Question about Dryers
I need a user manual for my Roper Gas Dryer Model RGD440VQ
  • 5,911 Answers
I believe the model number is actually "RGD4400VQ". Go to managemylife.com and type your model number under the "Manuals" drop down menu. The installation and owner's manuals are listed in .pdf (Adobe) format that you can download or print for FREE. If you have any questions, please post back and let me know. I hope this helps you.
Posted on Jul 12, 2010
Roper Electric Dryer...model RED4440XQ0 will not heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | Roper RES7646KQ Electric Dryer
The dryer heats up for a few minutes the continues to run with no heat it is a Roper dryer model number RGS7646KQ3
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Roper RES7648E Dryer
Can a roper gas dryer woek wirh propane gas?
Yes, but you will need to contact Roper or a local dealer so you can buy a propane conversion kit...they are fairly easy to install be need to be installed correctly for safety and so that everything works well...
heatman101
Aug 07, 2010 | Roper RGX4634KQ Gas Dryer
Does not turn on and it's plugged in and i triped the breakers......
http://www.hammerwall.com/Manuals/Roper/Description/REX3614KW/Roper%20Electric%20and%20Gas%20Dryers%20Manual/L0101032/
Hi whatever the cause you are going to need a service manual, the links above and below, are top, user manual, below your service manual.
Many dryers are the same, internally, simply rebranded..
http://appliancejunk.com/forums/index.php?topic=2931.0
Jul 14, 2010 | Roper REX3614KW Electric Dryer
I have a Roper Gas Dryer model RGX5634KQ2. The
My bet is that your ignitor is bad....change the ignitor and you will be working again...
Here is a tip that I wrote about your problem that will explain it further...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 30, 2010 | Roper Dryers
No longer drying the clothes. How can I fix this?
Make sure the lint filter is clean and the dryer vent pipe is not clogged all the way to the outlet.
If it is not getting warm the gas igniter/glow plug may need to be replaced.
If the igniter is OK but the flame does not light the gas valve coil may need to be replaced.
If it gets warm and the venting is not clogged, the thermostat or flame sensor may need to be replaced.
May 20, 2009 | Roper RGX4634KQ Gas Dryer
Roper Gas Dryer
The first thing I would check is the thermal fuse (#6 on the bulkhead parts break down diagram). Replace if it's open.
Also, the manufacturer recommended to replace the cycling thermostat (#8 on the bulkhead parts break down diagram) too if the thermal fuse is open.
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Roper dryer Model RGX4634KQ2
"Did it solve your problem?"
Jan 28, 2009 | Roper RGX4634KQ Gas Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
How do i access the gas coils on my roper dryer?
http://www.pcappliancerepair.com/model-display.php This is a good site for parts and help. You can see the screws #2 holding the front on. Release the spring clips #20 with a putty knife in the gap on the front.
Nov 24, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
70 people viewed this question
Top Dryers Experts
Marvin
Marvin
