Question about Casio FX-300MS Calculator
How to fix it . My calculator rounds up every number
  • Casio Master
  • 8,073 Answers
It is configured to keep zero decimal digits. You must change the number of decimal digits you want displayed. The following screen capture from the manual will show you how to select the display format SCI, NORM, RND and the number of decimal digits to keep.
Posted on Aug 24, 2010
  • k24674 Aug 24, 2010
    The picture was taken from page E-15 of the calculator's manual.
5 Suggested Answers
anderza
  • 41 Answers
SOURCE: Calculator rounds up fractions when adding or subtracting numbers
Type in
Posted on Jan 05, 2010
homedesigner
  • 583 Answers
SOURCE: i must of hit a button, now my calculator rounds
There should be a switch that has 5/4 on it. This is the rounding switch. Place it in the Up position to round all numbers up, 5/4 to round down when the next digit is less than 5 and round up when 5 or greater, and the down position to always round down.
Posted on Feb 26, 2010
  • 34 Answers
SOURCE: My Casio calculator rounds all decimals to whole
you can't casio is stupid like that. go roll a texas instrument. its wayy better
  • 16 Answers
SOURCE: My calculator is rounding to
You should move the rounding switch on your calculator. It has three options: an up arrow on the left side (for rounding up) a 5/4 sign in the middle (for rounding off) and a down arrow on the right side (for rounding down). borbalint.png
You may also have to move the decimal point selector switch to set the decimal point position.
Posted on Mar 15, 2011
How to I stop my sharp EL-531X calculator from rounding when converting from decimal to scientific notation?
You need to select the number of decimal places you would like, or if you would like the calculator to behave as normal. Press SET UP and select FSE (press 1) . You now have 5 options.
0: FIX means you can choose a fixed number of decimal places for every calculation.
1: SCI means scientific notation and choose the number of significant values you would like to deal with.
2: ENG means engineering and the power goes up in multiples of 3.
3: NORM1 and 4: NORM2 are the usual or normal settings on the calculator. Most school calculations will use NORM1 mode.
Aug 28, 2012 | Sharp El-531x Scientific Calculator Green...
How do i take of fix on a ti15
[FIX] [0.001] rounds results to the nearest thousandth.
[FIX] [ . ] removes the fixed-decimal setting.
You must press [FIX] before a Place Value key each time you want to
change the number of places for rounding.
Nov 28, 2011 | Texas Instruments TI-15 Calculator
Is their away to round whole number on a ti30 calculator
To do this you need to set your calculator to a fixed decimal value. You can do this by Pressing 2nd + FIX (decimal point) and then setting it to 0 decimal places. This will round a number to the nearest whole number.
Hope that helps.
Apr 22, 2011 | Texas Instruments TI-30XA Calculator
My calculator is rounding to nearest whole number. How do I fix this?
Mar 15, 2011 | Canon P23-DHV Calculator
How to get a Casio out of rounding mode
Press the MODE key a certain number of times, until you reach a screen that displays FIX SCI NORM and numbers 1, 2, and 3 under them. Press 1 key to select the FIX display format, then enter a number between 0 and 9 to set the number of decimal digits you want to keep in your result. In your case the calculator is already rounding so you should select a reasonable number of digits say 2 to 3.
MODE (a certain number of times ....) 1 (FIX) 3 will keep three decimal digits in the results.
Sep 14, 2010 | Casio FX-300MS Calculator
I must of hit a button, now my calculator rounds all my numbers how do i fix that?
Feb 26, 2010 | Basix BX-PC102 Calculator
Everytime I put decimals into my calculator, it just rounds the answer to the nearest whole number.
Increase the number of decimal digits in display.
  1. Press [SHIFT][MODE] to access the {SETUP)
  2. Enter the number (6) corresponding to option [6:FIX]
  3. In screen that is displyaed, enter the number of decimal digits you want (2, 3, or 4). If you enter 0, all decimal numbers will be displayed as integers (rounded). If you enter 9, you will have long numbers but that is hardly ever necessary.
Feb 21, 2010 | Casio FX-115ES Scientific Calculator
My ti 30 calculator always rounds to the nearest number with the answer. How can i get this to stop????
To stop the calcultor rounding your answers to the nearest INTEGER, press [2nd][FIX] followed by a number other than 0. For exemple
[2nd][FIX] 3 will display the numbers with 3 decimal digits.
Hope it helps.
Thank you for using FixYa.
Nov 24, 2009 | Texas Instruments TI-30XA Calculator
MS-80TV AUTOMATICALLY ROUNDS UP TO 1 DECIMAL DIGIT
The [MODE] key can be used to select the modes described below.
Important! The following is a general explanation of Scientific Calculator modes. Note that your calculator may not include all of the modes described here.
1) Calculation Modes
Before performing a calculation, you first need to select the appropriate calculation mode.
COMP: Basic arithmetric calculations
(arithmetic operations, trigonometric functions, etc.)
COMPLEX: Complex number calculations
SD: Single-variable statistical calculations
(sample standard deviation, etc.)
LR or REG: Paired-variable statistical calculations
(linear regression statistical calculations, etc.)
BASE or BASE-n: Binary, octal, decimal, hexadecimal number system calculations
MAT: Matrix calculations (determinants, etc.)
VCT: Vector calculations
EQU: nth degree equations, simultaneous equations
2) Display Settings
Use these settings to control how calculation results are displayed.
Note that changing the Fix and Sci settings does not affect internal calculation results.
Norm: Exponential display format and cancels the currently configured Fix and Sci settings.
Fix: Specifies a fixed number of digits to the right of the decimal place.
Sci: Specifies a fixed number of significant digits.
3) Angle Unit Setting
(90°=?/2 radians=100 grads)
Deg: Degrees
Rad: Radians
Gra: Grads
4) Engineering Mode
Use this mode when you want to input and perform calculations using engineering symbols.
Please rate this response . .
Sep 08, 2009 | Casio MS-80TV Scientific Calculator
Calculations are automatically rounded.
Look for button with FIX or FSE and then press:
[2nd][FIX][.] and now it's will give the whole number.
Rate me, thanks.
Jan 04, 2009 | Texas Instruments TI-30 XIIS Calculator
Casio FX-300MS Calculator Logo
173 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
