Question about Linksys Wireless-G WRT54GS Router (e125894)
Am using verizon fios wireless router 9100em but would like to add my linksys wrt54g for all wireless functions. Both routers use 192.168.1.1 to access router menus I can access the verizon but can't get thru to the linksys. Is there a way around this?
    Guru:
  • 480 Answers
You will need to change the dafault ip of one of the device.
Connect using a calbe lan first browse the ip 192.168.1.1
then change one of the device 192.168.1.2
Then set one as (ap repeater) access point router..
ok try this
Posted on Jul 12, 2010
I want to use my Linksys WRT54G as a bridge going thru Verizon FIOS 9100EM. What settings needs to be changed on the 9100?
You really don't need to change anything on the 9100 but with the router yes. And setting up the Linksys router depends on how the 9100 was configured. Just let me know if you still need more help.
Dec 22, 2010 | Linksys Wireless-G WRT54GS Router...
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Westell A90-9100EM wireless router cant make it work
Hello angiegall366,
The Westell A90-9100EM wireless router should be able to connect to the Motorola 2210. Follow the instructions in the Motorola 2210 User guide:
http://broadband.motorola.com/consumers/products/2210-02/downloads/2210-02-10na-usermanual.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 02, 2010 | Computers & Internet
XBOX360 Wireless Adaptor does not see my already set-up wireless network. I have Verizon FIOS as my ISP and a Linksys Wireless-G WRT54G Router. I can plug an Ethernet cord into one of the ports on the...
Please follow the steps below to setup your Xbox with your Linksys Router:
  1. With your Xbox powered down, take an Ethernet cable and plug it into a numbered port on the router, and plug the other end into the Xbox.
  2. After you have your Xbox connected to the router, start up the Xbox without a CD in the tray.
  3. After you start the unit, you should arrive at the “Xbox Dashboard”. Select the Xbox Live option and press the “a” button on the controller.
  4. After “Xbox Live” loads select the Network Setup and press the “a” button your controller.
  5. On the “IP Address” settings, you can choose “Automatic” or “Manual”, make sure it’s Automatic.
  6. Select the Connect option and press the “a” button on the controller.
After you use the “Connect” option, the Xbox will detect the network cable, and will ask you if you want to connect to Xbox Live.
Aug 17, 2009 | Linksys Wireless-G WRT54G Router
Is there any advantage using my DLink DIR625 with my Verizon 9100EM modem/router set up using WPA2? I have one ethernet tethered desktop and one laptop, plus using an wireless Skype Ipevo phone on the...
I can see no problem with that. But the WPA2 could be the issue. Some wireless device doesn't support WPA2 level. You can give it a try. For sure the laptop will connect. Not sure with the printer and the skype device. If they can't connect, use WPA only.
Jun 27, 2009 | Computers & Internet
Trying to get my verizon dsl to link with my linksys WRT54G route
The ethernet cable needs to be run from the dsl modem to the plug marked "internet" on the back of the router.
Apr 05, 2009 | Linksys Wireless-G WRT54G Router
Using Linksys WRT54G as router connected to ActionTec with FIOS
You must keep everything on the same subnet. Only allow the router to be DHCP and keep everything on 192.168.1.x subnet. You are going to have alot of problems talking across subnets
Jan 15, 2009 | Linksys Wireless-G WRT54G Router
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
Linking wrt54g with actiontec m1424wr
You need to check the ip address of your actiontec router, the default ip address of linksys router is 192.168.1.1, they should not be the same or else you will not able to connect the router to the internet.
To access the router web configuration
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3676&p_sid=fvzPHEYi&p_lva=3687#
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740145678B574
Let me also give you the site on how to add the linksys router to another existing router.
The linksys has 4 LAN port and 1 "Internet" port on the back - we ONLY use the LAN ports NEVER the Internet port - because your existing router is connected to the Internet - your linksys is connected to the LAN
http://www.kriyayoga.com/love_blog/post.php/368
Feb 18, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
359 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
