Question about Intel D845GVSR Motherboard
Motherboard problem Sir,when i am start computer then do not disply on moniter. i am cheaked the moiter , ram,smps. Do not problem them . Processor Fan is ok and motherboard green light is look when start the power. Please help us
    President:
  • 1,138 Answers
Secure the video card. make sure it is properly seated in the motherboard. fix the connection of the vga cable on the video card and the monitor.
Posted on Jul 12, 2010
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
Dear sir my motherboard not display i will cheack ram, bois,smps
does ur processor fan and smps fan work if both are working then the problem is in the motheboard if both are not working check ur smps by shorting the green pin with black if it doesnt work change ur smps and it works the problem is in ur motherboard ur power supplysection in ur motherboard has been fried take the mother board to a qulified chiplver service personal
Sep 27, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computer beebs on start-up, moniter shows black
For that open cpu cabinet
Reattach the RAM memory.
Open processor fan and processor reattach both.
Make sure motherboard circuit could not ground with cabinet.
Pull cmos cell from motherboard for 10 minutes .
Remove pci cards from motherboard if any.
Reattach VGA card if installed.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 27, 2010 | Dell Dimension E310 PC Desktop
I haveIntel D865GSA Motherboard. woth p4 2.4 processor. suddenly it cannot display. moniter gives orange light. HDD & SMPS is ok.i check it on other pc.
It may be caused by your RAM memory. Try cleaning it or try another one or change slot. If this don't work, unplug HDD/floppy/dvd drives/usb/audio from Motherboard & try.
If the above don't work, then it's probably the motherboard.. Hope u get the cheapest solution
Feb 10, 2010 | Intel D865GSA (BOXD865GSAL) Motherboard
Computer won't power up
Make off power.
Remove the RAM.
Check the beepcode occurs or not.
If beepcode is long then RAM DEFECTIVE.
===> Erase to polish contacts of RAM with soft white presto eraser.
If beepcode not sound, open Processor and recheck. same.
If again negative, just short green and black wire of SMPS after opening from motherboard. SMPS must start and check all voltages. If not start SMPS Defective.
Please give your feedback so that further repaire can be made.
Thanks
Jan 24, 2010 | Ultra (ULT31554) 500-Watt Power Supply
Disply problem
CHEK POINTS
1. Does your fan spins
YES:- Go to 2. No:- replace S.M.P.S.
2. Do you get any beep noise
Yes :- remove and fit Ram No:- go to 3
3. Does your processor fan spins & stops after while
Yes :- Your Processor might damage No:- go to 4
4. Do you got spindle voice of your hard disk & fan spins & stops after while
Yes:- Please take out motherboard from chassis & chek
No:- remove C-mos battery for 1 hour & fix again & check
Mar 14, 2009 | AOpen Computers & Internet
Motherboard display problem
o that is simple bro, see whats happening is that the processor was in the process of burning as a result it would create alot if heat constantly so sometimes it would start and sometimes it wouldn't, so what u can do is replace it with one with the same socket size and that should do the trick.....
Dec 06, 2007 | Intel D865GBF Motherboard
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
Intel D845GVSR Motherboard Logo
81 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
