Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
New machine, will not run,idles roughly ~ 5-10 seconds then stops.
    Sniper:
  • 56 Answers
Problem is...the factory adjusts these machines for a sea level situation.....if you live at any altitude at all they need to be re- adjusted....these things never work right out of the box....sounds like your engine is starving for fuel...a lean condition...on the side of your carb toward the front of the engine you will see two small adjustment screws....one marked H, and one marked L, these are your high speed adjustment and low speed adjustment accordingly. start with the L adjusment screw ( the one nearest the engine) and turn the screw counterclockwise in small 1/8 turn increments until a smooth idle is achieved....then throttle up the engine and see if it stalls. If it does do the same with the H adjusment screw ( the one nearest the air cleaner) until you get a full throttle response. If your machine is like mine, it has screw heads that require a special tool to turn....it is available on ebay for about 10 bucks....google "ryobi tools" and you should find it ...the screw caps are plastic so if you don't want to buy the tool you can do as I did and saw slots in the screws to allow you to use a fine point screwdriver to adjust the mixture screws...just remember...turn the screws counterclockwise = more fuel, clockwise = less fuel ....hope this helps ;-D
Posted on Jul 16, 2010
  • 718 Answers
If is NEW than just take it back where you got if they cannot remedy the problem they will give you a new one, simple do not try to be a mechanic when you do not have to. Customer is always right remember this, if not ask for a manager and raise your voice and you will see what happens. Ask your wife or better half about returning things,anyway Good Luck PAL
Posted on Jul 12, 2010
Rough Idle on 1986 GMC Jimmy.
change your some sensors that can probably cause your engine to run rough, ask you local oarts store for more info...
Aug 21, 2009 | 1986 GMC Jimmy
2002 chevy trailblazer has rough idle
it could be an o2 sensor. it could also just need a tune up
Mar 15, 2009 | 2002 Chevrolet TrailBlazer
94-4runner idling rough when at a stop
your fuel pump is geting bad replace it asp
Dec 28, 2008 | 1994 Toyota 4Runner
Rough idle stalls at low rpm's
hello first check your idle with the car running foot on brake see were your rpm reading is if your below 500rpm check your label underhood for your curb idle setting second see if theres a adjustment screw you can increase were your gas cable lever rest against your set screw underhood if you feel confident enough remove your iac motor idle air control valve if the bore were the end of the pintle extracts out to close has varnish builup our carbon it will stick creating vacuum leak type senario causing stalling rough idle sometimes even no start conditions good luck
Sep 14, 2008 | 1988 Honda Accord 4 Door
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
490 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Gene Tuck
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
