Question about Refrigerators
Fridge side of the side by side maytag refrigerator does not work does not get cold enough
    President:
  • 1,561 Answers
Inspect the gasket for dirt or debris that could prevent it from sealing. If you find any, remove the large debris, then wash the gasket, using a scrub brush and warm, soapy water.
Check the gasket for cracks or tears that can let cold air escape. If you find any, replace the gasket. If the gasket appears to be solid, go on to step 3.
Check the seal: Open the door, insert a dollar bill partway and shut the door on the bill. Try to pull out the bill. You should feel some resistance. Repeat the test at several points around each door. If the bill slips out easily, replace the gasket.
If there is any circuit breaker, reset it.
Check for thermostat problems. It could be off or won't cool properly (too warm,). If it can't be fixed with a simple adjustment, call a professional.
Check for coil problems. The compressor can overheat due to dust buildup on condenser coils. If so, vacuum the coils.
The above are the likely problem and the solution.
Take care.
Posted on Jul 12, 2010
I have a Maytag side by side, MSD2434GEW, about 8 years old, the fridge side appears to be working fine, the freezer side is about the same temp as the fridge and not cold enough to freeze anything. It...
the clicking sound is the compressor trying to start . i belive that you need to reolace the relay start on the compressor . the part that maytag has on ther websight is 12002794 about 34.00 .. mm hope this helps feed back pls ..
Dec 03, 2010 | Maytag MSD2434GE Side by Side Refrigerator
Maytag MSD 2756 DE The freezer is working the the fridge is not getting cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer works fine on my Maytag side-by-side refrigerator, but refrigerator is not cold enough, there is is ice accumulated inside the vent between the freezer and the frig., specially on humid days.
Defrost your fridge with a blowdryer in the freezer after you remove the freezer back panel. Get the ice out of your exhaust pipe going to fridge. Your evaporator fan should be running, either your defrost heater is bad or your defrost thermostat is bad. I ussually replace both. Good luck rate me if I am correct.
Aug 26, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag refrigerator about 6 years old. side by side. Freezer is working perfectly but the refrigerator side doesn't get cold enough.
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 30, 2010 | Maytag Refrigerators
Refrigerator portion of our side by side maytag is not getting cold enough freezer portion is working fine
see if your fan inside the fridge is working , if it is moving to slow or not functioning at all, try to replace it
Nov 14, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag side by side not getting cold enough
look in the back should have a fan in the bottom probably very dusty if it is it cant cool fridge clean it and it should work unplug it to clean
Jun 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
"maytag plus wide by side is not getting cold enough"
The defrost thermostat is failing on these machines as well as the adaptive defrost control.
The compressor start relay is on recall from Maytag also.
Apr 10, 2009 | Maytag MZD2766GES Side by Side...
Freezer not working
Hi. Thanks For The Question. Did You Check For Frost Build Up In The Freezer. Check That. Pull The Fridge Away From The Wall. Clean All Coils. Thanks The Appliance Doc
Aug 27, 2008 | Maytag MSD2656G Side by Side Refrigerator
Maytag side by side freezer works, fridge does not
the heat is from the condensor keeping the door from frezzing shut it is normal but you need to adjust the food compartment contorl it might say for a for a coler frezzor turn up then you do and the food compartment gets warmer all it is is a air baffle to alow more cold air into the food compartment turn the cold control half way its the one that has off on it and then turn the other control to a lower number to make more cold go into the food compartment
Aug 29, 2007 | Maytag MSD2656G Side by Side Refrigerator
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
