Question about Rheem 80 GAL ELEC TALL Water Heater 6YR SC 82V802
I just installed an 80 gal rheem tall water heater and now my hot water smells like rotten eggs.
  • 349 Answers
Hey check out this link that I found on this matter I hope will help you with this.
http://homerepair.about.com/od/plumbingrepair/ss/trblsht_hwh_5.htm
Posted on Jul 13, 2010
Egg smell from hot water
You either have water with a high sulfur content or need to flush your heater. you should flush your heater every year anyway. you can turn off the water and electric to the heater. and totally drain the tank when it is totally drained add more water and drain some more. then refill the tank and run a hot water faucet the tub is best to eliminate any air in the system then turn the electric back on this should solve the problem if it does not you probably have sulfur in the water and would need water treatment or filters to help
May 06, 2014 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
About every two months the the hot water gets a sour smell. To get the smell out I turn both elements all the way up for 3 hours then drain the water heater, its good for about two months. The water heater...
The smell is from bacteria. The high temperature kills the bacteria. Some regions require water heater temp to be set at 135 because of bacteria.
A test to determine if only the water heater is causing problem: Turn off water to water heater. Smell water coming out of cold tap. Turn on water to heater, smell water from hot tap. If only hot tap smells, then water heater is suspect.
Another way to handle the problem long-term, is to reconfigure cold water pipes so you can regularly pour in 2 bottles of hydrogen peroxide during your flushing procedure. Pour in the hydrogen peroxide and let it work for a while. And then flush tank as you have been doing.
You should read up on anode rods also. Many people replace anode rods when tank begins to get odor.
http://www.waterheaterrescue.com/pages/WHRpages/English/Longevity/water-heater-anodes.html
http://waterheatertimer.org/Replace-anode-rod.html
Oct 23, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Rheem RHEEM 50 GAL ELEC TALL Water Heater 1.5 yrs old, power at the elements, new elements installed new thermostat installed, still no hot water.
Hello Check the red overtemp reset button at the temp control.Check for contintuity at the elements with a volt meter (pull one wire off first) they should have a reading otherwise they are open & shot.Last is overdrawing (busted pipe) shut off the cold water supply for a 1/2 hour and open it back up and feel the hot water supply pipe.Is it hot?The tank can't keep up with the demand.
Sep 16, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
2 month old Lochinvar Electric 30 gal heater hot water has rotten egg smell. Do not have water softener system. Well water with a lot of iron.
is it a new well.......it may go away after a while...its sulfer....sometimes when you drill well too deep you get sulpher water......
Nov 16, 2009 | Emerson InSinkErator W-152 Point-Of-Use...
The hot water smells like rotten eggs., only the hot water
its the mag rod in water heater-if your not using alot of hot water,and water is sitting in heater it will smell like rotten eggs-u can remove mag rod from water heater.it is in top of heater-
Jan 08, 2009 | General Electric GE SmartWater Household...
Rheem 80 GAL ELEC TALL Water Heater 6YR SC 82V802 Logo
156 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
