Question about Fuji Cameras
Finepix f450, My lens will not close. I've taken out the battery, charged the battery. What do i do? Thanks harry
  • Fuji Master
  • 17,130 Answers
If your battery is testing good make sure of this or replace as a poor voltage/current factor may be causing the shutter not to get enough power. If this hold good then check if there is any physical damage specially if any sand had gone into the covers. if so use a good air blower to clean and sray out any dust /dirt. if this wont work then you have a serious issue of the shutter/ lens coverr mechanism having a fault. You will need to open only if confident of such work. check for failue of the electronics. power to the circuit or mechanism defect, motor failure or blocks. check using a good magnifier be very careful , do not tamper if not confident. Good day
Posted on Jul 12, 2010
My fujifilm finepix s8500 will not turn on and the light flashes red when i try to turn it on
Always be sure the battery is charged and suited for your camera.
Check contacts of the battery and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth, Or a cotton swap. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the battery before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Never use manganese (Zinc-Carbon) batteries in your camera.
Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
When, while shutting down, the lens got stuck, the camera won't see it on the correct place when switched on.
When you are sure you have good and charged batteries with clean contacts, reinsert the batteries and switch on again.
If that does not solve the problem, switch the camera off and feel if al slight pressure on the lens barrel, will help the lens go in. Never use force, because you can damage the lens motor or the gears.
May 26, 2014 | Cameras
Hi, I have had my Finepix 6900 Zoom for more than
A camera (or any electronic equipment) at ten years old is nearing the end of its useful life. Best to replace it with a newer updated model
Mar 29, 2017 | Fuji FinePix 6900 Zoom Digital Camera
Hi there. A mystery error shows the Display of my Finepix S2 pro. Its like that: "o - -" or "o _ _" in the upper Display. Has anyone an idea for that? Best regards, Harry
Try resetting the camera by removing the battery for 15 mins. Replace the battery then go to the camera's Menu and scroll through the settings to set the Date and Time.
Apr 18, 2013 | Fuji FinePix S2 Pro Digital Camera
My finepix s3400 will not turn on. I've tried almost everything and I'm really annoyed. Is there something i can do to fix it?
Mine wont turn on either, the battery is fully charged and inserted properly. I can tell this as the pre-flash light comes on but nothing else, the only way to get the pre-flash light off again is to remove the battery.
Mar 08, 2012 | Fuji FinePix 3800 Digital Camera
I have a Finepix A345. When its turned on, the motor will not push the lens out and open the shutter. Nothing happens and no pictures can be taken.
OK you are probably going to think I am loony giving you this advise But No I am completely sane! First make sure the battery is fully charged, Then....
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep the service online
Aug 31, 2009 | Fuji FinePix A345 Digital Camera
Camera was dropped in water for just seconds. It won't change between modes: play, video rec, and still shot. It is constantly in still shot mode. The battery dies quickly. I bought a new battery and it...
Water has got inside the camera and is causing the problems you have stated.
The battery is discharging quickly due to the water damage and the pictures you are able to still take have symptoms of over exposure, most likely caused by water in the lens.
The cost to try and repair would almost certainly match that of buying another camera. Just depends on who you send it to to have it looked at.
Aug 27, 2009 | Fuji FinePix F450 Digital Camera
Fuji Finepix F450 broken LCD
Possibly search ebay for broken cameras of the same make or replacement parts. Fuji's contact center may sell parts or possibly fix your camera for free.
http://www.fujifilmusa.com/support/ServiceSupportRepair.do
May 26, 2009 | Fuji FinePix F450 Digital Camera
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Fotos are white
Try the video. Is it ok?
Adjust the zoom so the internal lens is up close to the outside lens. Now, look into the lens at an angle so you can see into the lens without reflection. With the flash "off" so as not to blind you take a picture and watch the shutter close over the lens. Did it cover the lens? If not then something is obstructing it or there is an electrical failure with the electro magnetic switch operating the shutter.
Apr 24, 2009 | Fuji FinePix S6500 Digital Camera
Fuji F10 No power
You said that you changed the battery, did you put it in the right way around?.
I had exactly the same trouble, changed the battery (got it on ebay for £2.99) charged it and it worked.
Having said that, I closed the lense from external power. If the camera wont operate from external power then the camera is probably dead.
Sep 13, 2008 | Fuji FinePix F10 Digital Camera
Cameras Logo
200 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
