My Toshiba 32" analog tv, which is three years old, seems stuck with the volumen on high, and won't turn on or off by switch, only by plugging and unplugging the set. Thanks.
  • 1 more comment
  • trepym880 Apr 20, 2008
    Isn't it too coincidental that the on/off button doesn't work, and the volume is stuck? I should mention that the volume could be manually raised, but then it went down by itself. Next time I tried it, the volume was stuck in high, and its stuck there. I can't manually lower it. The tv comes on automatically when its plugged in. Still think its the control panel sticking? Thanks.
    Isn't it too coincidental that the on/off button doesn't work, and the volume is stuck? I should mention that the volume could be manually raised, but then it went down by itself. Next time I tried it, the volume was stuck in high, and its stuck there. I can't manually lower it. The tv comes on automatically when its plugged in. Still think its the a loose part on the board? Thanks.
  • trepym880 Apr 21, 2008
    Powwer doesn't work on either the set or remote. The volume doesn't work on the remote, but sometimes will on the set. The volume now is stuck in high, and the button on the set won't work to lower it. Thanks.
  • 19,396 Answers
You need to open the control panel try spraying the switch with contact cleaning solution. If this does not work you may need to replace the touch buttons or the control board
Posted on Apr 20, 2008
  • 3,037 Answers
Most likely there is a loose part on the board, check for loose connections and then you should just have to solder a point back together.
If you don't feel comfortable checking the tv, then you will need someone with experience to check it for you. Please let me know if you have any further questions.
Thank you for using Fixya and Have a Good Day
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 20, 2008
    Alright to further help you I need a little more information
    I need to know if the volume and the power button work on just the tv, the remote, neither, or both.
    Please answer the question and I will tell you what I think
    thanks
  • Benjamin Patri
    Benjamin Patri Apr 21, 2008
    this could be the power supply or the convergence circuit doing this
    The easiest thing to try is a simple hard reset which is just leaving the tv off for 4 hours and then trying it and seeing if it fixed itself
    you then can check for loose connections on the board, shorted out fuses and see if you smell anything that may be burnt. If you know what you are doing, basically test everything to see if power is running through if you can't find a loose connection.
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
Can you connect a hd converter to a Toshiba cx 32 g60 tv
there isn't much point in connecting an hd converter the toshiba cx32g60. the tv can only support an sd signal (composite video or ntsc analog). however, many hd set-top boxes (dvd players, cable and satellite) have composite outputs. these can be connected to your tv. blu-ray videos can't be watched with this tv. (the hdcp (high definition copy protection) can't be sent through most converters.)
if you want to watch ota programming , the cheapest option would be to find an sd digital-to-analog converter. these were the ones sold when most stations switched to digital tuners. some are being sold off as people replace their old analog sets. there are some hd tuner boxes, like this one: http://www.solidsignal.com/pview.asp?mc=03&p=3500stb&d=iview-hd-dvr-receiverconverter-box-for-tv-antenna-qam-%283500stb%29&c=digital%20converter%20boxes&sku= , that have composite video output which will connect to the cx32g60.
i hope this helps.
cindy wells
(if you tried an hdmi to component video converter followed by a component to composite video converter, the signal may degrade excessively.)
Jan 22, 2015 | Toshiba Televison & Video
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
I have a Toshiba 26AV502R tv, was working yesterday and now it won't turn on? It's about a year old. What do I do to fix this?
the only thing you can try to do: unplug TV, let it "reset" for a minute or so, then plug it back in. If that won't help, means: surrender to repair service. for 1 year, even with 24/7 usage, there is a slim chance for "bloated" capacitors inside of TV's power supply, but quite a good chance of your main board failure. Now a days they quite compact, packed with high temperature producing IC chips, led-free solder, which has drawback of "fatigue" failure. Or, there might be power surge involved. In any case, except "lock up", appeal to TV repair service.
good luck,
Alex's Television,
215-806-5980.
Jul 16, 2011 | Toshiba 26AV502R 26 in. LCD HDTV
My tenplus year old Toshiba 32" TV is stuck in standby mode
You have an old tv so the best problems are bad capacitors and bad grounds. Have someone pull the board and search for high voltage caps [160volts or 250 volts] with 1 to 4.7 microfarads. Should be two or maybe three and check all grounds. If the 4 amp fuse is good than the above will save your TV.
Sep 24, 2009 | Toshiba 32A33 32" TV
I have the Toshiba TV/DVD Combo less than 3 years old
check thje following
the power reaching your switch via a fuse and power out of the switch, when switched on.
if the power is leaving the switch okay then check the power supply components
semi conductors, for leaks and shoots, zener diodes, and capacitors for variations and change of values especially electrolitic capaciturs. if you get a high voltage of 85 and above going to the transistor near the transformer, then check your line trasistor.
Aug 18, 2009 | Toshiba MD20F51 20 in. TV/DVD Combo
Toshiba 32D46 - White Lines at Top Of Display and TV Not Turning
Ok, so know you own an LCD or Plazma set, visit the dumpster where your Toshiba is or perhaps your basement just for old times sake..
May 30, 2009 | Toshiba 32D46 32" TV
Can not turn TV on
Failing power supply. It's 14 years old.
Feb 19, 2018 | Toshiba MD14F51 14 in. TV/DVD Combo
TV Problem!
1-confirm sound level in tv is high.
2-confirm sound level in sound source if it is excit is in high level.
3- confirm that you did not plug any jack in headphone socket if it is exict4-remove power cord from outlet and remove the rear cover.
(often 4-6screws).4-go away far from right side of main board(because it is danger area!!!!!!!!. .
5-check for loose connector in the speaker and reconnect.
do not go any more for your safety.
Mar 05, 2008 | Toshiba 32A42 32" TV
Toshiba 37 inch tube tv wont turn on
Any set that won;t turn on is probably due to a power supply converter which has burned out switching semiconducors. The first thing to do with a set which will not turn on is to check out all the switching gear (ie switchmode converter circuits) and all associated drive and driver semiconductor devices. Once you've done this you will usually find the problem.
Dec 13, 2007 | Toshiba 32AF43 32" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
