No sound on my tv connected to directtv. It worked great and them I came back from vacation and now now sound. Just on one tv. changed cable and no sound. tv works with a different satelite receiver. Could it be the direct tv box?
  • 4,889 Answers
Definitely. It is the direct tv box. the only thing you need to check is whether you have muted the direct tv volume. As you must have seen the direct tv has its own seperate remote. If you are using a universal remote thrn this possibility is ruled out and you confidently exchange the box for a new one.
Posted on Jul 12, 2010
How do i turn off the closed caption on my toshiba 51h84 tv? i tried setting via the remote and changed the CC option to OFF but i still see the closed caption wording...it is driving me crazy!! help!
What is the source of your TV signal: Cable? Dish Networks? DirectTV? Antenna?
Many times the Cable/Dish Networks/DirectTV controller also has an option for closed captioning. Please verify that a controller is not setup to deliver the CC data.
Also, try setting the TV CC using 'C1' or 'T1' and selecting 'Enter' to accept the change; then come back and set CC to 'Off' again to see if toggling on/off helps.
Dec 31, 2014 | Toshiba 51H84 51" Rear Projection...
Sanyo LCD TV no picture or sound with directTV
If the Direct TV box is working with other TVs, the problem is in the connection to the TV. In many TVs the automatic sensor works to detect what is being plugged in. In some, it has to be selected through the menu.
Jul 10, 2012 | Sanyo 42 in. LCD TV
The sound on my television is not working
Did you select the audio through HDMI cable or through analog audio input port in the TV menu setup for that HDMI input?
Mar 24, 2010 | Philips 42PFL7332D 42 in. Flat Panel LCD...
Someone sat on the remote control for my Yamaha rx v557 and I have no tv picture--do have sound. System is set up to Direct TV. I can change channels and hear everything fine, but can't get a TV picture It...
If it was the remote that changed the function then likely the mode has been changed. You probably need to have it changed back to the input you plugged your DirectTv into, such as video1 or component, or cable/sat. etc, etc...
Dec 14, 2009 | Yamaha RX-V557 Receiver
I have a Sylvania TV that does not have a separate audio in/out connection. It only has 2 composite wire connections one on either side of the TV...I have a Sony DAV-BC150 5.1 surround system and a...
Maybe I don't quite get what you're trying to do.
Unless you still tune programs off the air from the TV tuner and an antenna - what possible TV program would come into the TV that the DirectTV box wouldn't already provide high quality sound and video for? You should run the audio from the DirectTV box to the receiver.
May 04, 2009 | Sony DAV-BC150 System
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Olevia
You should check to see if the sound is really coming from the TV- you may have the sound from the directTV cable box composite audio red and white RCA connectors.
Try connecting from the audio out of the TV to the stereo
Try the menu and see if you can adjust vertical and horizontal hold.
unplug tv for 10 minutes - tehn try again.
change battery in remote, if the remote does not seem to work
good luck
Oct 26, 2008 | Televison & Video
No audio in input-1 (where DirectTv is set up to)
Good Day, matt30;
So, the the sound was working in the input ONE mode? Try resetting the D-TV & TV, by unplugging both for about 3 to 5 minutes, then plug both back in. If no fix try input TWO.
Good Luck, big IRISH.
Sep 08, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
