Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Wont run clockwise
My fan will not run at all when rev. sw. is in clockwise poss.
  • Hampton Bay Master
  • 17,130 Answers
Pleae check for the capacitor that is connected to the motor. if possible use a parallel capacitor to test before you detach. If the fault clearrs up then you must change the capacitor.
If this wont help check for power tto the fan from the regulator, check for winding continuity and insulation shorting. I hope the fault is within here. Helpful I hop. Good day
Posted on Jul 12, 2010
I bought a Fahrenheat FZL4004 replacing an older model) and it wont stay on. It comes on, heats, blows, clicks off, & must be manually reset in order to come on again. Help?
Here is the link for the owner's manual. Or call customer service at 1-800-654-3545. http://www.manualshelf.com/manual/fahrenheat/fzl4004/instructions-assembly.html
Mar 01, 2015 | Fahrenheat Heating & Cooling
How to set the high and low
Turn mixture screws completely in gently, then wind out 11/2 turns each. The saw will be able to start and run at this point. On idle wind Low clockwise till motor starts to die then anti-clockwise 3/4 turn.
High speed is a little more difficult, On full revs wind clockwise till saw starts to rev out (lean Mixture) then back till the sound starts to bubble.
Jul 26, 2014 | Husqvarna Garden
My cr125 wont idel after stating can it be ajusted.
there is a little screw at the back of your carb next to your air box. kick your bike over and keep little revs on screw it clockwise (in) then start so slowly screw it anticlockwise (out) till your bike starts to rev a bit mor then release your throttle and it should tik over.
Aug 07, 2012 | 2003 Honda CR 125 R
How to Diagnose a Cooling fan
if the fan doesnot run with the engine running and the A/C on poss bad fan or sensor or relay
Aug 25, 2010 | 1995 Honda Accord
Wiring diagram for a 3 way ceiling pull switch.
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
May 29, 2010 | Hampton Bay 24750 Huntington III Ceiling...
The fan on my Toyota Corolla is not running. I just changed the radiator and refilled the coolant. Shouldn't it run immediately I switch on? How can I tell if the fuse has blown?
What has the radiator got to do with the fan coming on? There may be a bad fan switch,screwed into the radiator,but you wouldn't change the radiator,only the sw ,if bad. You could jump the fan sw wires,turn key on, to test for a bad sw and a working fan
Mar 25, 2010 | 1990 Toyota Corolla
Fuel Air Adgustments .What they are Set at.& Which are which?
The air looks after itself when you operate he throttle. This how you adjust the fuel....There are two screws on the carby marked L and H. Turn these only 1/8th of a turn at a time. Start with H (high) with the saw at full revs. Turn anti clockwise untill you get max revs then turn it back a little bit. If its running too lean it will over heat the motor and damage it. Then if needed adjust the L (or Low)screw. If you get black or grey smoke when you push the throttle up from idle to full its too rich so turn clockwise. If if slows before it picks up to full revs turn anti clockwise.
Sep 07, 2009 | Garden
Replacing a 3 speed sw.
Does the fan work with direct wires to it? If it works then the switch is bad or your wiring is mixed up.
Feb 13, 2008 | Hampton Bay 04379 Madison Avenue Ceiling...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
