I have a whirlpool washer lxr7144e01 the water drains out but it wont spin. It looks like the drum is not sitting level anymore. You can hear something runing under the drum.
    President:
  • 2,702 Answers
The drum support spring/s have come off,,letting the drum drop a few inches,,take the top or back off and the support springs can be put back on or new ones fitted,,the springs fit into the top of the washer case and hook onto the drum
Posted on Jul 12, 2010
Washer won't drain or spin.
What to do when your washer won't spin or drain water ...
? 2:23
https://www.youtube.com/watch?v=oFB1jEdXVsQ
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't spin or drain water ...Washer Repair - Not draining or spinning ...
Maytag, Whirlpool & Roper Washer Diagnostic - Water Does ...
? 6:33
www.youtube.com/watch?v=diRuMkf9_Vs
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Fix your own Maytag Top Load Washer which has some of the following ... Troubleshooting Why the Washer ..
Oct 31, 2015 | Maytag MHWE450WW - Performance Series HE...
My whirlpool commercial washer is not draining properly. The close is extremely wet but there no excess water in the drum. what could cause this issue?
Sounds like the water drained but the drum did not spin. Select spin and see if the drum actualy turns. If you hear a motor running then it could be just the drive.
Oct 03, 2014 | Washing Machines
I have a Whirlpool Cabrio Washer Model # WTW5600XW1, When placed on normal wash cycle, washer skips the drain and spin cycles, and no error code flashes?
If the same fault comes on other programs then it can be due to the controller board.However you can check the drain filter and pump , check inlet water flow to the drum and also check if the water level sensor is working to the set level.
Jan 23, 2013 | Whirlpool Washing Machines
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer wont spin during spin cycle everything else appears ok.
Machine not spinning....check]
1..all water gone clean pump trap and check blocked drain
2....somehting stopping drum spin drum freely by hand.
3....too much soap use low suds soap and very little of it.
4....motor brushes wearing out...call for service for this one.
Good luck
T
Aug 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Will drain but wont spin
Try these
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion......
Jul 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Water drains during wash cycle. I have used this washer for many years without a problem. About two months ago I noticed that the water level in the drum was going down during the wash cycle. Last week I...
Take the drain hose out of the drain pipe and put it into a sink to test the machine
If that works make sure that the drain hose is being allowed to breath (ie let air into the main drain pipe so that the machine does not set up a syphon).
Jul 16, 2009 | Whirlpool Washing Machines
My whirlpool awz410 is not spinning
if its draining while its filling ,raise the drain hose higher than the water level and it wont syphon.
May 01, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
