Question about Dell Computers & Internet
There is no audio device due to which computer does not produce any sound what should i do now
  • Dell Master
  • 32,281 Answers
You can download the audio drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows XP or Vista version of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Posted on Jul 12, 2010
Can't get the PC to produce sound. Have connected
Hi look at my tips on the link below:
http://www1.fixya.com/support/r9160787-no_audio_sound
If none of them help add a comment and I see what I can do.
Sep 24, 2011 | Computers & Internet
What is audio drive
In computing, a device driver or software driver is a computer program allowing higher-level computer programs to interact with a hardware device.
A driver typically communicates with the device through the computer bus or communications subsystem to which the hardware connects. When a calling program invokes a routine in the driver, the driver issues commands to the device. Once the device sends data back to the driver, the driver may invoke routines in the original calling program. Drivers are hardware-dependent and operating-system-specific. They usually provide the interrupt handling required for any necessary asynchronous time-dependent hardware interface.
Dec 17, 2010 | Computers & Internet
The right speaker produces almost no sound
This can happen due to several reasons.
You just check whether th wire got bend . It can happen due to that.
-rate if it helped you.
Apr 08, 2010 | Bose Companion 2 Series II Multimedia...
Pci device drivers are not installed on my system i dnt know how to install. due to this my audio device is not working
Installing Sound/Audio Cards and Drivers Sound or audio cards, whether it is a stand-alone device inserted into an expansion slot or embedded sound controllers in the motherboard, require specific device drivers in order to function and produce sound. This low-level program is responsible for processing the data between the sound card hardware and the operating system.
Most sound cards are bundled with the appropriate installation CD when purchased. This disc contains a database of the manufacturer’s available sound device drivers at the time of purchase and includes the specific driver intended for the card purchased. Most discs have an autorun installation program that prompts users to start installation. Some only provide a database of drivers and let the Device Manager or Add Hardware applications in the operation system perform the task of installation.
If you dont know the type of driver that you have, please check the following link to help you:
http://www.drivershq.com/driver-update/audio-and-sound/
I hope this is helpful.
Mar 17, 2010 | Computers & Internet
No sound
Its real Funny monitor dont need driver to produce audio it needs connector and if you hvent manual here it is and find how to. You need audio cable. But if drivers arent installed on your pc audio computer dont produce audio and monitor also cant "say" anything. Find device magager and ensure that every device works correctly. If not wrire motherboard model and name and post then I find drivers for you.
Aug 01, 2009 | HP Compaq WF1907 Monitor
My pc does not produce any sound when i am on or off the pc then have also no sond produce
1/ look on device manager sound is stall or not (right mouse click onmy computer click on device manager) 2/ type on run-"control" then click sound and click sound and divece and check setting.3/ reinstall sound softwere of board cd. if not correct, keep sound card to check on bord ()sound card isnot damage?
Jul 10, 2009 | M-Audio Audiophile 2496 Soundcard for...
My laptop doesn't produce any sound.
Did you check start->control panel->system->hardware tab-> device manager and see if there are any errors related to your sound drivers? Probably see a yellow exclamation
Jun 10, 2009 | Compaq Audio card Sound Card
Speakers not working.
The easy way to trouble shoot sound problems is to plug the speakers into another device like a portable player and see if they produce sound. If you had sound from your portable device but no sound from your speakers then your speakers have died. You can see if the computer is producing any sound by pluging your headphones from the portable into the computer and see if you have sound.
May 01, 2009 | Audio Players & Recorders
When I try to play an audio file on my computer, it says that it seems that no sound device is installed or working on my computer. What's a sound device and how can I solve this problem ?
a sound device is a dedicated board the fits in a free PCI slot(inside the PC) and produces all of the sounds once connected to a set of speakers, hifi unit,some newer PC's come with built in sound cards
not all cards are the same quality some are standard stereo and some are full theatre quality(dolby,THX etc)
so its wise to find a solution for your needs as many aspects of newer cards may never be needed
maybe you have a sound card in your system and have not yet installed drivers if you right click on my computer(on desktop) and use the properties in the menu,you will see a new box ,goto the HARDWARE tab and then the DEVICE MANAGER tab
click the + next to sound,video,gamecontrollers
if u see any mention of an audio device right clickit and select UPDATE DRIVER
but remember a sound card must be connected to speakers or a hifi unit to produce the sound
Jul 27, 2008 | Audio Players & Recorders
Computers & Internet Logo
13 people viewed this question
Alun Cox
