Question about Whirlpool Duet GHW9150P Front Load Washer
After doing a load of laundry, the machine won't drain
Did a load and their was a small pool of water. I then ran a load with out laundry just through the drain and spin cycle and it continues to leave a pool of water.
I also need to know how to open the front panel. Perhaps something is clogging the drain pipe...
  • 5,911 Answers
If your Whirlpool FRONT LOADER is leaking, the following link can give you guidance on how to inspect the washer to determine where the source of the leak may be coming from:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Most commonly, the source of the leak comes from the door bellow (gray rubber seal). They do wear out with age and can develop small rips and tears. A routine inspection of the perimeter of the door seal can determine if you have any holes. If the seal is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
The manufacturer recommends that you leave the washer door open between washes to prevent the seal from becoming permanently stretched. Once the seal stays compressed constantly it can stretch and not seal properly. In addition, leaving the door open helpd let the wash tub air out and prevent mold, mildew and musty odors.
If you suspect you have an obstruction somewhere in the drainage system, the drain pump reservoir needs to be cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage these small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Posted on Jul 12, 2010
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Water not coming into tub just makes clicking sound and FH code
I think the solenoid operated inlet valve has failed, for which ever inlet is turned on. This is a very common fault.
May 11, 2015 | Washing Machines
Water seems to be leaking from the bottom of my Maytag washing machine. Machine set for a large load. Water stopped, I added the detergent and then the soiled laundry. I went to get other laundry I had...
unplug washer. pull washer to you, have someone tilt the washer back and get a flash light and look for water spots on water pump,your drain hose,could be aclanp or just a hose we hope.
Sep 17, 2011 | Washing Machines
Clothes wet after spin
Hi, if clothes are wet after spinning, check.......
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Apr 13, 2011 | Whirlpool LSR8433K Top Load Washer
After the clothes have spun dry, a small amount of water accumlates in the tub; generally 1/4 inch or so. Why BTW, I'm not sure that I've selected the correct model. Our washer is about 3 years old.
If draining into laundry tub, chances are water is siphoned back into washer due to laundry tub slow drain.
Very long drain hoses( such as 10+ feet) will also cause this.
Nov 05, 2009 | Fisher and Paykel IWL12 Top Load Washer
Softner Compartment won't drain
this may be a faulty valve that allows the water to fill the softner compartment.to check the draining capability remove the drawer and take it to a sink make sure it remains level you you sink tap or a cp of water and fill the compartment almost to the top and it should start draining once it starts to drain stop putting water in and watch it. it should finish draining by itself there will be some water left in it but only a small amount. if it does not drain clean it out.
Sep 24, 2009 | Samsung WF337AA Front Load Washer
How to drain water after laundry?
at the bottom of the washer is instructions on how to drain the water inside the washer. A small hose is contained at the bottom right hand corner with a white plug (you need to pull on it hard). Once you remove the plug from the small drain hose it will drain all the washer water.
Before you do all this make sure you disconnect the electrical wire or turn off the breaker switch to the washer machine.
Dec 22, 2008 | Samsung WF337AA Front Load Washer
Will not drain
It spins, but doesn't pumpIf your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Nov 30, 2008 | Kenmore Energy Star 44092 Front Load...
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Does not drain & makes a loud buzzing sound(KENMORE 44042)
this sounds like something has gone into the pump, coins or whatever, the objects need to be removed, also check the hoses, remove the plug to work on any appliance the buzzing is the pump trying to work but unable to go round, start there and see how you go if i have helped rate me please
Sep 12, 2007 | Kenmore 44042 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
118 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
