Question about Frigidaire Dehumidifiers
Drain hose for fdk45p13 - Frigidaire Dehumidifiers
Hose connected but not draining and bucket filling
I am also an air conditioning tech, with same problem and same soleus dehumidifier problem. you must remove the plug and install the drain line hose adapter. Hose must lay flat and have no "hills" for water to drain. With this done pull your drain pan out and set aside. look under right side facing the dehumidifier and you will see a small spout. Has a lip like a little tea pot. Plug that spout. I used a foam ear plug used in work shops. Now give the front of dehumidifier a slight rise on front wheels about the thickness of a pies of cardboard 1/8 to 3/16 of an inch. Now put drain pan back in an start up. The problem is the drain pan was made with very little differance in pitch between the the hose drain and the bucket drain. Remember to check your drain hose periodically and the air filter also. Good luck
Sep 09, 2011 | Soleus CFM-40 Dehumidifier
How to set the dehumidityfier to drain through a hose than the bucket
As you're facing the rear of the unit, you will see a drain hose connection with a drain cap in place, don near floor level. Using a garden hose, no longer than 5 feet, remove the drain cap and save for future uses. Connect the garden hose section to the drain hose connection. Roll the dehumidifier to within 5 feet of a floor drain and place the hose at the inner edge of the floor drain. Be use the hose is sloped down and without bends or kinks. Plug the dehumidifier in, turn it ON and set the humidity extraction level at 35 - 40%. Monitor the hose to make sure its draining after 15 minutes of operation.
Keep in mind, the drain hose relies entirely on gravity to drain. It will not drain, if the hose is not sloped it's entire length down from the unit.
To assist you further, I have included a link to your Owner's Manual, that you can download and print for future reference. http://www.danby.com/cms/uploads/products/en_manual/DDR586R%20EFOM.pdf
I hope this helped you and thanks for choosing FixYa.
Aug 01, 2011 | Danby DDR586R Dehumidifier
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
How do I install a hose so this humidifier drains automatically?
Look at the drain pan, it might have a garden hose connection that you might have to knock out, mine is not the same model but it may be similiar, and then run it to a floor drain or such. Good Luck
Jun 30, 2011 | Whirlpool AD50USS Dehumidifier
How is the external tube for draining outside connected to the dehumidifier. Does the tube insert into the right angle nipple, then the threded end conected to a drain hose?
No. The tube inserts straight into the drain hole. Follow the 4 sets below.
1. Connect a garden hose to the threaded drain hose connector.
2. Remove the drain-hole cover.
3. Push hose connector tightly into the drain-hole on Rear Grille.
4. Press the hose down and make sure the "Arrow" on the tab is pointing upward.
NOTE:
The hose attachment will accept a standard garden hose fitting. Do not over tighten the hose when
connecting it to the hose connector, use a rubber washer and tighten by hand firmly without stripping the plastic threads. Be sure the hose lays flat and has no kinks, as it will not drain properly.
Apr 12, 2011 | LG DH404E Dehumidifier
Will not drain out of the hose i have to keep emptying the pan i thought it was suppose to drain out of the hose to keep running
If the hose is connected to the tap on the drain pan/bucket, did you knock out the center of the hose connection on the bucket? If you didn't that's the problem. If that's not where your hose connection is located, do not put the bucket back in. It triggers the unit to fill the bucket and not use the hose drain. Keep in mind the hose must remain lower than the connection on the dehumidifier to drain properly.
Mar 21, 2011 | Whirlpool AD35USS Dehumidifier
How do I connect the hose? lost manual
If you asking about the drain hose. There's what looks like a hose hookup on the back of the unit, down near the floor. It's probably plastic and is threaded to accept a garden hose. You may have to carefully knock out the opening of the plastic connector, to allow the water to drain into the connected hose. The hose then should go to a floor drain or sump pump. Keep in mind, the water will not drain up.
Feb 08, 2011 | LG LHD65EBL Dehumidifier
Why doesn't dehumidifier drain through hose? Even with the hose connected, the water still drips into the bucket and shuts off.
I had the same problem....raised the unit 3 feet off floor, the drain hose is 4feet long... But the secret to getting unit to drain into hose if unit is set to Continous is...... TILT the unit back about 5 degrees with a half inch piece of wood under front wheels and She will drain into hose instead of bucket.... .....goldiejud@netscape.net
Oct 18, 2010 | Whirlpool AD50USS Dehumidifier
50 pint dehumidifier has drain hose connected but fills up the drain bucket and stops running....
safety switch is turning off the dehumidifier....you need to drain out the bucket more often....or put the drain hose into an actual drain....ive seen some people run a small plastic hose from the dehumidifier to the sump pump hole in their basement.
Jan 27, 2010 | Frigidaire Dehumidifiers
Need manual for fedder dehumidifer to hook up drain hose. need to know were drain hose connects.
Pull out the water collection tray. You will see a small pipe (about 1/2" diameter) in the top of the area where the tray came from. This is the "drain" that fills the tray. Connect a hose to this pipe and run the hose to a floor drain if you have one. I used a section from an old garden hose for my unit. There also may be a small opening in the back wall of the dehumidifier to route the hose more aesthetically.
Dennis
Jun 12, 2009 | Fedders A7DH45B2A Dehumidifier
Dehumidifiers Logo
165 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
