Question about De Dietrich Dishwashers
De Dietrich dishwasher model DVF300JU2 Child opened door during wash cycle closed door but m/c did not restart,now all lights on! unable to clear/restart, tried to cancel programme by pressing 'Start' for 3secs as per manual HELP!
  • jackcoletalk Jul 12, 2010
  • 11,896 Answers
Try pressing stop or cancel button for 10 full seconds. If this does not work, unplug the machine for 10 minutes. While unpluged, press and hold cancel or stop but for 10 seconds, then plug machine back in. If it still does not work, test the door switch with an ohmmeter to make sure the door switch is not faulty.
Posted on Jul 12, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This issue can be either due to a faulty door latch or door lock switch which is not engaging itself. If the door latch will not engage the dishwasher will sense it as open door and will not start the cycle. The light also blinks when the dishwasher detects a no-fill condition. Also check the fill valve. I'll also suggest you to check the detergent dispenser solenoid for this issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • 1 more comment
  • Rylee Smith
    Rylee Smith Jul 12, 2010
    If the green/clean light flashes, pauses, and then repeats,
    the dishwasher doesn't sense a water temperature increase and it stops working
    and locks the functions (clean light flashes, all buttons are non responsive). To
    resolve this you’ll have to reset the console. Do this by closing the door and
    press these buttons in sequence...
    -high temp wash
    -heated dry
    -high temp wash
    -heated dry
    further assistance.
    Thanks
    Rylee
    Hi Rylee, thanks for your response, all the lights are constantly lit, ie. none are 'flashing', the washer has worked perfectly upto the incident of the child opening and closing the door during a normal wash cycle, I've tried the 'cancel program' procedure as per the handbook all to no avail, all the lights remain lit....???
    just a comment on your last suggestion re: button pressing sequence, I cannot do this because when the door is shut the buttons are inaccessable (built in unit model).... any further suggestions would be appreciated....... thanks Jack.
  • Rylee Smith
    Hi Jack thanks for your reply. You can try to
    reset it by unplugging the unit from the power socket and mains and let it be
    seated without power for more than ten minutes. Now re-place the plug into the
    power socket and mains and switch it on. If still the issue is not resolved then remove the
    control panel and blow air on it. If this works then it might have been caused
    due to moisture in the board. If it won’t work then the control panel should be
    replaced.
    Please do accept
    Thanks
    Rylee
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
Model DVF300JU2, all lights on! unable to clear/restart
Well first of all you can turn of the water supply, then disconnect the Aquastop and drain out the water in the hose. Reconnect and turn on water and machine. Please post comments if further you have the same problem....
Good Luck!!
Thanks
Jul 12, 2010 | De Dietrich Dishwashers
Light stays on in De Dietrich oven DOD438 all the time. It is in the lower oven. Stays on whether door is open or closed. Oven is new since May 2007
I too have just had this problem. The door switch (top right corner) is broken and the oven thinks the door is always open. Chances are it won't heat up either.
Apr 05, 2010 | De Dietrich 22 in. DTV315 Electric Cooktop
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
Leak from a De Dietrich Integrated Dishwasher has caused 3 red lights on the left of the Control Panel to flash and also a Blue Light on the right hand side of the Control Panel to flash. On resetting...
Pull the built in unit out and tilt towards the rear right leg and the water will drain on to the floor. The Dishwasher then restarts but the anti flood sensor will reactivate after 2-3 more washes. Do not know final fix yet.
Oct 05, 2008 | De Dietrich Dishwashers
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Oct 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Kitchenaid dishwasher KUDS02SRSS2 start light blinking won't start
I have this same kitchenaid model. It would not start after selecting the wash cycle and pressing start. The light would blink as if the door was open. I did the reset by pushing the sani-rinse, heat dry, sani-rinse, heat-dry and closing the door. You can hear something going on inside. After that stopped (about 3 minutes). I was able to select the wash cycle, press the start, close the door, and it started. Good luck!
Feb 22, 2008 | Dishwashers
Dishwashers Logo
858 people viewed this question
Top De Dietrich Dishwashers Experts
ray gallant
richie46
Are you a De Dietrich Dishwasher Expert? Answer questions, earn points and help others
