Question about Hotpoint Refrigerators
How do I remove the realy cover on a Hotpoint RL63
How do I remove the relay cover on a Hotpoint RL63 fridge? I need to check the relay, compressor starter.
  • Hotpoint Master
  • 3,361 Answers
Use a flat blade screwdriver and snap it off.
Posted on Jul 12, 2010
Have received a reply from Richie46 regarding Hotpoint fridge - however where do I find the start capacitor and/or start relay?
The start relay is under the cover on the compressor. The wires are connected to it directly. The capacitor may be mounted a short distance from the compressor. Wire color is usually brown or yellow.
Sep 26, 2015 | Hotpoint Refrigerators
Hotpoint FF200LP fridge freezer,fridge no longer cooling.
first thing I would do is remove the cover on the back and feel the compressor to see how hot it is or even if its clicking. I would also check the defrost controls
Appliance 911 Sea Breeze
I'm here to help you locate the problem just talk with me
Aug 27, 2015 | Hotpoint Refrigerators
Hotpoint RLA64T fridge freezing up after new thermostat fitted
WHEN U TALK ABOUT THE THERMOSTAT U MEAN THE COLD CONTROL THERMOSTAT OR DEFROST TIMER THERMOSTAT? WHEN UR PROBLEM SOUNDS MORE LIKE THE DEFROST TERMINATOR OR BAD HEATING ELEMENT, LOCATED ON THE FREEZER EVAPORATOR COILS? IF ITS STAYING ON ALL THE TIME U HAVE A DEFROST ISSUE? OR BAD SEALS ON DOOR AND DIRTY COMPRESSOR
Aug 02, 2014 | Hotpoint Refrigerators
My fridge freezer (Hotpoint FFA70) defrosted of its own accord. The lights are still lit at the top but is there anything I can do?
Hello, Your freezer is supposed to go into a defrost cycle every 8-12 hours. By doing this it defrosts any ice build up on the evaporator coil. Question though are you stateing both the fridge and freezer are wam in your unit? If this were the case then you would locate the compressor which in most units you would have to pull the unit away from the wall and remove the lower panel in order to access the compressor area. You can use the palm of your hand against the side of the compressor to assure if the compressor is running or not. If the compressor were not to be running then on most refrigerators on the side of the compressor is a small box if you were to remove the box this would give you access to the start relay and overload for the unit which is what starts the compressor. You would first unplug the machine and remove the small box. Next you would disconnect the wires going to the relay. After disconnecting the wires you would then remove the relay and overload off the side of the compressor. You would then inspect the relay for any blackend electrical burns and if there were none then you would shake the relay and if you heard a rattle in the relay this would be a sure sign that the relay need to be replaced. If you have any questions or find that the compressor is running when you use the palm of your hand on the compressor message me back for further diagnosis as well as your complete model number. I await your reply Thanks
Rick
Sep 24, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
My refrigerator/freezer has stopped working.
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jan 12, 2011 | Hotpoint Refrigerators
Hotpoint Mistral Fridge freezer no Power Issue
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Dec 11, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
RS2555SL - Replacing the relay step-by-stemp
Thanks, Jonathan! I got the relay replaced and my fridge is working like new!
May 25, 2009 | Samsung Refrigerators
Where is the timer motor on older hotpoint side by sides
Depends on the model, but the easiest place to check is behind the kick panel under the doors. If it's not there try removing the control cover, or you may have to pull the fridge out and remove the compressor cover. These are the 3 most common places for a defrost timer.
Jul 20, 2008 | Hotpoint HSS25GFP Side by Side...
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
Refrigerator stopped after only having 18 months
"part that starts the compressor" could be the thermostat or the compressor relay. most probably the thermostat. the 'stat is indeed nothing to do with the compressor and is only the switch that makes the compressor start. the part is reasonably cheap and easily replaced. hotpoint refrigeration is as good as any and i don't have a vested interest
May 09, 2007 | Hotpoint  16.6 Cu. Ft. Top-Freezer...
Refrigerators Logo
108 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
