Question about Car Audio & Video
Where do i connect my amp to my paosonic cq-dfx301u
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
On the the back of the unit there will be be a set of rca leads marked pre out run set of rca leads from these to the input connectors on your amp,you will also need to run a single wire from the wiring harness of head unit look for a wire marked remote (usually blue)run this to the terminal on amp marked remote ,you will also need a fused power cable run to battery +and a earth cable - screw this to metal part of chassis ,then run your speaker wires make sure + - symbols on speakers get connected to + - terminals for speakers on amp.
Posted on Apr 20, 2008
  • mossman12 Apr 20, 2008
    Also make sure the power cable is the right gauge or awg for the wattage of the amp your fitting ,crutchfied adviser has a handy table for working out what gauge you will require.
Color code for wiring harness on Panasonic cq-dfx301u
If you are needing a replacement harness try metraonline.com. they have many replacement harnesses available or try ebay.
Aug 09, 2016 | Panasonic Car Audio & Video
I am trying to hook up an amp to my panasonic cq-c300u but i cant find the remote wire in the back. does it even have one? and if not is there a way to add one?
If your stereo doesn't have an option for amp cut the RCA wire that you're going to use and connect it to the output speaker wires at the back of your stereo. You can also use crossovers.
Apr 07, 2011 | Panasonic CQ-C300U Car CD/ MP3 Player
Compaq CQ 62 Drivers
here is a link to each model of the cq-62 notebook.
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=4113092
good luck
Feb 27, 2011 | Computers & Internet
Panasonic CQ-C8303U. Hooked up an amplifier and it works with the radio but when i put in a cd the amp doesn't work. the receiver just plays with normal sound.
Verify your wire connections are correct. Keep in mind that if your amp is hooked up to the radios power antenna wire this is the problem. When you insert a cd the radio is designed to lower the antenna. If your amp is hooked up to the antenna wire the radio is shutting off the amp when you put in a cd Panasonic does this on most of all their units. You may have to hook your amp up to a separate switch to turn the amp off and on or hook it to your ignitions acc wire, if you hook it up to your ignitions acc the amp will stay on as long as your key is on even if you turn off the radio.
Here's a link to download the manual for your radio just copy and paste it in to your web browser and download the PDF file. You will need the reader to view it. If you don't have the reader you can download it for free at www.adobe.com
http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-C8303U
Oct 09, 2010 | Panasonic CQ-C8303U CD Player
Speakers in my vet dont seem to work
Yes, if your car speakers are ran through that amplifier that red wire (power wire) needs to be connected to the battery. I would make sure that there is a brand new, or clean terminal to connect to the battery. I usually use a ring terminal on the end of the power wire to connect to the positive battery post bolt. If you do not have a ring terminal on the end, you do not need one, but I do it for the fact that it is a cleaner installation and a certanty that it will not fall off the positive post. If you have any questions feel free to email me at stevieb1282@yahoo.com put subject vet amp no sound.
Feb 27, 2010 | Panasonic CQ-C1401U CD Player
Panasonic CQ-C8400U CD turns itself off after 9-10 mins
Hey did you ever get this problem fixed? My deck just started to do the exact same thing.
Nov 03, 2009 | Panasonic CQ-C8400U CD Player
I HAVE PANASONIC CQ-C700U STEREO PLAYS ON ALL
are you running the rest of your speakers off an amp? if so, it sounds like you have the amp remote wire connected to the power antenna wire. on some radios there is an amp remote wire and a power antenna wire. the power antenna wire loses power when not listening to the tuner (radio). usuall there is a solid blue and a blue with white stripe. the blue with a white stripe should be amp turn on.
Aug 19, 2009 | Panasonic CQ-C700U Car CD/ MP3 Player
How to unlock my panasonic CQ-DFX301U
You won't be able to unlock it without the code.
Jun 16, 2009 | Panasonic CQ-DFX301U CD Player
Panasonic CQ C1100U amp output?
Yes, the Panasonic CQ-C1100U can be connected to a 2-channel amp. It has a single set of preamp outputs. I'm attaching an image of the connection shown in the Panasonic user manual. The appropriate connection is the one without the dashed line. The dashed line showing a 2nd set of outputs only applies to the 1110, 1120, and 1200 models.
Hope this helps. If it does, please rate as "FixYa". Thanks!
Mar 30, 2009 | Panasonic CQ-C1100U CD Player
Panasonic cq-c7401u
If you using external amplifiers with you system;check your remote wires.
You may be using the wrong remote wire to turn you amp on.
There are two remote wires,one is for pwr ANTENNA(BLUE ONLY),this wire cut the pwr out when you insert a cd.
The other wire is the REMOTE TURN ON(BLUE/WHITE STRIPE)this is the one you need to connect to the you amp.
LET ME KNOW IF IT WORKS.
Dec 22, 2007 | Panasonic CQ-C7301U CD Player
Car Audio & Video Logo
91 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
