Question about Intex Frame Set 12 ft x 30 in Pool with Pump
My pool is not level by 2.5 inches. Will it
My pool is not level by 2.5 inches. Will it collapse or make it another month or so? We already took it down once to try to fix this problem - it must be settling to much on one end.
  • 52 Answers
Drain and move to level ground . or add sand on the low side to keep it level
The Pool Tech
Posted on Jul 14, 2010
How long should it take to assemble a12ft bestways steal frame pool
how long will it take you make sure the ground is absolutely level and covered with 4" of sand
if that is not done then the pool will collapse when full and the uneven surface will punch holes in the pool liner
As for the rest probably 1 1/2 hours and a carton or two
Dec 23, 2017 | Pool & Spa
Hello I have i 18 foot by for foot deep above ground pool with the blow up ring. It is about 3 inches lower on one side. Well we got in it today with no problems of water coming over the ring. Well ...
above ground pools have to be erected on perfectly level ground. If you have one side 3 inches lower than the other then all the weight of the water is against that lower side and eventually the water will overcome the air pressure in the ring and it will collapse and let the water out especially if the ring has a small air leak and looses pressure. You are lucky that you do not have a pool with 4ft sides as the loosing water effect is remarkable and will wash away any thing in it's way. Use the water in the pool as a level and adjust the base ground so that the pool sits level all the way around.
Jun 17, 2013 | Intex Easy Set Pool 15x36
Where to find PVC valve on 460 engine
PCV valve will be located either in valve cover (tappet) or cover over the lifters under the intake. Not real sure as I haven't touched a 460 in 20+ years but know that it has to be able to get vacuum from the intake system and have access to the inside of the engine above the oil liquid level. Should have a thumb thick (1/2 - 3/4 inch) hose going to it from the intake or carb.
This has nothing to do with a 2 inch pool diverter valve......
Sep 30, 2012 | Pentair 263029 2-Way, 2-Inch PVC Pool...
My wife and i bought a 16 by 48 in. ultra frame intex pool. we had profesionals level the ground, we have a sandy base, and after filling our pool with water and the legs settled, the pool is approx. 2 in....
There won't be any structural problems and you will notice the difference more than anyone else. If you redo the pool next year it will help to set each leg on a patio brick so it won't settle.
May 10, 2011 | Intex Ultra Metal Frame Pool w/ Upgraded...
The metal poles seem to be tilting in twords the top it looks like its going to collapse. The pool is not to full...It is also not on a hill.
If your soil is sandy or loose the pole bases may be sinking and spreading outward. I have seen people use landscaping blocks or bricks underneath the bases to solve this.
And remember, even a couple inches of elevation change can unbalance one of these pools...not obvious to the eye over an 18 foot area, but obvious once you fill it.
Jun 29, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Crooked ''legs'' intex pool
Should be ok, it really depends on the angle, mine are prolly a few inchs off on some, but im not worried with mine. im pretty sure you will be ok.
Jun 12, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Hi! I just filled a metal frame 12 X 3. It is unlevel by almost 6 inches. Will it collapse or just spill water on the high end? should I just remove some water to make the higher end lower? or do I need to...
"should I just remove some water to make the higher end lower" - Does that really make sense to you?
No matter how much water you have in the pool the bulk of it is going to go towards the lower side. It shouldn't collapse. Pools collapse due to winter damage, not to being unlevel, and you cannot leave that pool up over the winter or it will pop.
Jul 03, 2009 | Intex Frame Set 12 ft x 30 in Pool with...
Lopsided 18x4 intex round easy set pool
I started out with easy set pools a few years ago and finally gave up and went to their steel supported ones.
I have put up over 20 above ground Intex pools and have learned a few things in the process:
A: The larger the pool with the air ring at the top the more difficult it is to fill to its maximum potential.
B: Eventually the pool is going to collapse with people in it, especially if someone leans over the edge with their arms on it which is a perfectly natural thing to do.
C: It is virtually impossible to get an area beneath the pool level without scraping the ground and measuring it with, in your case, at least a 16' long 2"x4" on its edge with a level on it.
D: Trying to build up the ground on one side with sand will eventually result in collapse of the pool.
E: There is a type of stiff styrofoam ring that you can buy in sections to go around the bottom of the pools, but that will also result in collapse unless it is used for what it was developed, and that is a rigid wall pool.
F: Out of the three types of pools that Intex sell, the easy up with the air ring (the worst), the steel supported all the way around (next worse). and the rigid side, only the rigid side is forgiving to a tiny degree where unlevel ground is concerned.
For your size of pool everything must be exact and completely level or at one point it will collapse. There is little more discouraging than seeing all those gallons of water run out onto the grass. Once the water goes over the edge, no amount of people can prevent the collapse.
Finally I have learned that, with above ground pools, you get exactly what you pay for. My 5th above ground Intex pool was the best, but even with the ring around the edge at the bottom and the rigid side, I was still wasting my money unless the ground was aboslutely level. You just have to cut away the dirt until the level shows no angle.
I wish you all the luck. If you feel a desire, I have 5 Intex pools in my barn I will give to you if you pay the freight. Each was a dissapointment and a waste of time, energy, and above all, money.
I finally spent about $750 on one, had a professional crew level the ground, and it stays up through the winters even.
May 25, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Unlevel ground 3 inces
No, it wont collapse, if you fill it too full it will just overflow
May 23, 2009 | Intex Easy Set Pool 15x36
Intex Frame Set 12 ft x 30 in Pool with Pump Logo
733 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
