Question about Brother SE-270D Computerized Sewing Machine
When threading my needle a small metal object came off the machine. Now it doesn't want to thread. I saw a spring and a small white plastic piece which went up into the machine (the piece that comes down when threading the needle) and the piece that came off looks similar to a presser foot but much smaller and thinner. I have a feeling it is the theader itself but not sure how to put it back in place. Please help..i'm trying to embroider names on bags for my Girl Scout troop. Thanks
  • 17,130 Answers
I am sorry that the small metal object has done some great damge to your base mechanism. Since the identity of the object you described is not very relevant , it cannot give much than to advice you to carrefully check inside for a jigsaw puzzle to be put in place. assuming that only the parrts were dislodged you can carefully out this in place to fit in. if there is damage or broken parts, I am afraid that you may need the brothere service centre help for the spares. Check out what you can and then call up. Helpful? Good day
Posted on Jul 12, 2010
I have a Elna excellence 7600. Why does thread keep breaking while chain stitching fabric?
Thread breaks
first check to see if there is an actual thread break, then check the threading-both needle and thread
Sometimes the machine will signal a thread break when there really isn't one, at least not technically. For example, a mis-threading can cause the thread break sensor to think there is a problem because it is not sensing the proper thread tension. This can also happen if a loop of thread forms suddenly resulting in slack in the thread.
a thread break signal are really a "thread out" indication most often triggered by an empty or low bobbin or the needle becoming unthreaded.
rethread the machine and correct any low thread conditions.
Actual Thread Breaks
Examine the thread break. Is it a clean snap or is it shredded?
Next, examine the thread path. Did the thread get caught on something
A common problem with embroidery thread is that due to its slippery nature, it can slide down the spool and get hung up underneath causing a sudden jerk on the thread. Rayons will probably just snap at this point but some poly threads may be strong enough to resist breaking and instead flex the needle resulting in a broken needle.
Metallic threads often cause more breaks and shredding because they tend to form loops and kinks as they come off the spool. This is exacerbated by small spools with narrow diameters and short thread paths from the spool to the first thread guide. A simple solution for this is to extend the thread path.
Thread Factors
Lets look a little closer at thread. Embroidery threads are more fragile than those used for garment construction or quilting. Start with quality thread and know how to care for it.
Embroidery threads can dry out when exposed to light, heat, drafts, and air conditioning. They can become "bruised" if dropped or handled roughly. As they age, they become more fragile. Due to dying and other processes, certain colors break more easily than others. Check this for yourself. Try breaking a white thread and then a black. Also notice that the black is slightly thicker than the white.
Rayon tends to break easier than poly. Metallics are more temperamental and finicky
Needle-Related Possibilities
On a single needle machine, if you are getting continuous thread breaks with multiple colors and you are sure you can eliminate the thread, then look at the needle.
Is it the right size? For 40 wt rayon or polyester thread, a 70/10 or 75/11 works well on most fabrics.
Embroidery needles have a slightly larger eye to reduce friction on the thread. High quality needles have a well-polished eye that won't snag, abrade, or shred the thread. The thread can pass through the eye of the needle 50 to 60 times before it is laid down on the fabric. Any rough spot on the needle or thread path can literally saw the thread in half
The broken needle is the least of your problem! If your machine doesn't stop the instant the needle breaks, it may severely damage your fabric. Needle breaks can cause scratches and rough spots on the throat plate and in the hook area that can shred thread. Until these problems are smoothed out, thread breaks will be your reality.
It is possible for the fabric and/or stabilizer to the source of thread problems. For example, heavy, stiff fabrics can easily strip some metallic threads
If the lower thread keeps breaking, open out the bobbin hatch and check that there is no lint buildup that is hindering the smooth flow of the thread. If there is any lint, remove the bobbin and clean the area thoroughly with a brush. Also check that the bobbin is wound correctly and that the tension of bobbin thread is even. Poor maintenance and incorrectly wound bobbins are the culprit more often..
Mar 22, 2016 | Sewing Machines
How do I change the bobbin in a Janome sewing machine?
There is a small plastic plate where the needle goes down through the foot, remove this cover and you will see the bobbin. Remove the bobbin and refill or selecting another bobbin turn it so that when you pull the thread the bobbin turns anti-clock-wise, slip the bobbin into the black plastic casing, pulling the thread towards the small red arrow at the bottom of the casing, slip the thread between break in the silver metal sleeve pulling it to your left between the 2 pieces of metal this is where the tension on the thread is. You have now changed your bobbin. With the plastic plate still off, hold the top thread with your left hand and with your right slowly turn the wheel, this will send the needle (holding your top thread) down into the bobbin casing and will pick up the bottom thread, pull on the top thread and bring the bottom thread up through the hole in the plate. Replace the plastic plate and recommence sewing. Good luck
Sue
Sep 24, 2014 | Janome Sewing Machines
Constant problems with tension and the thread breaking from the top threader
check your thread spool for a snag on the plastic. Sometimes thread will catch on that "thread keeper" and once it catches and jerks free, it can cause the spool to spin the other way thus winding the thread on the spool pin.
Another thing to check is to make SURE that when you thread the upper thread that the pressure foot is UP. While you have the pressure foot open, run a piece of unwaxed dental thread through your tension discs.
Also make sure that your needle is large enough for your thread. To test this take another needle of the same size as the one in the machine and clip a piece of thread about 6 inches long. Thread the needle ... grasp the tread by both ends... tip the thread side to side... if the needle doesn't move well, your needle is too small. If it moves well but not too loose...it fine.
Jul 30, 2012 | Brother XL-5700 Mechanical Sewing Machine
On a brother cs 8060 - as i pushed the thread compartment into the machine a silver metal forked thing flew off the machne hitting me in the neck. it has two pins one on each side and is actioned by a...
the piece that flew out goes to the piece that lowers with the wire. mine is having same issue but i saw mine right before it flew off. not quite sure how it goes back together.
Jan 07, 2011 | Brother CS-8060 Computerized Sewing...
I saw a white sm2000 in a thrift shop. it was in decent condition and the needle moved smoothly. I was wondering if this machine would be worth getting. I have reservations because of all the negative...
There's nothing wrong with the newer plastic sewing machines. Most of them are plastic now and not as heavy as the old metal ones. You said that the needle moved smoothly but what you need to know is if the needle thread picks up the bobbin thread. If you don't know how to thread the machine either check the manual or ask someone in the shop to thread it. If anyone there sews, they will know how to thread it. If the machine makes a stitch go ahead and get it. It the bobbin thread is not picked up by the needle thread IT WON'T STITCH and then you'll know that the timing is off. That's a repair job and will be way more than what you paid in the thrift shop.
Sep 09, 2010 | White Sewing SM2000 Sewing Machine
Missed stitches noise when it happens
Firstly, turn machine off then turn back on. Change needle. Re-thread the top and bobbin threads. Make sure you have not set the machine for a sideways stitch but you have been using a single stitch foot (recipe for Disaster!). BEFORE trying to sew, wind the machine by hand through a stitch or two (take the thread out of the needle's eye first) and look closely to see if the needle is in fact hitting something. If it is, then the needle needs re-centering and you will have to take the machine for repair to get this done.
Make sure the top thread is going into the tension disks. The presser foot MUST be up while you are threading. Hold onto the thread just as it comes off the spool and when you get down to the needle give a tug to be sure the thread is seated in the tensions before threading the needle. When you insert the bobbin, be sure the thread "clicks" into the tension slot on the bobbin case. Check the Sewing Advisor to be sure you are set for the correct fabric and stitch for what you are sewing. Have you cleaned out the bobbin area? Remove the clear or smoke bobbin cover, either use the tool provided or just press down firmly and slide forwards the metal feed dog cover (feed dogs down first), lift out the light grey plastic bit that half covers the bobbin case, remove bobbin case. Use the brush and clean out all the fluff from the bobbin area. Then check the bobbin case and clean it too. You can use a piece of strong thread or UNWAXED dental floss to clean out between the tension springs (the bit where the bobbin thread 'clicks' into). Reassemble the bobbin pieces in reverse order, making sure that when you replace the metal feed dog cover you push it all the way to the back and it too will 'click' into place. Hope something in the above works for you.
Dec 23, 2009 | Husqvarna Designer I
There is a small metal 'thingamajig' that the bobbin thread goes by when it sew and every so often the plastic piece goes by that metal thing and cause loops on the underside. why is it doing this?
Be sure that your bobbin thread is correctly placed, is the correct thread for the fabric, usually the same as the top thread, the needle is correct size for fabric. Correct tension - balance your tension, use new needle for each project and correct pressure. Have the machine cleaned-lint build up. Use new thread, sometimes old thread breaks down and creates skip stitches.
Jul 19, 2009 | Elna Heirloom Edition 6005
How do you thread a singer 9836c machine
I have this machine and the manual but it will be difficult to explain without the diagram. Here are the instructions without the diagram ... I'm assuming that you know some parts of the machine i.e. the foot etc
NB. thread the bobbin FIRST - points number 8 onwards....
1. Raise take-up lever to highest position on machine by turning the hand wheel towards you and make sure the presser foot is raised.
2. Place spool of thread on the spool pin at the back making sure spool cap is firmly in place to keep it on.
3. Take thread and place through the thread guide (plastic bit same side as spool pin) a under and over action. Across from this guide is a small metal wheel on top of another loop pin on the top at the front of the machine. Take the thread and put through the loop pin. 9Thread should come out on top of the pin towards you).
4. On the front of the arm is a tension wheel numbered between 0 - 8. The thread should then be placed down the front of the arm, underneath the tension wheel (behind the body part of the arm not under the wheel) and lifted up to catch the tension spring unseen behind the wheel. It should then be threaded through the eye of the metal piece (that moves as the needle goes up and down).
5. The thread should then be passed down the gap in the body work and down through the middle of the metal spiral loop in the front near the needle.
6. The thread should continue down through the horizontal clip just above the needle.
7. The needle should be place with the flat part at the back and held firmly with the screw. The eye of the needle will face you. The thread should then be threaded through the front and out the back and under the foot leaving a six inch tail.
Your thread should now come off the spool move towards the left through the plastic guide, across the top of the machine at right angles, through the metal loop; down the front of the machine (you can't see the thread as it sits behind the body) and reappears through the metal arm hole that goes up and down with the needle. It should then come down through the metal spiral and behind the clip above the needle, through the eye of the needle and away from you under the foot.
8. The bobbin needs to be wound. The bobbins are particualr to each make of machine. So only singer bobbins can be used on Singer machines. The bobbin winder is the metal pin on the right on the top of the machine.
9. To wind the bobbin. Place the bobbin over the metal pin nad push firmly down. It is located on the top on the right hand side.
10. Place thread on the spool pin as before and thread the cotton through the plastic thread guide.
11. Take the thread as before but rather than going through the metal clip on the top at the front, place it anti clockwise partly round the metal wheel on top of the metal clip (don't go all the way around) and across to the right where the bobbin has been placed.
12. The thread should be wound clockwise as many times as required not to slip off when the thread is automatically wound with the electic foot peddle.
13. Push the bobobin manually to the right along the groove in the body and press the electric foot peddle. Bobbin should wind moving the thread up and down (not necessarly evenly) and filling the bobbin. Fill about 80%. Leave a six inch tail.
14 Pull the plate forward under the needle. Place bobbin in its slot. The thread should be in a clockwise direction and when the bobbin is placed catch the thread under the groove found on the left at the top of the bobbin case. Close the plate with the thread coming out above in the slot under the needle.
15 Manually turn the hand wheel a couple of times until you can see the bobbin thread making a loop with the stitch thread and pull through.
16 Both threads should be under the foot and away from you.
17 Tension normally is around 5 -6 on the tension wheel with standard cotton and polyester cotton thread. To tighten the tension the number should increment upwards.
Machine is a cracker and according to my local shop never goes wrong. I have had mine since 1999 and that's true.
Hope this helps.... I would send you the manual but I'm not sure how you keep email addresses private.
Good luck.
Jun 29, 2009 | Singer Sewing Machines
Parts fell out
WE FIXED IT!!!!! Ok my fabulous husband fixed my automatic thread foot last night and now I am sewing away. Here is what he did best I can describe. when you engage the thread shuttle, a piece comes down from the right of the sewing machine. I has a spring on the back and a very thin piece of wire with a white plastic moving part. the foot has to snap under the white plastic thing... so you have to very carefully take the white thing out of the track and then put the foot in. the bar side with the larger metal pin goes here and the foot should be facing towards the needle. Hope this helps and if I didn;t explain it well please leave me a note and I will try again :)
Apr 18, 2008 | Brother SE-270D Computerized Sewing...
Threading machine
The machine is relatively simple to thread. This is what I do and I've had no threading problems. 1. Put thread spool on the spool pin and put spool guard over spool pin to hold spool onto pin. 2. Take thread and put it under the bent tab by the circle tensioner. bring the thread around the right side of the circle tensioner and bring around the front of the circle tensioner thing back to the top hook on the far left side of the machine. 3. Take the thread around the backside of the top hook think until it threads through the flat piece on the left side of it. 4. Bring the thread down through the first (right side) channel and under the plastic piece to the second (left side) channel. 5. Bring the thread up the second channel and around the moving thread holder and past it's flat metal piece to hold it. 6. Tuck the thread around the small wire thread holder below the needle screw. This may take a few passes to catch it. 7. Thread the needle from the front and run the thread between the teeth of the presser foot. 8. Put a bobbin in the bobbin case so that the thread pulls off the bobbin from the left side of the bobbin if you look at it from above. 9. There is a small channel in the bobbin case that is covered by the bobbin tension flat piece. Pull the bobbin thread through this channel and into the empty space where the needle thread will catch. 10. Place the bobbin case into the machine with the little set bobbin arm pointed to the sky so that it fits into the machine without wiggling to the right or the left. 11. Turn the, uhhh brain fart, the hand wheel until the needle comes back up with the bobbin thread hooked over the needle thread. Take a narrow thing, like scissors or a seam ripper and pull both threads until the bobbin thread comes up. Now your machine is threaded. Use these directions with the pictures in the book to get this machine threaded.
Dec 11, 2006 | Euro-Pro Fast and Easy 420 Mechanical...
Brother SE-270D Computerized Sewing Machine Logo
82 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
