When I press the power button on my Everex computer; nothing happens. It's not getting any juice. Even the cd door won't open. Is there a fuse inside the computer that may have blown? Or is it likely the power button switch component? Could even be the power cable but that doesn't seem likely. It's an older model prior to 2003. Any guesses?
  • Computers & ... Master
  • 5,660 Answers
Diagnose.
1) Make sure the surge protector your computer is plugged into, has power.
Could be the surge protector isn't any good.
Could be that the wall receptacle the surge protector is plugged into, doesn't have power.
2) Make Sure THE receptacle IN the surge protector, that the computer is plugged into, has power.
I have had more than one surge protector in the past, where just THAT receptacle the computer was plugged into, was bad.
"Hmmm, power on LED light of the surge protector is on.
Monitor, printer, and router plugged into the surge protector have power."
If this holds true for you, remove one of the peripheral's power cables out of it's receptacle in the surge protector, and plug into the receptacle the computer is using.
[A monitor, and a printer are two examples of a Peripheral]
Make sure THAT receptacle has power.
3) Bypass the Power On switch, to see if the problem is the Power On switch, or the Power Supply.
If I were to hazard a guess, my hypothesis would lean towards the Power Supply.
Power Supply failure, is one of the leading causes of computer failure.
Causes for Power Supply failure are generally,
A) Computer is dirty inside, as well as the inside of the Power Supply.
Dirt, dust, hair, carpet deodorizer, you name it, is 'inhaled' by the fans of the computer. No matter how good a housekeeper a person is, the above mentioned 'gunk' is going to get inside.
This 'gunk' is drawn through the computer, and drawn into the Power Supply.
[Computer case fans draw air into the computer from the front, or side.
The air is 'exhaled' through the rear of the computer.
The Power Supply fan draws air into the Power Supply, and pushes air out of the Power Supply, towards the rear of the computer.
Computer case fans in the rear of the computer also push air out.
A typical ATX style of Power Supply,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4236686&sku=C13-2507
This 'gunk' coats the cooling components of the computer, and drops the cooling capacity of these components tremendously.
Heat = Wasted Energy
When the cooling components of the Power Supply, (The fan of the Power Supply, and Heatsink's which are used inside), are coated with 'gunk', the Power Supply heats up.
The more heat, the more the Power Supply strains to keep up with the call for power.
Eventually components inside the Power Supply fail, and the Power Supply itself fails.
The inside of the computer, as well as the inside of the Power Supply, should be cleaned on a regular basis as needed.
The computer should be unplugged from power, computer case open, and Anti-Static precautions followed before using the air.
[Q-tips can also be used to help remove a heavy buildup of 'gunk'. The Q-tips are just used to break the 'crust' of the gunk, and the can of compressed air can then remove it]
B) Low quality Power Supply
Low quality components are used inside the Power Supply.
1) Gauge (Size) of wiring is too small.
2) Low quality Electrolytic Capacitors
3) Low quality Rectifier Bridge
4) Low quality MOSFET's
Just to name a few components.
Everex seemed to be a quality manufacturer of pre-built computers, from my research.
They typically used generic Power Supply's that were of average quality.
(Management of the company seems to have been Everex's downfall)
If the Power On switch is bypassed and the Power Supply comes on, the problem is the Power On switch.
[One generic Power On switch that I have found fits many computers,
http://www.directron.com/atxswitch.html ]
If the Power On switch is bypassed, and the Power Supply does NOT come on, the problem is the Power Supply.
The Power On switch is bypassed, using a jumper wire in the ATX main power cable connector.
[Has nothing to do with the Power On switch directly]
I don't know if your model of Everex computer used a 20-pin, or 24-pin ATX main power cable.
Typical 20-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Typical 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
The Green wire you see present in both ATX main power cables, is the Soft Power On wire.
This is BRIEFLY connected to any Ground wire.
ALL Black wires you see are Ground wires.
The Voltage present is 5 Volts DC.
Two C cell flashlight batteries produce 3 Volts DC.
There is a proper method for doing this procedure, that I would like to outline before you attempt it.
Should you wish to attempt this procedure, please state so in a Comment.
Even with the model number of your Everex desktop computer, I may not be able to give you exact guidance in opening your computer case.
With your patience, and our communicating back, and forth using Comments, I Can guide you in opening the computer case.
[Computer UNPLUGGED from power. Anti-Static precautions followed once the computer case is open]
Posted on Jul 12, 2010
Power is present at player but when on/off button is pressed nothing happens. What's wrong?
probably the motor that turns the cd on the inside if its a expensive cd player you might want to get it repaired.
Jan 23, 2015 | 2004 Suzuki Grand Vitara
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
Kitchenaid kudi01ilwh2 won't start
By won't start do you mean that everything is set ok but when you press Start button then nothing happens.
In that case most likely the door is not sitting properly or the door latch or door switch is faulty causing the dishwasher to not start.
However, if nothing happens on the panel when you press buttons but power is there, then most likely the panel is faulty and can be replaced.
you can trace the parts in these diagrams.
Nov 01, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
When you press the start button nothing happens. I checked the door switch, and the start button switch, and it is getting juice.
may have a bad thermal cutoff fuse usually located next to exhaust inside unit....remove panel and gain access.. it will usually be white in color and plastic with 2 terminals coming off of it...take a meter and ohm it out should be closed if good and opened if bad.... anymore questions repost....good luck
Jan 09, 2011 | Roper REX4634KQ Electric Dryer
Starter button quit
hello. if this an electric dryer, here are the possibilities, if it is a gas dryer get back to me.
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Aug 13, 2009 | Dryers
Jensen VM9410 - Stopped Operating All Of A Sudden
Sound like to me you got a problem with the capcitor inside the unit, if its under warrenty it will need to be serviced. If its not I ould be checking capcitors inside to make sure there not bulging leaking or otherwisen ot wroking correctly.
Jun 24, 2009 | Jensen VM9410 Car DVD Player
Gateway 7330GZ wont boot
for me this is the try and test situation,
try to remove ram -- look what happen. or try to turn on the laptop with the xp cd in the drive rom, there a similar case and the problem solved after i take out the keyboard and put it on again.
Jan 18, 2009 | Gateway 7330GZ Notebook
Camera won't switch on
if it will not power on, then let a technician repair it for you... nothing to do except hard reset... but the camera needs to power on for that to happen.. card door open, press and hold both the ok and menu button
Dec 16, 2008 | Olympus EVOLT E-410 Digital Camera
Sunbeam SMW5500 micro/convection oven shorted out when opening door
You are decribing a typical Door Safety Switch problem. The Door Safety Switches has Failed.The Door Safety Switch is designed to shut down the Micro in the event the Micro is still cooking when the door is being opened. The first "Click" of the switch cuts off the "Cook". If it does not cut off the "Cook", the second "Click" blows the power. Otherwise it would "Cook" with the door open, and I need not to tell you how DANGEROUS that could be. It first Tripped the Circuit Breaker which supplies power to the Microwave. After Re-Setting the Breaker the same thing happened except this time the Micro is DEAD- not even a light working. Yes, there is a line FUSE inside the Micro. You however need to address the Door Switch SHORT before replacing the fuse. If not, it will just Blow The Fuse Again, and Again, until the Short is corrected.
Call around, ask How much to replace a Door Safety Switch.
Good Luck!
Feb 15, 2008 | Microwave Ovens
Computers & Internet Logo
318 people viewed this question
David Payne
David Payne
