Question about Refrigerators
I have an Amana side-by-side frig/freezer SXD22S2w Mgf # P1303512ww. The settings for temperature are 1 to 7. Is one the coldest or warmest? I have it on number one but the top of the water on the noodles is frozen. Help?
  • 1214 Answers
SOURCE: amana refrigerator warm
Chances are if they are getting cool but not cold-
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Posted on Jan 20, 2009
  • 12 Answers
SOURCE: fridge & freezer not cold enough
EASY FIX. TAKE ALL FOOD OUT OF FRIDGE AND FREEZER AND STORE IT.
THEN UNPLUG YOUR FRIDGE FOR 24HOURS WITH DOORS OPEN.
YOU WILL HAVE TO CLEAN UP ALOT OF WATER. THEN CLEAN THE FRIGE.
WHEN YOU PLUG IT BACK IN IT WILL WORK.
BUT THIS IS JUST A TEMP FIX. IT WILL HAPPEN AGAIN IN ABOUT A YEAR OR TWO.
TO GIVE U A MORE PERMANENT FIX WILL TAKE SOME TIME. TRY THIS FIRST.
Posted on May 01, 2009
  • 212 Answers
SOURCE: amana fridge ice maker not working
need to check water valve. probally need to replace valve. not letting water through. if valve is ok then ice maker module is bad
Posted on Jun 21, 2009
dmftrucker
  • 1922 Answers
SOURCE: the temperature gage is a wheel on the right hand
1 is warmest-7 is coldest
Posted on Dec 25, 2009
Testimonial: "fabulous thanks"
freetek
  • 5569 Answers
SOURCE: Amana refrigerator not cold
The fan that should circulate air between the two compartments has failed. These usually have 'sleeve' bearings which can become sticky and fail to start up without help. Go to the Sears/parts website and enter your Amana model number; if you are lucky, they will have a line drawing of your model which can aid in finding how to access the fan:
Sears Parts Dept.
They have info for thousands of non-Sears items and most can be ordered via that website as well.
Posted on Feb 25, 2010
Is 1 on the temperature control of my Sanyo bar fridge the coldest temperature or the warmest? It goes off 1- 2- 3 .. up to max.
1 on fridges is the coldest --the bigger the number the warmer the fridge
it is the opposite for freezers
Jul 06, 2018 | Sanyo Refrigerators
Refrigerator& freezer not getting cold enough.Like to know not the T Stat works .1 coldest or 7 coldest.
1 is warmest 7 is coldest
a couple thing to check are if the coil i behind the rear service plate is clogged with dust,or is if the fan is running in the freezer.
Aug 06, 2011 | Amana ABB1927DE Bottom Freezer...
How do I adjust the freezer temperature on a Kenmore upright freezer?? Brand new, model number 461.27432, didn't come with a manual.. can't tell whether 7 or 1 is considered the coldest temperature?
Sorry there is no manual on-line for the freezer. But I can tell you this 7 is the coldest and 1 is the warmest.
Good Luck and Please rate 4 thumbs up for the free answer.
Jul 04, 2010 | Kenmore Freezers
Amana side by side refrigerator wont cool properly after moving from one house to another
have a two year old side by side amana frig. the freezer side works fine, the frig is at 56 degrees at coldest setitng. HELP, can't get repair guy for five days cause we live in rural area.
Apr 19, 2010 | Amana ARS266ZBS Side by Side Refrigerator
My GE side by side has started freezing everything in the refrigerator on the warmest setting and the freezer will not maintain less than 10 degrees on the coldest setting. Any ideas?
on the left side of the crisper drawer there may be a air return hole that you can adjust, if not try some duct tape where the air comes into the fridge, cover it by 1/4 then 1/2 till it is the right temperature
Aug 04, 2009 | GE Refrigerators
17 yr old Amana frig freezer isnt cold enough lite display nowork
No it's not worth it! Sounds like its low on freon and they don't make R12 anymore, junk it
Jul 06, 2009 | Amana ASD2625KE Side by Side Refrigerator
Veggies freeze up in the compartment meant for them
1 is the warmest setting, 7 is the coldest.
No answer for your veggies freezing.
Jan 09, 2009 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
