adapter firmly on the tire stem to open the air flow, using any locking mechanism to secure it down. It can be tricky to get this on correctly.
Apr 26, 2014 | Topeak Joe Blow Sport Pump
I can't get my pump to pump air in my daughters tire. This is my first time using a pump where I have to set the pressure. What do I set the pressure to in order for it to pump the air in the tire?
You don't have to "set the pressure", that knob is just for your own reference.
Most problems of this sort are due to not getting a good seal with the tire nozzle. Here are some steps to help you along.
1. put the bike on a flat surface
2. spin the wheel so the nozzle is facing upward
3. put the pump end on the nozzle with the lever down (this is a common mistake as older pumps had to start with the lever up)
4. Push the end down on the nozzle and pull the lever up
5. If you hear air escaping, then hold the pump end on the nozzle for the first few pumps.
6. pump it up till its a bit hard but be careful you can pop it.
check out the video for a but more info and good luck!
Mar 17, 2011 | Zefal Bicycle Air 1 Floor Pump
When using my new Serfas floor pump air doesn't go into the tire. The line pressurizes but nothing in the tire itself.
Do you have the connection to the tire valve tight? You must have the connector pushed completely down and the locking lever pushed in the down position. Be sure it can not be pulled off of the valve while pumping up the tire.
Feb 12, 2011 | Serfas FP50 Floor Pump
The pressure gauge on my Topeak Joe Blow Ace floor pump is not working. The pump works fine. How do i take the pump apart and what should I be trying to do to repair?
Jan 09, 2011 | Topeak Joe Blow Ace Floor Pump
HOW DO I PUT AIR IN A MOUNTAIN BIKE TIRE WITH A PRESTA VALVE WITH A TOPEAK MINI MASTERBLASTER PUMP.
Nov 02, 2010 | Topeak Mini Master Blaster
I have just purchased a Topeak Mountain Morph pump, which can be used with both Presta/Scrader valves. I have a presta valve on my bike, but am not able to inflate my bike. Not sure if I am doing...
Aug 25, 2010 | Topeak Morph Pump
Topeak joe blow pumps front but not rear tire
What's different?
http://www.youtube.com/watch?v=Ehf6HL0aLTc
Aug 21, 2010 | Topeak Joe Blow Ace Floor Pump
My almost new JoeBlow Turbo pump won't seal on either type stem
Do you flip up the lever on the air outlet? It should be flat on the handle to insert on the valve stem and then flipped up to lock on.
Hope,
matt
Sep 07, 2009 | Topeak Joe Blow Ace Floor Pump
Topeak Joe Blow Ace Floor Pump Logo
236 people viewed this question
Top Topeak Cycling Experts
Michial Gueffroy
numbers819
Level 1 Expert
dante
Are you a Topeak Cycling Expert? Answer questions, earn points and help others
