Question about Singer Sewing Machines
Foot pedal is getting extremely hot
I have a singer overlocker/serger, the foot pedal gets extremely hot. I returned it when I first purchased it and was told by the technician that there was nothing wrong with it. When I use it, it smells like something is melting/burning and the base of the pedal gets too hot to touch. the technician told me this was NORMAL. I have not been using it as I am scared it will catch fire, even though I have only used it twice obviously the warranty has expired. does anyone else have this problem with there singer.
  • 17,130 Answers
I would suggest that you do not use the pedal. there is no chance that the foot pedal has to heat up. this is an anomaly and checked within. open the pedal and look inside. you will locate a switch/ circuit. If there is heat building up remove the mains connection and test carefully with you finger for the heat build up area. Also smell for any burning. You will get to the fault with no difficulty. If not replace with a new pedal.Try to send a mail to your singer dealer with the fact that it is unusual and dangerous. I am sure they will replace it for you fearing any accident. So check this out. hope my advice helps. Good day
Posted on Jul 12, 2010
The foot pedal won't turn the hand wheel singer simple 2263
Sounds like there's a problem with your foot pedal. You can purchase another at SewingPartsLine for $27.00. Here's the direct link http://www.sewingpartsonline.com/foot-control-and-cord-singer-359102-001.aspx.
Feb 05, 2017 | Singer Sewing Machines
How to set Bernette serger 203 for rolled hem
Be sure you have the proper foot for your machine to make a rolled hem.
Bernette 203 How to use rolled hem foot have the one page manual but it...
Sew Inspired Serger Rolled Hem Tips
In case you don't have a manual, you may be able to glean some information here:
Sergers Overlockers
need manual for the Bernina Bernette 203 overlocker
Aug 31, 2016 | Bernina Sewing Machines
Do you have a foot pedal for Singer 2210?
Your foot pedal works on several models of high-end machines, including a Bernina. Unfortunately, while you can easily purchase a replacement at several sites, it's pricey. However, I took a look on eBay, and there's one for sale there for $50, which is much better than $149, which is the list price. Here's the link
http://www.ebay.com/itm/Singer-2210-Quantum-DSX-DSX-II-LE-XL-1000-XL-5000-XL-6000-Foot-controller-/261741269436?pt=LH_DefaultDomain_0&hash=item3cf0fed1bc
Jan 21, 2015 | Singer Sewing Machines
I have a brand new Singer Pro Finish Serger and it won't sew. When I press on the pedal it makes noise, but the needled do not move. Nothing else happens.
are the cords for the power & foot pedal plugged in correctly?
the only thing I can suggest is taking the machine to a sewing machine shop
to be checked
or check on youtube or ehow that can help you
Apr 12, 2012 | Sewing Machines
My serger doesnt make any stitches at all. I have been going through this book for 3 years and I cant get it to work
Has it ever chained off since you bought it? If you purchased it second hand it is possible that the timing of the loopers is out and this will prevent a chain from forming.
However, I'll go through general overlocker/serger troubleshooting for threading up. The critical things are to thread it exactly as the diagram shows, some sergers have a diagram inside the front looper cover so its easy to refer to when you are working on the machine. Or use the manual diagram. There is a sequence you need to follow in threading up, usually upper looper, lower looper, then the needles. This is important. Then you pull all four threads under the raised pressure foot, lower the pressure foot, and start to stitch and hopefully a chain forms. If you need to change a thread you can knot on a new colour, turn the tension to zero, then pull through the new thread. Pull the knot right through the looper eyes but you will need to cut the knot out and thread the needles with the new colour once you get there. Then turn tension back to the normal setting (5 usually) and again pull all threads under the foot.
The timing of the two loopers to the needles is critical to a stitch forming though so if you have tried everything and aren't getting a result; then perhaps its time to take it to a service centre, get it checked out and if it works fine for them, ask for a quick demo of threading up, then do it yourself with the demonstrator watching.
Overlockers are very different to sewing machines and there is a learning curve but once mastered, they are so quick and give a great finish.
Oct 08, 2011 | Singer 14SH654
I've just got janome 634d serger, how can i make the bottom of a T-shirt ? Thank you so much
If you want the bottom of the T to look like RTW with the double row of stitching, you cannot do this on a serger.
You can achieve the effect by using a twin needle, two spools of thread, bobbin and a straight stitch.
Make sure the double/twin needle will pass through the presser foot and opening in the needle plate below the presser foot.
Practice on a double layer of a scrap of the T shirt material as the tension may need to be slightly looser than the normal setting.
Apr 05, 2010 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
306 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
