How do i turn off parental control on a tv with no remote
    Genius:
  • 1,121 Answers
Normaly is power off , and press a key while power on. normaly apear the parental menu. You must try several combinations, until you find correct one.
Posted on Jul 12, 2010
I have an RCA tv that the parental locks are set on and now the remote wont turn the tv on
you probably need to go for a universal remote , and check as the problem might be on the existing remote may not be working and then using the universal remote , u can undo the changes you have done .
Dec 14, 2014 | RCA 27" Tv Sdtv Universal R.c. connections...
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Parental Control Lock is on. Need to get rid of it. remote not working. JVC 32" Model AV32850
Unfortunately, you need to have the original remote control to turn off parental control lock.You need to use original remote control to access menu and then turn off the control lock.There is no alternate way.If the remote is not working, you need to buy a used / new remote.You could buy it from :-
http://cgi.ebay.com/JVC-AV3685-AV27850-AV32850-AV36850-TV-Remote-Control-/380292217173?pt=LH_DefaultDomain_0&hash=item588b2eb955
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 30, 2010 | JVC AV-27230 27" TV
Parental Control Code?
if you forgot your password you can reset it ,turn tv off press and hold vol< on tv and clear on the remote for 5 sec.,enter a new password next time you access the parental control menu.
Apr 16, 2008 | RCA F19436 19" TV
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
Parental control code lock tv
I am not sure if this works for your model, but if you have the original remote, turn the TV on, point the remote at the TV and press the "QV" (quick view) and the "9" buttons at the same time. Let me know if that works.
Sep 01, 2007 | Mitsubishi CS-26201 TV
Tv lock because of parental code
You will need an original remote control, which you can order online. With the original remote, turn the TV on, point the remote at the TV and press the "QV" (quick view) and the "9" buttons at the same time.
Override Parental Control
Customer service at RCA stated that you have to simultaneously push the menu button on the TV and the volume down button on the factory issued remote hold for three seconds and the parental should unlock and allow access again.
Jun 29, 2007 | RCA F32645 32" TV
Parental Control Locked
for an unknown passwrod try, go to parental control in menu then push mute,pisplay,clear,reset buttons in sequence. you may need to borrow a friends remote to do this. once in you can change your setting. good luck
Nov 12, 2006 | GE 19GT317 19" TV
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
