Question about Xerox Phaser 7750DN Laser Printer
Model 7760 boots up to main menu but says it is warming up. Is this a problem with engine controller board ? Fuser is hot.
The Xerox Phaser must be connected to thenetwork via the ethernet cable or via the USB to a PC before you start it up.
If the printer can't "see" the network or PC via the Ethernet or USBconnections when you switch it on, the menu will display "warming up"continuously and when you try to access the menu, it will "freeze".When this happens, switch the printer off and make sure the Ethernet or USBconnections are connected properly before switching it back on.
Posted on Nov 27, 2010
Konica minolta 240f error code 18 stands for what
https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20240F&code=18
Konica Minolta bizhub 240F Error Codes
Quoting from the web link shown above:
Konica-Minolta bizhub 240F Error Codes
Exploded Views and Parts List Free!
Code
18
Description
Fuser Error
(The number indicates the detailed error code) 0 The fuser did not become to the main motor driving temperature in 50 seconds after printing started. 1 The fuser did not become to the paper pick-up temperature in 50 seconds after printing started. 2 The fuser did not become to the main motor driving temperature in 30 seconds after warming up started. 3 The fuser did not become to the warm-up finishing temperature in 30 seconds after the motor started driving. 4 A temperature of 250°C or higher is detected in a mode other than sleep mode. 5 The fuser does not warm after fuser error is solved and the power is turned OFF/ON. 6 A low temperature of 10°C is detected in 10 seconds after printing started. 7 A temperature of 190°C is detected in ready mode after printing finished.
Remedy
1. Turn on the power again, and verify the fuser warms up. If it does not, see step 4. 2. Check the contact between Fusing thermistor and Connect A PCB(P89). 3. Check the contact between Connect A PCB (P80C) and the main board. 4. Replace the Fuser. 5. After replacing the Fuser, verify the fuser warms up when the power is on. 6. Replace the main control PCB.
Apr 07, 2018 | Konica Minolta Office Equipment & Supplies
I need help to clear error 18 on konical minolta 240f.
Code
18
Description
Fuser Error
Remedy
Nov 19, 2017 | Minolta Office Equipment & Supplies
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
My laser printer gives message open heat error how can I fix
This is most commonly caused by a failure of the Fuser unit.
However, in rare circumstances, this can be caused by the Fuser Control section of the SMPS, or the fuser temperature monitoring circuit on the Main Board.
There is a closed control loop:
1. AC voltage is supplied to the Heat Lamp in the Fuser from the Fuser Control section of the SMPS
2. The temperature of the fuser heat is monitored by a thermistor (mounted on the Fuser) connected to the Main Board.
3. The Main Board determines if the fuser temp is too low, correct, or too high and signals the Fuser Control to increase, maintain, or decrease the AC voltage to the Fuser
sorry io say but you had to replace the fuser
call dell costumer support and tell your model no. ask for fuser replacement and they will do it .
Hope your printer is in guarantee period otherwise you had to pay.
REGUARDS
Dec 13, 2009 | Dell 1600n All-In-One Laser Printer
Permanent warming up message
When you replace a power supply for this machine, it needs to be the correct power supply for this model. If you have the old one, check to make sure the right power supply was ordered for this specific model.
Because I cannot see the display, and we only know what it is saying, the next best thing would be to see if the fuser warmed up at all. Open the side door and gently feel the fuser frame to see if it is warm at all. Do not touch the Fuser roll; it is hot even to the slightest touch.
If it is not hot, make sure all the plugs were correctly plugged into the power supply.
On this problem there can be other factors that can cause warming up.
First, the fuser assembly may be defective and needs replacement.
Second the main board may be gone out.
And last if the machine has memory chips in the back, unplug the machine, remove the small cover from the back and unplug the simms chips and reseat them. Plug in the machine, then power it on.
See if the machine will go to a ready.
If not, possibly the fuser, or main board, or both. If the main board or(and) the fuser assembly is replaced,
MAKE SURE THE CORRECT PART IS INSTALLED IN THE MACHINE.
If all else fails, Place a Xerox Service Call on the machine before it gets too expensive in troubleshooting the problem with purchased parts.
Oct 22, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Sharp AR 5316 E ia giving me h 4
This sounds like a fuser unit is causing the problem.
If this problem is at warm up, the fuser maybe the cause of the problem.
Turn on the machine, wait for the error code to appear. Open the side door where the fuser is located. Try to feel the area and see if it is warm, careful not to touch the heat roll itself, it can be hot.
If it is not hot, the problem area is with the unit, or the main board that controls it.
Oct 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
Hello i hope someone can help me with my problem i need reset the fuser uit xerox phaser 7760,because the rollers both(up,low) are like new condition thank you
You can get more life out of the fuser by removing one end and placing a piece of tin foil OVER the THREE FUSES, which are designed to blow at set times. Just tape it in place with some tape.
Good Luck
Oct 03, 2009 | Xerox Phaser 7760/YDX Laser Printer
I have a xerox 5016 copier ,
All U4 codes on Xerox machines relate to the "fuser".( That's the hot bit on the way out) You will find the rollers fail to warm up, or reach correct temperature .
Most often the heater rod inside has burned out, or sometimes the overheat thermostat goes open circuit.Both problems will require the fuser unit pulling out of the machine and a test meter to check continuity of the components
Jan 07, 2008 | Office Equipment & Supplies
OPEN HEAT ERROR
hi im jules_09,does the machine warms up?if not reset the error code in the program.if the is still there check the termistor,heating lamp and termalfuse one of those components are deffective.test it with a tester
Nov 02, 2007 | Xerox CopyCentre C20 Black and White...
Xerox Phaser 7750DN Laser Printer Logo
930 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
